[KERNEL][STOCK/CM13][G4-h815] [SUPERXE][5.1/6.0] [19/02/2016]*[TWRP 3.0.2.0]
:excl: Lien du thread original sur xda :excl:  :
Noyau LG-G4 personalisé basé sur H815 ,compilé avec les dernières sources LGE .
Compilé via  aarch64-linux-android-4.9 toolchain
5.1 - KERNEL-STOCK
v1.1 Initial Release
- init.d support
- permissive selinux
- exfat fs support
v1.2 Release
- added I/O Schedulers (bfq,fiops,zen,sio)
- bcmdhd:reduced rx wakelock
v1.3 Release
- improved stability and overall smoothness.
- ramdisk updates to support all lollipop stock based roms - 10x
- busybox auto install if not present
- KCAL post-processing driver @savoca
- compiled every TCP Congestion Algorithm into the kernel so now every user will be able to choose which one to use:
-bic
-reno
-cubic
-westwood
-vegas
-veno
-yeah
-illinois
-more information on github...
v1.4 Release
- No CPU and GPU overclocking yet
- Synapse support (install app from playstore)
- USB Fast charge
- Added state notifier driver @neobuddy89
- Added Adreno Idler @arter97
- Fixed GPU frequency scaling (180-600Mhz)
- Drivedroid support
- Updated touchscreen firware to L0L55P1_1_11
- Updates and fixes from google and CAF msm-3.10
- More information on github...
v1.5 Release
-Overclock A53/384-1632 A57/384-2016 (choose during aroma installation)
- USB mouse and keyboard support
- Fauxsound support(use faux123 app)
- updated zram driver from linux 4.1
Version Information
Current version: 1.5
Status:Stable
6.0 - KERNEL - STOCK
v1.6 Release
support all marshmallow stock based roms - 20x
- autoroot if your system is not already rooted
- init.d support
- exfat fs support
-bic
-reno
-cubic
-westwood
-vegas
-veno
-yeah
-illinois
- USB Fast charge
- State notifier driver @neobuddy89
- Added Impulse governor
- Overclock A53/384-1632 A57/384-2016 (choose during aroma installation)
v1.7 Release
- latest CAF updates
- /dev/frandom support
- usb debugging fixed
- show cpu voltages via sysfs
- updated state notifier driver
- updated adreno idler driver
- updated impulse governor
- 27Mhz gpu sleep state frequency
- fauxsound works with kernel adiutor now
- less aggressive thermal throttling
v1.8 Release
- LGE 20d kernel source
- Latest CAF updates
- Zram backport (linux 4.1)
- Full crypto support
- Optimized cpufreq/governors
- A53/A57 clusters undervolted (-25mV)
- Reduced wlan timeout wakelock (current value 4/25%)
- Motorola's lmk,shed and power optimizations
- Disable thermal-engine hotplug and poll instead (50c) (flar2)
- Sound control V2 (faux123/flar2/cile381) (cleaned and adapted for G4)
- Kernel now use frandom as RNG
- 27Mhz GPU min freq (idle/sleep)
- Disabled PM fsync-added Dynamic fsync (faux123/Boefla)
- Disabled CRC control
- Tuned LGE lbfc/cancun for overclocking ability
- Removed autoroot option from kernel (either way kernel support system/less root)
To change the kernel values use Kernel Adiutor.
Version Information
Current version: 1.8
Status:Stable
Credits:
- faux123
- savoca
- flar2
- arter97
- neobuddy89
- Dees-Troy
DOWNLOAD
_____________________________________________
*H815* *5.1 *
*H811* *5.1*
______________________________________________
*H815/H811 *5.1* UNI*
-Kernel v1.5
*H815*6.0*
*SUPERXE KERNEL - H815*MM - 6.0.x - CM13 BASED ROMS*
V1.0
- Compiled every TCP Congestion Algorithm into the kernel so now every user will be able to choose which one to use:
- USB Fast charge
- exfat fs
- CPU voltages via sysfs (ro)
V.1.1
-New installation method (kernel now supports all CM based roms)
Version Information
Current version: 1.1
Status:Testing
DOWNLOAD
Kernel - CM13 - v1.0
Kernel - CM13 - v1.1
INSTALLATION :
- Flashé dans le recovery TWRP.
