Recovery TWRP Android 5 Lollipop
Testé par moi meme a 15h30.
avec la derniere mise a jour: 12.8.5.222
Donc, maintenant que nous avons cette TWRP travailler.
Screenshot de l interface:TWRP 3.0.0.0 Recovery
Screenshot de l interface:TWRP 2.8.7-7 Recovery
Téléchargez TWRP.img et Flashify sur votre téléphone (nécessite root)
TWRP 3.0.0.0
https://github.com/sabpprook/android_device_asus_ze500kl/releases
TWRP 2.8.7.7
http://click.xda-developers.com/api/click?format=go&jsonp=vglnk_145114306775813&key=f0a7f91912ae2b52e0700f73990eb321&libId=iin8mnos01000n4o000DL228ao0pc&loc=http%3A%2F%2Fforum.xda-developers.com%2Fzenfone-2-laser%2Fgeneral%2Ftwrp-ze500kl-t3277224&v=1&out=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F0B1pErR_Eg7cXVXNEeUN2RDhPOUU%2Fview%3Fusp%3Dsharing&ref=http%3A%2F%2Fforum.xda-developers.com%2Fzenfone-2-laser%2Fgeneral%2Ftwrp-ze500kl-t3277224%2Fpage2&title=TWRP%20for%20ZE500KL%20%7C%20Zenfone%202%20Laser&txt=Ici TWRP
http://click.xda-developers.com/api/click?format=go&jsonp=vglnk_145114317445515&key=f0a7f91912ae2b52e0700f73990eb321&libId=iin8mnos01000n4o000DL228ao0pc&loc=http%3A%2F%2Fforum.xda-developers.com%2Fzenfone-2-laser%2Fgeneral%2Ftwrp-ze500kl-t3277224&v=1&out=https%3A%2F%2Fplay.google.com%2Fstore%2Fapps%2Fdetails%3Fid%3Dcom.cgollner.flashify%26hl%3Dit&ref=http%3A%2F%2Fforum.xda-developers.com%2Fzenfone-2-laser%2Fgeneral%2Ftwrp-ze500kl-t3277224%2Fpage2&title=TWRP%20for%20ZE500KL%20%7C%20Zenfone%202%20Laser&txt=Flashify
1: Lancez Flashify et selectionnez recovery image. allez chercher le TWRP.img puis redemarez votre mobile
Retirer TWRP
Exactement même procédure, mais avec la reconstitution des stocks.
http://click.xda-developers.com/api/click?format=go&jsonp=vglnk_145114320604216&key=f0a7f91912ae2b52e0700f73990eb321&libId=iin8mnos01000n4o000DL228ao0pc&loc=http%3A%2F%2Fforum.xda-developers.com%2Fzenfone-2-laser%2Fgeneral%2Ftwrp-ze500kl-t3277224&v=1&out=https%3A%2F%2Fdrive.google.com%2Fopen%3Fid%3D0B1pErR_Eg7cXSGRycW9tZzNLd3c&ref=http%3A%2F%2Fforum.xda-developers.com%2Fzenfone-2-laser%2Fgeneral%2Ftwrp-ze500kl-t3277224%2Fpage2&title=TWRP%20for%20ZE500KL%20%7C%20Zenfone%202%20Laser&txt=Stock%20recovery
source du poste: http://forum.xda-developers.com/zenfone-2-laser/general/twrp-ze500kl-t3277224
si avec la manip Power et volume + vous ne parvenez pas a avoir accé au Recovery, essayez par le biais de cette application.
https://play.google.com/store/apps/details?id=com.codem.reboot&hl=fr Modifié par JackMess24000
  • Like 3
Merci beaucoup pour ton retour ^^
  • 1 month later...
Comment unrooter Android ?
Vous avez tous l'application SuperSU intallée sur votre mobile à la suite du root justement. L'application possède une fonction qui permet de retirer l'accès au root . Ensuite désinstaller l'appli
Modifié par dickdevries29
J'ai essayé de suivre ton post ici
http://click.xda-dev...er&txt=Ici TWRP
http://click.xda-dev...er&txt=Flashify
Mais ensuite le zenfone 2 ne fonctionne plus ( reste bloqué dans la mire asus au démarrage !
Tu sais pourquoi ?
Super pour toi
je viens de le faire juste à l'instant et au reboot il reste bloqué dans la mire (logo asus)
et ne bouge plus
j'ai du encore repasser par adb pour m'en sortir et installé le root ( mod_boot )
et là il redémarre normalement . C'est un bug ou mon zenfone je dois l'envoyer au SAV ?
Moi l accé au recovery est Power + Volume-
quand ton telephone reste bloqué sur ASUS, retire la baterie et essaye de redemarrer en recovery TWRP avant de tester le reste.
Moi ce que je testerais avant.
C est de refaire une reinitialisation, puis
De refaire l installe de la derniere version.
De root et d essayer de reinstaler TWRP.
Si apres ceci tu as tjs le meme soucie un retour sav pe etre possible. Ou tu patiente peut etre la prochaine mise a jour
