Flyme OS 4.1.1 test firmware
mik69
apres une réinstalle de 4.1.2A j'installe aussitôt google now 4 sans mettre mettre mon backup et pis [color=red]qd[/color] je le lance ça met "l'application recherche Google s'est arrétée" :(
Donc je confirme que la version Google now 4.0.26 ne fonctionne pas sur le firmware 4.1.2A, apres l'avoir désinstallé et mis la version 3.6.15 du google play mon google now fonctionne ! :/ :/
Modifié par mx4
Full change log :
Video
1. Optimize cache video playback logic, ensuring seamless playback of online video and cached video convergence
2. You can also play without the cache is completed, the number of cache to see how much
3. The continued optimization of the whole network search, before addressing the special character of the problem does not recognize the replacement
4. Lenovo keyword search mechanism optimization, keyword no association issues resolved before
5. Personal Center interface visual optimization
Clock
1. The new entity volume keys metering stopwatch functions
The first letter of the city's function retrieval 2. Add a new world clock
Browser
1. New multi-tabbed window animation
2. Optimize the magnifying glass to enlarge text effects
+ Game Center application center
1. Add the split package upgrades
2. New features historical version installed
Music
1. repair using a single camera editing songs cover issues cause Gallery to stop running
2. No lyrics player interface, adding "no lyrics" prompt
Boot boot
1. Use the boot boot new networking
Communications
1. Increase the top display unread messages
2. Open the message / phone APP guide Flyme increase open communication
3. Optimize visual contact details page
The message authentication code repair some pop to extract the code is not accurate
5. New Flyme communications inactive reminders
Cloud Storage
1. Modify the management of all transmission begins, all pause, delete all the status updates
2. Fix cloud disk for file upload around 1000, click on the notification bar and then point to continue to suspend the document without responding
3. Add the task of optimizing file upload download speeds
Input Method
1. Optimize emoji expression, color expression input interface
Screen will only issue a letter on the first 2. Rapid Repair Pinyin input
3. Repair full keyboard Pinyin input to the limit, the first candidate is not automatic screen problem
4. Fix calls custom interface replies bottom bar is white issue
5. Repair starts Alipay and Taobao, smartbar disappear momentarily restored problem
6. remove the English QWERTZ keyboard
Calculator
1. Optimize boot speed calculator
The weather
1. Optimize the weather at night animation
2. solve the sleep screen when sleet weather or power off screen, LCD screen is only when there is no rain and snow problems
3. Solve the share of air quality into other applications, somatosensory temperature display the wrong question
Camera
1. Optimize the speed of the video begins
2. Fix scan code mode on the flash lights only three seconds left in question
3. Repair Slow video, pause the power button lock screen, not the video again after unlocking problem
4. Fix the front camera is switched MX4 click the menu button, the camera is no gray font size set of problems
5. Click the Home Repair exit into the camera click on the record button again inefficacy of the flash video
6. Repair fullscreen problem can not focus
Security Center
1. garbage clean new timing scan Sustainment phone clean
2. New applications since the launch of the white list
3. Check the phone memory capacity is insufficient additional storage space, can be a key clean-up function
4. Slide the notification bar information about new applications banned push notification bar message function
5. Optimize a key detection experience
6. New system cache garbage can selectively clean up
7. Add the file path to clean up large files, source application, time and other auxiliary information
8. Flow control management is not new, excessive consumption of functional application of traffic
9. For large file management, optimization can choose from single to multiple choice
Mail
1. Repair mail interface takes too long to load problem in large quantities
2. Add into the mailing list loading transition animation
3. Optimize the mailing list code, resolve when the list of more than 2000 e-mail, mark the slow, delete crash
4. Fixed some problems rotated images can not be displayed correctly
Link : http://airdisk.com.cn/download/ab5138a4f...85bd8.html
je ne pense pas qu'il y aura une version internationale sur ce genre de version
mise a jours effectuer en passant pas une clef USB tjr pas trouver de solution a mon probleme d'usb avec mon PC copier sur une USB de l'USB la mettre sur le mini USB puis copier coller de la clef vers le MX4 :P
Modifié par leredge
Mise à jour effectué
Pour l'instant tout est impeccable
Petite question (mode noob android on :D) : Vous réinstaller google installer, le super user etc a chaque mise à jour ou vous avez un truc pour automatiser
Pour le coup venant d'un iphone sur cydia des tweaks permettait de tout réinstaller en auto
Hello,
Je suis passé de la 4.0.4I sur la 4.1.2A plus mise à jour 4.1.3A
Touchpal X, téléchargé sur le playstore marche bien et en français (pour la reconnaissance vocale et correcteur)
Modifié par Dream-eco
Bon finalement je suis passé en 4.1.3A. Quelqu'un sait si c'est possible de désactiver l'animation/transition de zoom lorsqu'on accède aux dossiers sur le launcher stock ? Y'a un soucis de lenteur et j'aimerai ne pas changer de launcher pour l'instant. Sinon pas de soucis notable :)
