Posté(e) 7 septembre 200917 a voila installée sur un Magic... c'est une tuerie... http://forum.xda-developers.com/showthread.php?t=555735
Posté(e) 7 septembre 200917 a d'ailleurs .. http://android.modaco.com/content/htc-sapphire-sapphire-modaco-com/292559/07-09-2-1-modaco-custom-rom-hero-to-sapphire-32b-port/ vous avez plus qu'a changer :D
Posté(e) 8 septembre 200917 a Va falloir que je l'essaie celle-là mais pour le moment, j'ai rien pour formatter ma partition ext3 :(
Posté(e) 8 septembre 200917 a J'ai prit celle de Akirah dans le même genre surnommait 'Hero 2' et ça tourne très bien.
Posté(e) 9 septembre 200917 a Formatting you SDcardYou need Recovery image 1.31 to do this folks! To format card SD card with linux-swap WARNING!!! this will reformat you entire SD card!! You can use the recovery console and parted to format SDcards with 1.31 folks, no more going through hassles you have the tools on you G1!...here is an example of how to do this in recovery console using parted. DO NOT USE MORE THAN 32MB SWAP!!! Example for 8GB card (this example plays it safe and will leave a small amount leftover regardless of the 8GB card) Reboot and enter recovery Enter console #parted /dev/block/mmcblk0 #print (to verfiy we know what size card we are dealing with, the details should be straight forward) rm 1 rm 2 mkpartfs primary fat32 0 7200 mkpartfs primary ext2 7200 7700 mkpartfs primary linux-swap 7700 7732 #print (to verify we have the 3 partitions) Example for my 4GB card #parted /dev/block/mmcblk0 #print (to verfiy we know what size card we are dealing with, the details should be straight forward) rm 1 rm 2 mkpartfs primary fat32 0 3420 mkpartfs primary ext2 3420 3932 mkpartfs primary linux-swap 3932-3964 Example for a 2GB card playing it safe #parted /dev/block/mmcblk0 #print (to verfiy we know what size card we are dealing with, the details should be straight forward) rm 1 rm 2 mkpartfs primary fat32 0 1200 mkpartfs primary ext2 1200 1700 mkpartfs primary linux-swap 1700-1732 "End?" you need to place the last value for the linux swap eg.3964 for my 4GB card #print (to verify we have the 3 partitions) Next we need to "quit" parted and upgrade our ext2 partition to ext3 #upgrade_fs Swap value is set to 30 currently, you can change this by modifying the "echo" value for swappiness in the a2sd.sh script For a longer more detailed parted turorial read this Flashing the ROM
Posté(e) 9 septembre 200917 a Petit retour sur la MoDaCo que j'utilise actuellement (la 2.2). C'est plutôt fluide et sympathique, mais personnellement, il persiste encore des défauts qui gênent : - Ca n'est pas aussi fluide qu'une cyanogen ou autre rom "normale". - Le rechargement de la home à la sortie d'une application que je trouve très lourd à l'utilisation. Ca demande encore à mûrir mais c'est bien parti ;)
Posté(e) 9 septembre 200917 a Merci pour le retour j'hesitais a la tester. Je reste sur ma cyanogen experimental finalement (dailleurs la 4.1.6 vient de sortir)
