[ROM CUSTOM] [5.1.1] ResurrectionRemix v5.5.9 (20/11) Dernière update !
Voici la Resurrection Remix pour le Galaxy Alpha, une rom CM améliorée :)
Resurrection Remix Features:
  • Enable/Disable Navigation Bar (+ left/right handed mode switch)
  • Navbar Button Customization
  • Navbar Dimensions (Potrait & Landscape)
  • Brightness Slider
  • Enable/Disable Show Notification Count
  • SuperUser Indicator Switch
  • Carrier Label (Switch + Colour)
  • Quick Pulldown Switch + Smart Pulldown Switch
  • Clock Customizations (colour, day & date toggle, center clock/right clock choice)
  • Battery Bar/Icon Customization
  • Network Traffic Indicator
  • RR exclusive PITCH BLACK THEME
  • Gestures Anywhere Feature
  • App Circle Bar (choose apps in app circle, trigger width/height/position)
  • Recents Panel
  • Clear All Tasks Switch (+ adjust position of button)
  • cLock Widget
  • Lockscreen Shortcuts (choose up to 5 shortcuts, 100+ icons for shortcuts)
  • Quick Settings (choice to add 20+ tiles, enable 2/3/4 tiles per row, enable/disable brightness slider etc.)
  • Buttons (backlight timer/strengh)
  • Power Menu End Calls Switch
  • Specific options and adjustments for NavBar + Volume buttons
  • LCD Density
  • Expanded Desktop Mode
  • OverAll Smoothness Improvements, Optimizations to Improve Battery
  • Quick Unlock
CyanogenMod 12.1: Features and Additions:
  • Privacy Manager - restriction of app rights
  • Extended Volume Indicator - subdivision into calls/messages, media und alarm
  • AudioFX Equalizer + Eleven Music Player - extended audio settings
  • Blacklist - block incoming calls and messages
  • Theme Engine - own adjustments of the user interface
  • System Profiles - automatic adjustment of system settings
  • Root - The Privacy Manager is responsible for allowing root access.
  • Statusbar - control the battery/clock indicators etc.
  • Launcher3 - an own home screen provided by CM
  • Filtering of App Notifications
  • CM File Manager - Root Access Mode available
  • Quiet Hours
  • AOSP Browser, Gallery App, SIM-Toolkit, Soundrecorder etc.
Changelog 20/11:
Android update: 5.1.1_r26
Screenshot:
ici
Download:
GAPPS
Bugs
Weak vibration after the end of a call
Tuto:
- Etre en 5.0.2, être rooté, avoir la rom et les Gapps dans la mémoire du téléphone
- Faite un backup dans le recovery
- Faite un wipe (/system, /data, /cache, dalvik cache)
- Installer d'abord la rom puis les Gapps
- Puis rebooter B)
Modifié par Yeezus.
Salut, tu as testé la ROM ? Elle est stable, fluide et sans bug ?
C'est pour le Alpha de ma petite soeur, faut que ce soit le plus stable possible.
les ROM's commencent enfin à arriver sur le Alpha, c'est cool.
En tout cas, merci pour le partage.
Oui je l'ai testé, elle stable et très très fluide. Le seul bug qui a pu me gêner c'est la caméra quand tu filme c'est tout bleu mais il me semble qu'il faut utiliser une autre app "camu camera" pour corriger ce problème.
Si tu veux du "pure Google" installe-la sinon je peux aussi te conseiller la Ozcan Rom si tu veux du touchwizz bien optimisé ;)
Envoyé de mon SM-G850FQ en utilisant Tapatalk
Modifié par Yeezus.
Le probleme vient surtout dans la connexion bluetooth avec mon vehicule .
Pour les autres appareil cela fonctionne.
Ozcan tout fonctionne correctement en 5.02 et resurrection remix en 5.1.1 ne marche pas.
Merci quand meme pour tes reponses.
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
