Acceder a un header d'un drawerlayout
Baptiste Leulliette
Je n'arrive pas a acceder au TextView que l'on pourrait trouver dans un LinearLayout qui lui meme se trouve dans le NavigationView du drawerLayout...
J'ai posté sur StackOverflow sans réel succes, alors je me tourne vers vous :
http://stackoverflow.com/questions/34518757/change-textview-in-drawerlayout
ActivityMain :
<?xml version="1.0" encoding="utf-8"?>
<android.support.v4.widget.DrawerLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    xmlns:tools="http://schemas.android.com/tools" android:id="@+id/drawer_layout"
    android:layout_width="match_parent" android:layout_height="match_parent"
    android:fitsSystemWindows="true" tools:openDrawer="start">
    <include layout="@layout/app_bar_main" android:layout_width="match_parent"
        android:layout_height="match_parent"/>
    <android.support.design.widget.NavigationView android:id="@+id/nav_view"
        android:layout_width="wrap_content" android:layout_height="match_parent"
        android:layout_gravity="start" android:fitsSystemWindows="true"
        app:headerLayout="@layout/nav_header_main" app:menu="@menu/activity_main_drawer" />
</android.support.v4.widget.DrawerLayout>
et le nav_header_main
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_width="match_parent" android:layout_height="@dimen/nav_header_height"
    android:background="@drawable/side_nav_bar"
    android:paddingBottom="@dimen/activity_vertical_margin"
    android:paddingLeft="@dimen/activity_horizontal_margin"
    android:paddingRight="@dimen/activity_horizontal_margin"
    android:paddingTop="@dimen/activity_vertical_margin"
    android:theme="@style/ThemeOverlay.AppCompat.Dark" android:orientation="vertical"
    android:gravity="bottom">
    <ImageView android:layout_width="wrap_content" android:layout_height="wrap_content"
        android:paddingTop="@dimen/nav_header_vertical_spacing"
        android:src="@drawable/side" android:id="@+id/imageView" />
    <TextView android:layout_width="match_parent" android:layout_height="wrap_content"
        android:id="@+id/labelConnection"
        android:paddingTop="@dimen/nav_header_vertical_spacing" android:text="Se connecter..."
        android:textAppearance="@style/TextAppearance.AppCompat.Body1"
        android:onClick="onClick"
        android:clickable="true" />
</LinearLayout>
Je n'arrive pas a acceder au textview qui se nomme LabelConnection, a chaque essai, je tombe sur un nullPointerException......
Des idées?
  • 1 month later...
Si tu fais un findViewById dans ton activity, tu ne le trouveras pas car il va le chercher dans le root layout (donc ton DrawerLayout)
Il faut que tu récupères d'abord ton object NavigationView (appelle le mNavigationView par exemple) puis tu récupère son header :
mNavigationView.findViewById(R.id.labelConnection) devrait fonctionner.
Ou bien, je n'ai pas vérifié, mais tu as peut être même un getter sur NavigationView : View mHeader = mNavigationView.getHeader() ... à vérifier
