drag/drop
vectoire
j'ai voudrais faire bouger une image sur l'écran .Quand je clique sur l'image j'ai réussi a la déplacer mais quand j'ai voulu l placer (faire le drop) elle disparaisse completement .Help please.Voici le code java.
package com.example.appdrag;
import android.app.Activity;
import android.content.ClipData;
import android.content.ClipDescription;
//import android.support.v7.app.ActionBarActivity;
import android.os.Bundle;
import android.util.Log;
import android.view.DragEvent;
import android.view.Menu;
import android.view.MenuItem;
import android.view.MotionEvent;
import android.view.View;
import android.view.ViewGroup;
import android.widget.ImageView;
import android.widget.LinearLayout;
import android.widget.RelativeLayout;
public class MainActivity extends Activity {
    ImageView img;
    String msg;
    private android.widget.RelativeLayout.LayoutParams layoutParams;
    @@override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        img=(ImageView)findViewById(R.id.imageView);
            img.setOnLongClickListener(new View.OnLongClickListener() {
            @@override
            public boolean onLongClick(View v) {
                ClipData.Item item = new ClipData.Item((CharSequence)v.getTag());
                String[] mimeTypes = {ClipDescription.MIMETYPE_TEXT_PLAIN};
                ClipData dragData = new ClipData(v.getTag().toString(),mimeTypes, item);
                View.DragShadowBuilder myShadow = new View.DragShadowBuilder(img);
                v.startDrag(dragData,myShadow,null,0);
                return true;
        img.setOnDragListener(new View.OnDragListener() {
            @@override
            public boolean onDrag(View v, DragEvent event) {
                switch(event.getAction())
                    case DragEvent.ACTION_DRAG_STARTED:
                        layoutParams = (RelativeLayout.LayoutParams)v.getLayoutParams();
                        Log.d(msg, "Action is DragEvent.ACTION_DRAG_STARTED");
                        // Do nothing
                        break;
                    case DragEvent.ACTION_DRAG_ENTERED:
                        Log.d(msg, "Action is DragEvent.ACTION_DRAG_ENTERED");
                        int x_cord = (int) event.getX();
                        int y_cord = (int) event.getY();
                        break;
                    case DragEvent.ACTION_DRAG_EXITED :
                        Log.d(msg, "Action is DragEvent.ACTION_DRAG_EXITED");
                        layoutParams.leftMargin = x_cord;
                        layoutParams.topMargin = y_cord;
                        v.setLayoutParams(layoutParams);
                        break;
                    case DragEvent.ACTION_DRAG_LOCATION  :
                        Log.d(msg, "Action is DragEvent.ACTION_DRAG_LOCATION");
                        break;
                    case DragEvent.ACTION_DRAG_ENDED   :
                        Log.d(msg, "Action is DragEvent.ACTION_DRAG_ENDED");
                        // Do nothing
                        break;
                    case DragEvent.ACTION_DROP:
                        Log.d(msg, "ACTION_DROP event");
                     /* ClipData.Item item = new ClipData.Item((CharSequence)v.getTag());
                        v.startDrag(dragData, myShadow, img, 0);*/
                        // Do nothing
                        break;
                    default: break;
                return true;
        img.setOnTouchListener(new View.OnTouchListener() {
            @@override
            public boolean onTouch(View v, MotionEvent event) {
                if (event.getAction() == MotionEvent.ACTION_DOWN) {
                    ClipData data = ClipData.newPlainText("", "");
                    View.DragShadowBuilder shadowBuilder = new View.DragShadowBuilder(img);
                    img.startDrag(data, shadowBuilder, img, 0);
                    img.setVisibility(View.INVISIBLE);
                    return true;
                else
                    return false;
    @@override
    public boolean onCreateOptionsMenu(Menu menu) {
        // Inflate the menu; this adds items to the action bar if it is present.
        getMenuInflater().inflate(R.menu.menu_main, menu);
        return true;
    @@override
    public boolean onOptionsItemSelected(MenuItem item) {
        // Handle action bar item clicks here. The action bar will
        // automatically handle clicks on the Home/Up button, so long
        // as you specify a parent activity in AndroidManifest.xml.
        int id = item.getItemId();
        //noinspection SimplifiableIfStatement
        if (id == R.id.action_settings) {
            return true;
        return super.onOptionsItemSelected(item);
