[TUTO] [MOD] Régler le problème de ralentissement/lag sur Mahdi/CM11S/crDroid
davbarr
Rencontrant quelques soucis de ralentissement sur un téléphone aussi véloce. Je suis parti à la recherche d'une solution sur XDA.
What Is it?
Some android applications have some lag when they scroll.
I found in logcat that garbage collector is working to much when I do some scroll in application.
I googled about it and found the 'scrollingcache' function inside android making problem.
Some application developers recommend disable 'scrollingcache' in app's internal config.
But not all applications have disabled scrollingcache.
So the mod I'll do will disable the scrollingcache throughout the Android OS.
All apps will have no problem with scrollingcache.
I've had scrolling improvements with facebook,playerpro,poweramp,gallery apps , etc.
http://forum.xda-developers.com/show...&postcount=210
Download
Mahdi:
Mahdi 11/03: https://www.androidfilehost.com/?fid=95784891001606162
crDroid:
10/29/2014: https://www.androidfilehost.com/?fid=95784891001603911
CyanogenMod 11S:
XNPH44S: https://www.androidfilehost.com/?fid=95784891001607684 (thanks to @dmarden)
XNPH38R: https://www.androidfilehost.com/?fid=95747613655042891 (HUGE thanks to @stizolo)
XNPH44S Revert (for future updates): https://www.androidfilehost.com/?fid=95784891001607686
XNPH38R Revert (for future updates): https://www.androidfilehost.com/?fid=95747613655042892
XNPH33R Revert (for future updates): https://www.androidfilehost.com/?fid=23622183712460610 (thanks to @tw1tch175 for providing the file)
SOURCES:http://forum.xda-developers.com/oneplus-one/themes-apps/mod-smooth-scrolling-mod-mahdi-rom-t2840934
