kuan Posté(e) 27 mars 2016 Share Posté(e) 27 mars 2016 (modifié) Je viens de découvrir un outil "tout-en-un" réalisé par Magdag (une grosse pointure chez Xiaomi). Il m'a l'air franchement intéressant (pour les "novices" et les autres) et comporte plusieurs sections : déblocage du Bootloader, installation du root, TWRP, etc. Je vous laisse le découvrir (j'ai refait les captures d'écran car on ne les voyait pas très bien sur son fil). Le fil sur en.miui.com http://en.miui.com/thread-246711-1-1.html Redmi Note 3 ToolKit (SnapDragon) Updated V4.0 It has bunch of features like : Install Adb Drivers Root via ADB Sideload EFS Tool for One Click Backup /Restore EFS Cracked / Modified Boot.img to save from Bootloop Custom (Twrp 3.0) / Stock Recovery via Both ADB and Fastboot Bootloader - Status , Unlocking via Mi Flash Unlock Tool , Re-lock Added Check conditions on locked Bootloader device trying to Flash Twrp. Couple of things like Reboot to Fastboot , Recovery , system via ADB and Fastboot Automatic Update , which checks for new update and Download it when New Update is available. Bootloader Tool Here , you can reboot you device to Fastboot via ADB with just one button click. Once in Fastboot mode you can Unlock Redmi Note 3 Bootloader via Stock Mi Flash Unlock Tool. You should Know that you Still need Unlock permissions to unlock device . you should apply with the same Mi Account as used in you phone here ( www.miui.com/unlock/apply.php ).After you get Unlock permission, which takes about 10-15 days ( you get a sms to registered Phone number ) you can unlock via this tool . You Need Internet Connection to Unlock Bootloader of the device.Relock Redmi Note 3 if you wish to reload the bootloader.You Can also check the Current Status of your bootloader, where it is unlocked or locked . Twrp /Stock Recovery tool Here You can Flash both Twrp 3.0.0-0 and Stock Recovery via both ADB or Fastboot , just choose the option and press Flash. After Flashing Recovery , phone stays at Fastboot , so that you can Flash the Cracked Boot.img .So, as you completed Flashing recovery , press Cracked Boot.img Button . It will take you to next page,where you can Download the Appropriate Boot.img version same as your MIUI ROM version. This is Very Important - Flashing wrong boot.img will Cause BootLoop and Loss Of WiFi connectivity . The Boot.img are uploaded to server as New Roms are released. Cracked Boot.img Download and Flash Tool Here , you can Download the appropriate boot.img version same as your MIUI ROM version and flash it. After downloading the boot.img , press Flash button which opens a Dialog box - Browse to the downloaded Boot.img and select it and press OK to Flash it .This is Very Important - Flashing wrong boot.img will Cause BootLoop and Loss Of WiFi connectivity Boot.img are uploaded to server as New Roms are released. Phone Should be On Fastboot Mode Only and Internet connection is Needed to Download the boot.img file. Rooting Tool Here , you can root you Redmi Note 3 using ADB connection Only . TWRP must be flashed Before trying to root . Now, Connect the phone via ADB. Then Press reboot to Recovery button , it will reboot to TWRP recovery . Then go to Options and enable ADB sideload Option . Then Press Root Via Adb Sideload button . You can also download the root.zip ( Link available on the tool ) and copy it to Phone's Internal / SD card storage and reboot to recovery and install the zip . Credits to Chainfire for the Root zip. EFS TOOL Well, this is the new addition on V2.0 .This tool helps to generate EFS backup ( IMEI/Baseband ) and restore it when you loose it . You need to be Rooted to use the Automated Tool. Its one click tool . easy to use . Le fil sur en.miui.com http://en.miui.com/thread-246711-1-1.html Modifié 9 septembre 2016 par kuan 3 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jweb Posté(e) 30 mars 2016 Share Posté(e) 30 mars 2016 Kuan, tu penses que cette méthode est plus facile que la tienne ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
quent13476 Posté(e) 12 avril 2016 Share Posté(e) 12 avril 2016 Pas plus de retour sur cet outil ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BooKi Posté(e) 19 août 2016 Share Posté(e) 19 août 2016 Quelqu'un a-t-il essayer ? Qu'en pensez vous ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
guigus76 Posté(e) 9 septembre 2016 Share Posté(e) 9 septembre 2016 bonjour, pas possible de telecharger les liens sont down ou renvois sur des sites frauduelux Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kuan Posté(e) 9 septembre 2016 Auteur Share Posté(e) 9 septembre 2016 Il faut prendre le lien du fil original pour se procurer les bons liens à jour Le fil sur en.miui.com http://en.miui.com/thread-246711-1-1.html Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
