[APAD][ROM] Hybride Relax v1.2/3 [02/02/11]
Hello all,
alors Marlket ok a 100%,enfin tout est fonctionnelle avec les perfs au gout du jour ;)
Quatres thèmes disponible,la totale B)
Uniquement pour APAD batch 2 red light bootloader 3.20.
Procédure to flash :
https://forum.frandroid.com/forum/viewtopic.php?pid=438272#p438272
Relax v1.3 Gingerbread ÉDITION[15/01] :
http://www.4shared.com/file/NKjIENTW/APAD-Hybride_Gingerbread__Rela.html
Hybrid Relax v1.2 BLACK ÉDITION :
lefeudedieu-Hybride-Relax v1.2-Black.rar - 4shared.com - online file sharing and storage - download
Hybrid Relax v1.2 SYLVER ÉDITION :
lefeudedieu-Hybride-Relax v1.2-Sylver.rar - 4shared.com - online file sharing and storage - download
Élégant SlateDroid Steel :
lefeudedieu-SlateDroid Steel-updateV2.zip
Applications APAD :
APAD APP.zip
ROM :
v1.3 :
Base v1.2 root
Théme Gingerbread
New Youtube (Fullscreen)
v1.2 :
Base v1.1 root
Black/Sylver ÉDITION
News Spares Parts
News icones apps
Now icons (return, Home, Vol + / -, Menu) in the bar are Blue
v1.1 root :
Base HKX1.3.3 by Xaueious
Boot.img (Donaldson Firmware 3)
Finish Sylver theme
News icons
More lightweight and fluid
The Market operates correctly
v 1.0 root :
Base HKX1.3.2 by Xaueious
Turbo Script (1.5 CupCake "Revolve" by Alex/Lfd for Dream)
CompCache has deleted each re-boot
Sylver theme by Goldopaco (More light and speed)
Ambient Time (Sony Ericsson touch your screen AmbientTime after you have activated)
Music Player
TaskKillerFull
Reduction of weight
New boot animation
New icons
Aldiko book
New Fonts (more Hebrew, Arabic, Thai)
Je ne saurais etre responsable,ect,ect.
Pour le Batch 3 9v blue led :
SlateDroid Forum :
http://www.slatedroid.com/index.php?board=167.0
Lfd ici Toulouse :cool:
Modifié par lefeudedieu
  • 4 weeks later...
Procédure pour flasher ton APAD IROBOT "7" :
Télécharge "Outil de Flash" APAD ci-dessous .
http://www.mediafire.com/?14si0y4a0ynl3e9
Télécharge ton firmware (By Lfd ;) ).
Flash en suivant la procédure suivante :
1)tu éteins ton APAD
2)tu bascule le bouton "Power" sur Off puis sur On
3)tu appuie sur le bouton "Home" sans le relâcher (IMPORTANT) en haut a gauche.
4)tu branche ton Usb au PC,windows te demande alors la direction des drivers a installer,lesquels se trouvent dans le répertoire "Drivers" de "RKAndroid_ENG1"que tu as préalablement téléchargé "Outils-Rockchips" et installé sur ton bureau
(Lorsque tu branche l'usb il faut absolument le brancher sur port qui se trouve en entre le bouton d'alim et le On/Off)
5)Tu relâche "Home" après l'installation des drivers et ouvre RKAndroid_ENG1
6)tu indique a RKAndroid_ENG1,la direction ou se trouve la ROM (update.img) téléchargée et de-zippée sur ton bureau.
7)tu appuie sur "Update",la procédure se lance,attends la fin,ferme RKAndroid_ENG1 et débranche ton câble Usb,tu calibre l'écran et voila "Update successfull".
Le Forum et moi-même ne serions être tenue responsable d'une mauvaise manipulation en cas de brick.
Quel est ton modèle APAD-Irobot "7" :
Salut a toi,
trois choses pour identifier son APAD I-robot (si tel est le cas !).
1)le voltage du transformateur deux éventualités : 5volt ou 9volt
2)le voyant en charge,sa couleur:rouge ou bleu
3)sur la tranche droite du bas vert le haut tu as :
1)l'alim
2)prise casque
3)mini usb (par lequel on flash)
4)bouton on/off
5)mini usb (clef usb/3G)
6)slot micro-SD
Il existe trois modèles chez APAD-Irobot "7":
batch 1 = 5v+led bleu
batch 2 =5v+led rouge
batch 3 =9v+led bleu
Si tu as cette config boutons et un des trois batchs (3) qui est cités,tu as un vrai APAD-Irobot ;)
La procédure ici :
Bien sur avec ma Relax v1.2/3 Cupcake 1.5,tu aura bien plus que l'accès au Market ;)
A plus B)
merci pour se petit tuto ,
moi g un apad avec le boutton on/off a gauche et pour se qui et de la prise usb , je l'ai mais sur un adaptateur que je branche sur l'apad !!!
le rom et pas fait pour celui la je pense ?
si mon apad ne peut pas utiliser se rom , connaissez vous un rom qui peu fonctionner sur le mien ??
merci d'avance
merci d'avance
Il faut que ta led en charge soit de couleurs rouge et que ton transformateur sorte du 5v pour utiliser cette ROM.
Il y a aussi des APAD en 9v et Led bleu ou rouge,c'est de cette façon que tu identifiera ta ROM,trois versions en tout batch 1/2/3.
Jette un oeil sur le Slatedroid forum,tu trouvera ton bonheur,j'ai aussi fait une ROM pour batch 3 led Rouge 9v qui est la bas.
A plus
Modifié par Leufeudedieu
  • 3 months later...
  • 1 month later...
  • 9 months later...
Salut a tous,
je rapproche ce sujet pour les possesseurs d'un APAD ou tout autre K2808.
Ayant recu gratuit un de ces ancêtres que l'ont peu mettre au gout du jour,on ne sais jamais ca peu servir,car ici il y a la totale (1.6/2.1/2.2/2.3) pour ces MIDS.
http://www.slatedroi...edieu-firmware/
lefeudedieu
Modifié par Lfd
