[XPOSED][MODULE][MM] G4 TweaksBox (1.6.1)
G4 TweaksBox
59bc98436623094.jpg 779ff7436623108.jpg 9dd5a3436623127.jpg 4f8916436623145.jpg c59863436623170.jpg a30d5d436623202.jpg 4d1a34436623233.jpg adc8f7436623249.jpg 02759d436623292.jpg
Some Features:
Theme tweaks
  • Themes support
  • Tinted Bar MOD
Status Bar Tweaks
  • Battery tweaks(color,size,hide)
  • Circle Battery(with custom style,color,animations)
  • Status bar icon colors
  • Hide status bar icons
  • Clock tweaks(position,color,style,html,hide)
  • Carrier tweaks(visibility,color,custom text,custom size)
  • Brightness changing with sliding the status bar
Navigation Bar Tweaks
  • Softkey themes support
  • Button color on home screen
  • Button glow color
  • Navigation bar size
  • Button scaling
  • Button long pressing actions(with many actions and custom timeout)
  • Up to 7 buttons in the navigation bar
  • Replace QMemo with Menu button
Notification Panel Tweaks
  • Blur Effect
  • Custom panel backgrounds
  • Custom color for each element
  • Options to hide elements
  • Custom app on clock button pressing
  • Custom carrier text
Quicksettings Panel Tweaks
  • Custom toggle color
  • Add brightness tile
  • Quick Pulldown
Recent Apps Window Tweaks
  • Blur Effect
  • Hide buttons
  • Add Clear button(Material style with a long pressing option)
  • Add Ram Bar(with custom colors)
Calls tweaks
  • Call Recording
  • Auto Call Recording
  • Bigger caller picture
  • Set Call History as Default Tab
  • Disable in-call floating timer
Messages tweaks
  • Exclude contacts without phone numbers in messaging app option
  • New Message screen off option
  • Increase recipient limit to 100
  • Enhance zoom range
  • Add sent time stamp to msg details
  • Custom theme color
Lockscreen tweaks
  • Enable QuickUnlock
  • Enable all weather effects
  • Enable Rotation
  • Disable carrier text and icon
  • Hide alarm info
  • Hide charging info
  • Hide pattern string
  • Hide swype string
  • Hide Knock code string and brackets
  • Hide statusbar clock
  • Show Remaiming Attemps
Notification tweaks
  • Hide input switcher notification
  • Disable charging plug/unplug notifications
  • Hide full battery notification
  • Hide AC charging notification
  • Hide slow charging notification
  • Hide wireless charging notification
  • Hide Battery saver notification
  • Hide Low Battery Dialog
  • Hide Airplane Mode Dialog
  • Disable Data roaming notification and popup
  • Disable voice mail notifications
  • Disable voice roaming notification
  • Disable data nag dialogs
Camera Tweaks
  • Disable Shutter Sound
  • Disable Video Recording Sounds
  • Disable Camera Sound
  • Disable Focus Sounds
  • Disable low battery check
Sound tweaks
  • Disable Safety HeadSet Volume
  • Auto Expand Volume Panel
  • Skip Tracks with volume Keys
  • More Volume Steps
  • Disable Volume adjust sounds
  • Link Ringtone and notification volume
  • Force volume media control
LED Tweaks
  • Change default led color for missed call
  • Change default led color for incoming call
  • Change default led color for missed messages
Launcher Tweaks
  • Hide icon labels from the homescreen
  • 8 Hotseat items
  • Custom Grid on homescreen
  • Hide Tabs on App Drawer
  • Hide icon labels from the App Drawer
  • Custom Grid Size on App Drawer
  • Hide Clock On Launcher
  • Enable LG Launcher Hidden Settings
Misc tweaks
  • Enable All Rotations
  • Freeze rotation to the current one(disable forced rotation to potrait when you disable auto rotation)
  • Disable Navigation Bar
  • More items in powermenu
  • 4Way powermenu
  • Disable the power menu when device is locked
  • Volume button actions while LCD is idle.
