Aizkolariak Aizko Posté(e) 17 décembre 2014 Share Posté(e) 17 décembre 2014 bonjour j'ai rooter ma tablette via iRoot . J'ai testé avec root checker voici le résultat Congratulations! You have root access! Super User Application Status:SuperSU application by Chainfire - version 2.40 - is installed! System File Properties for Root Access:Standard LocationCheck Command: ls -l /system/bin/su:Result: -rwsr-sr-x root root 46416 2014-12-17 13:24 suAnalysis: Setuid attribute is present and root user ownership is present. Root access IS correctly configured for this file! Executing this file can grant root access! Standard LocationCheck Command: ls -l /system/xbin/su:Result: -rwsr-sr-x root root 46416 2014-12-16 15:00 suAnalysis: Setuid attribute is present and root user ownership is present. Root access IS correctly configured for this file! Executing this file can grant root access! Alternative LocationCheck Command: ls -l /sbin/su:Result: /sbin/su: Permission deniedAnalysis: File system permissions restricted and denied access. Alternative LocationCheck Command: ls -l /system/xbin/sudo:Result: /system/xbin/sudo: No such file or directoryAnalysis: File /system/xbin/sudo does not exist. Root User ID and Group ID Status:Root user id: Root not properly returning its user id Root group id:Root not properly returning its group id System Environment PATH: /sbin /vendor/bin /system/sbin /system/bin /system/xbin ADB Shell Default User:ADB shell setting for standard access, stored in default.prop, is configured as: shell (non root) user - ro.secure=1 Results provided on your K00F - Android 4.2.2 device by Root Checker Pro version 1.3.9 from joeykrim in the Android Market mais lorsque j'allume superSU la mise a jour ne veux pas s'ouvrir et apres avoir suivi le tuto de ce site http://www.galaxynote.fr/verifier-root-partiel-total-full-root-t5297.html j'en conclu que l'etape 1 et 3 ne fonctionne pas donc ma tablette et rooté partielement . je ne trouve pas un bon tuto pour la rooter entièrement merci pour votre aide Lien vers le commentaire Partager sur d’autres sites More sharing options...
maxoxo Posté(e) 17 décembre 2014 Share Posté(e) 17 décembre 2014 Lorsque tu as rooté avec iRoot il t'as installé SuperSU ? Tu as dû virer trop tôt l'application installée par iRoot, il faut mettre à jour SuperSU pendant que cette application installée par iRoot est encore là. En gros il faut que SuperSU prenne totalement le contrôle de su. Assure-toi aussi lorsque que tu exécutes iRoot qu'ADB soit bien activé et que la case "autoriser les applications inconnues" soit bien cochée dans Sécurité. Lien vers le commentaire Partager sur d’autres sites More sharing options...
aizkolariak Posté(e) 18 décembre 2014 Share Posté(e) 18 décembre 2014 merci pour ta réponse. effectivement la seul application qui c'est mis c'est kinguser. ensuite superSu je l'ai mis apres car il n'était pas installer. case "autoriser les applications inconnues" soit bien cochée dans Sécurité ok pour adb je n'ai pas trop compris sont installation mais comme le root se faisait je ne me suis pas occupé de odb .mais lorsque j'allume la tablette il y a ASUS Android Composite ADB Interface sur peripherique du pc . Lien vers le commentaire Partager sur d’autres sites More sharing options...
aizkolariak Posté(e) 18 décembre 2014 Share Posté(e) 18 décembre 2014 bon j'ai refait le root avec motochoper et sa marche très bien. vérifier avec root checker et super user c'est mis a jour. merci pour vos info . amicalement Lien vers le commentaire Partager sur d’autres sites More sharing options...
