ALILOVIC Posté(e) 2 avril 2016 Share Posté(e) 2 avril 2016 (modifié) HI every one I'm new in this, and I have some question that I hope you guys can answer me here.i have an LG3 G3 i bought from ITALY Model: LGD855Suffix: A6TITNCountry: 6TI/TIM(ITALY) I search for a marshmallow Firmware for my device using my IMEI number but the last version I found was the D85520n_00.kdz (lollipop 5.0) so why there is no marshmallow for my device !! is there any Firmware compatible with my device so I can do it manually? and if yes is there any issue after the upgrade? Modifié 2 avril 2016 par ALILOVIC Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Praxium Posté(e) 7 avril 2016 Share Posté(e) 7 avril 2016 (modifié) Hi @@ALILOVIC, This is a french forum this means you must speak french there. You can always flash it yourself using the kdz flash method via flash tools or recovery I notice you've received reply on XDA too : http://forum.xda-developers.com/lg-g3/general/lg-g3-android-marshmallow-discussions-t3216143/post66165275#post66165275 Cheers, Modifié 7 avril 2016 par Praxbe 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