  • Show Extended Kernel Info
  • Disalbe full-screen keyboard in landscape mode
  • Enable Knock OFF on Navigation Bar
INSTALLATION
1)Télécharger & Installer Xposed Framework(Flash via recovery or use Flashfire)
2)
Télécharger & Installer  l'apk
3)Activer le module dans xposed installer
4)Redemarrer
5)Ouvrir G4 TweaksBox et appliquer les mods que vous souhaitez
6)Redemarrer le téléphone
5)Done
CREDITS:
Rovo89 for his hard work
C3C076 of gravitybox for: some snippets for brightness status sliding, ticker animations hooks,the method to retrive the cm battery height , the runnable to get ram info
Sven Dawitz of CM for circle battery class
TELECHARGEMENT
UNIQUEMENT POUR MARSHMALLOW
Source
Modifié par LudoG4
Juste une petite question le Module G4 TweaksBox est bien payant pour débloquer certains Tweaks ????  ou il est passer en gratuit ????
Parce que l'un des Tweaks qui pour moi était intéressant étant le redémarrage avancé sans passer par l'applis QuickBoot mais c'est payant pour l'avoir :( après il me semble qu'il n'y a pas que sa de payant ducoup vaut mieux passer par GravityBox Non ?
Je dis sa mais sa fait un moment que j'ai pas réinstaller ce modules la .....
Modifié par Renaf
En ce moment je n'utilise ni l'un ni l'autre....donc bon ^^ mais oui c’était payant y a 1 mois .
Merci pour le post LudoG4  B)
Modifié par herveonex
Oui oui payant !
J'ai payé.. je trouve ça tellement utile.
Ce qui m’intéresse le plus moi c'est:
- Désactiver le son lors de la prise de photo ([color=red]jsuis[/color] un paparazzi à mes heures perdus)
- Centrer l'heure
- Pouvoir enregistrer les appels
- Pouvoir changer de musique avec les boutons volumes (ça me sert énormément +++++ avant que Cyano géré ça)
- Avoir la date exacte de l'envoi des messages reçu
Et c'est tout je crois.
Modifié par LudoG4
Ben effectivement sous stock l'applis semble très convainquante en version pro mais je la trouve un peu cher pour ce que c'est et si je change de smartphone pour un Samsung l 'applis deviens inutile donc je ne préfère pas mettre la main au portefeuille ;)
oui c'est sûr
mais étant en intérim (je ne finis jamais mes mois) pour moi 3 €uros c'est beaucoup alors si je peux avoir 3 euros en fin de mois autant te dire que je vais pas les mettre dans une apps mais dans la bouffe ou les charges :)
DSL pour le hors Sujet et le raconte ma vie.com
Après je dis pas si un jour j'ai les moyens de le faire je l'acheterais :)
Modifié par Renaf
Je juge pas Renaf t'inquiète mais pour moi ça me parait dérisoire ..
Après je vie chez mes parents et j'ai un fixe chaque mois...
Bref tfaçon on peut la "trouver" sur Internet je crois ;) Mais moi je l'ai acheté car je la trouve top :)
Chacun à ses priorité ;)
Moi c'est la vape et une loi qui s'applique le 21 mai en france [TPD] qui me dit : refume des clopes l'état est en manque .
Enfin tout ca bien sur après mes momes qui eux ne savent pas encore ce que vaut réellement 3 ou 30 euro ^^
Désolé pour ce big HS : )
Merci de ta compréhension ;)
T'Inquiete pas pour tes momes herveonex sa fait pas si longtemps que sa que je comprend la valeurs de l'argent et encore ... et je suis même pas sur que le meilleur économiste au monde connaissent vraiment la valeur de l'argent .... :)
Avant j'aurais pu acheter la version pro de ce module xposed mais sa c'etait quand j'étais chez mes parents ou quand j'avais encore un CDI mais depuis cette loi macron de m**** je suis devenu interimaire lol
Modifié par Renaf
Il met arrivé plus d'une fois d'acheter des applis (ex tapatalk VIP) pour moi ou et surtout pour encourager les dev de rom ou kernel mod etc .
Je trouve le processus saint et bénéfique à la différence du monde de la pomme ou tout etait payant .
Envoyé de mon LG-H815 en utilisant Tapatalk