-Reboot
TWRP RECOVERY H815 MM-6.0X
- Built from android-6.0.1_r16 sources
- Flash through the existing recovery
CHANGELOG for 2.8.7.0:
- Initial ground work for software drawn keyboard (_that)
- Fix handling of wiping internal storage on datamedia devices (xuefer)
- Allow DataManager to set and read values from the system properties (xuefer)
- Fix crash when taking screenshots on arm64 devices
- Fix error message after an ORS script completes (Dees_Troy)
- Fix crashes / error when creating encrypted backups (_that, Dees_Troy)
- Add system read only option – more details below (Dees_Troy)
- Add resize2fs and GUI option to run resize2fs (Dees_Troy)
- Fix crash loop caused by empty lines in AOSP recovery command file (_that)
- Prevent duplicate page overlays such as multiple lock screens (mdmower)
*DOWNLOAD 2.8.7.0*
CHANGELOG for 3.0.0.0:
- Completely new theme - Much more modern and much nicer looking (by z31s1g)
- True Terminal Emulator - Includes arrow keys, tab and tab completion, etc. (by _that)
- Language translation - It won’t be perfect and especially some languages that require large font files like Chinese & Japanese won’t be availble on most devices. Also some languages may only be partially translated at this time. Feel free to submit more translations to OmniROM’s Gerrit. (mostly by Dees_Troy)
- Flashing of sparse images - On select devices you will be able to flash some parts of factory images via the TWRP GUI (by HashBang173)
- Adopted storage support for select devices - TWRP can now decrypt adopted storage partitions from Marshmallow
- Reworked graphics to bring us more up to date with AOSP - includes support for adf and drm graphics (by Dees_Troy)
- SuperSU prompt will no longer display if a Marshmallow ROM is installed
- Update exfat, exfat fuse, dosfstools (by mdmower)
- Update AOSP base to 6.0
- A huge laundry list of other minor fixes and tweaks
*DOWNLOAD 3.0.0.0*
DOWNLOAD 3.0.2.0
https://www.androidfilehost.com/?fid=24459283995313307
CHANGELOG for 3.0.2-0:
- support new CM 13.0 pattern encryption (sultanqasim)
- fix slow flashing issue due to modprobe (present on only some devices) (#twrp)
- libtar updated to latest upstream and fixes (jcadduono)
- fixes for loading custom themes (_that)
- TWRP will now detect and install TWRP themes automatically through the normal zip install process (Dees_Troy)
- translation updates – added Italian, Czech and Polish and significant updates to Dutch
- progress bar improvements – progress bar updates during image flashing and better tracks progress during file system backups (tar) (Dees_Troy)
- fix input box text display (Dees_Troy)
- Reboot option after zip install complete (bigbiff)
- Other mostly invisible bug fixes and improvements
TOUT CREDIT @cile381
http://forum.xda-developers.com/member.php?u=823251
Screenshot
d77a2437b5b0e5f6fc21db277e6006f8.jpg7ee6b18907fd6872e673de88a1b0921b.jpgfc34d9330fa535ced0a246ecde0090ab.jpg
Envoyé de mon LG-H815 en utilisant Tapatalk
Gouverneur performance lite et big :
Le test antutu a bouffé 3 % de batt.
Modifié par herveonex
Salut LudoG4,
Bonne question et étant récent dans le monde LG je ne serai te répondre clairement ...pour ne pas y avoir été confronté et rien ne ressort du post original sur la question!
Je suis sous 20d donc pas eu de souci pour ma part .
Au pire fait un backup complet avant avec twrp ....
Moi je suis sous imperium kernel v2.4
Je ne sais pas lequels des nombreux kernel pour le lg g4 est le mieux n'ayant que tester l'imperium ...
Je ne suis même pas sur qu'il y ait grande difference entre tous ces kernels les retours sont dans l'ensemble tous bon .....
A voir
oui il y a du choix et c'est cool çà B)  !
Apres chacun a un peut ses spécifications quand même suivant
les gouverneurs /volt/TEMP employé ainsi que leur OC/UC pour le score ou bien au contraire la duré de vie de la batterie  :D en générale.
Et donc leur différent accès via des appli ou la gestion de la ram   ^_^ !
Perso jai prit les fréquences les +élevé pour les petits proc et les gros proc .
2.02 Ghz
Ok super merci j'ai donc mis les mêmes fréquences que toi,
Je suis à 98000 sur Antutu, première fois que j'arrive à un score pareil (j'avais pas réussis avec le kernel Impérium)
Donc je suis content, mais ce sont de réelle performance ? Ou ça trafique Antutu un peu? fin ça optimise que certains trucs pour monter le score Antutu?
Perso le tel est plus réactif, c'est une sorte d'overclokage c'est ça? Le pross n'est pas mis en danger de le laisser tourner à cette vitesse la?
C'est le constructeur qui bride à votre avis ou pas?
Bref Genisys + Kernel 1.8 ça fonctionne j'ai juste reflash SuperSU au cas ou car on m'avait dis un truc du style sur XDA donc voila. Faites un backup ceux qui veulent se lancer je recommande quand même.
Encore merci pour le topic! :)
Merci du retour sur la compatibilité c'est cool !! :D
Oui c'est de l'overclocking (oc) du CPU, fréquences augmenté sur les 6 cœurs 2x2.02Ghz et 4x1.63Ghz .
Un danger direct  non du-moins sur mes anciens smartphones je n'ai jamais eu un cramage de cœurs , après oui c'est quand même risqué si tu fais n'importe quoi avec les appli qui gère ça,  genre laissé les 6  a fond même sans  grande activité réel ,après il est dans la marge souvent utilisé dans l'oc à savoir 200/250 ghz .
Par exemple mon S5+ avec son 805 à 4x2.5ghz peut etre OC a 4x2800ghz  ainsi que son GPU passé de 600ghz a 800 ghz mais le tel devient très très chaud pour arriver maxi a 78000 sous antutu ,et il n'est pas stable dans temps ...
Là le GPU n'est pas OC donc ça va encore lol, mais avec un OC important du gpu (puce graphique)  ,le tel commence a chauffer sévèrement .
Par contre tu peux faire l'inverse et bloqué les fréquence comme ex:  2x1.5 ghz et 4x0.9. ghz et donc baisser ta conso de batterie ,pour le gpu ne baisse pas trop par contre ...
je ne serai te dire si il joue sur des paramètres pour antutu mais si c'est le cas cela sera vite vu par d'autre et donc vite dit  ....
D'après mon experience l'overclockage sur android n'est utile que sur des telephone bas de gamme et encore lorsque ces bas de gamme le supporte
Pour le G4 je ne vois pas trop l'intérêt a part bouffer de la batterie le G4 etant deja tres bien comme il est de plus effectivement il y a un risque de cramer le cpu sur le long ou le court terme depend de se que peut supporter le cpu ....
Moi j'ai le imperium kernel underclocker a 1440 mhz je ne vois aucune difference mis a part niveau autonomie je tiens 2 jours voir 3 jours maintenant : )
Ondemand dans les reglages ordonnanceur cfq le gpu sur simple_ondemand bref rien ne change niveau réactivité et fluidité et je gagne en autonomie ah si le score antutu baisse evidement mais le score antutu mis a part mentir sur les chiffres et pis c'est vraiment le jeu de celui qui a la plus grosse pour moi aucun intérêt...
J'ai longtemps ete sur des bas et milieu de gamme que je rootais, modifiais , overclockais pour que mon precieux se rapproche des hauts de gamme de leur fluidité entre autres mais aussi leur possibilité quasi infini de pouvoir tout faire tourner , la possibilités d'avoir des mises a jours régulière , etc ...
Maintenant que j'ai le G4 je me rend compte qu'une fois qu'on a un haut de gamme ben on peut le garder plus longtemps qu'un bas de gamme la fluidité du S6 par exemple est quasi la meme que sur le G4 enfin a quelques petites differences près de quelques miliseconde mais quasi imperceptible pour nous alors bon a quoi bon changer a part peut pour les nouvelles fonctionnalités qu'au final ont utilisera pas .... Bon j'arrete la je m'egard total
C'était la minute philosophique lol
Modifié par Renaf
La minute philo j'aime bien ^^ moi : )
Question la plus grosse ,c'est un point de vu meme principe que d'avoir des route a 130 et des caisses meme standart qui vont a 200 .
Le 1 er but maintenant(de nos jour) est l'under aussi , avoir un travail sur la ram et la volonté a tout moment de basculer de profils suivant l'utilisation.
Et oui au niveaux du G4 l'utilité de l'uc est presque nul et inintéressant ors habitude de bidouillages que j'ai gardé perso ,ce n'est pas parce qu'une personne a désiré brider ma bécane a 100 ps que je vai rester aussi ,pourtant avec 100 j'ai déjà de quoi me sateliser.
L'utilité et la futilité des choses est inhérent a l'humain ou sinon faut devennir bouddhiste ^^ .
Oui j'exagère un peut ; )
Non non j'aime bien la phrase sur l'utilité et la futilité
Sa resume assez bien l'humain est materialiste et perfectionniste mais c'est futile ; l'utilité c'est de subvenir a ces besoins : )
Bref bref ; )
Oui fin j'ai essayé de baisser la fréquence, c'est une catastrophe lol ou alors j'ai pas baissé le bon truc.
On sent quand même la diff et c'est assez violent, pour le moment je suis avec les fréquences dites "stock"
Tu règle avec quoi?
Tu met tout à fond en flashant le kernel et ensuite tu ajuste avec des apps c'est ça?
En mettant mes freq en stock je reste à 98000 sur Antutu ça fait plaisir à voir la batterie maintenant.
Ca donne un truc du style : 4x1,44GHz et 2x1.82GHz
J'utilise  Kernel Adiutor , tu peux régler tes fréquences à souhait et jouer aussi sur les gouvernor , ainsi que baisser le gpu  pour la batterie .
Apres tu peux aussi affiner mais bon c'est déjà la base .
Oui je prend les + grandes valeurs et après je régule avec l'appli.
Avec les reglagess vu plus haut :
49 % d' utilisation en 9h23. Avec 2h30 d'écran ouvert ,10 m de test GFXbrench (aux max ) et des applications /intenet.
Pas très révélateur dû à la modif en cour de journée...
  • 1 month later...
