Root and Recovery
Samrazzy
Here is how to install twrp on LG K7.
Do you want to install Custom Recovery on LG K7 ? Here is our full guide on How to Root and Install TWRP Recovery on LG K7. TWRP Recovery is a Custom Recovery which is also known as TeamWin Recovery built with a touchscreen-enabled interface which allows users to install third-party firmware and backup the current system, which are often unsupported by stock recovery images. This Guide is recommended only to try on LG K7 with model MetroPCS (lgms330) and the T-Mobile (lgk330) models. So please try only on MetroPCS (lgms330) and the T-Mobile (lgk330) models.
This is a guide to Install latest TWRP for LG K7. This is a guide to Install latest TWRP 3.0.2.1 for LG K7 . The TWRP 3.0.2.0 Recovery has a material design, so Now you can install TWRP 3.0 for LG K7 . Download the TWRP Recovery 3.0.2.1 for LG K7 with model MetroPCS (lgms330) and the T-Mobile (lgk330) models and Read the steps below. Download the Install TWRP Recovery on LG K7 with lgms330 and lgk330 today and Read the steps below. This is not an official TWRP Recovery for LG K7. But you can install the unofficial now. If you install any Custom Recovery on LG K7, you can install Custom ROM, Custom Mods, Custom Kernels or any zip file such as Xposed. Read the guide carefully on How to Root and Install TWRP Recovery on LG K7.
Team Win Recovery Project (TWRP), is an open-source software customrecoveryimage for Android-based devices. It provides a touchscreen-enabled interface which allows users to install third-party firmware and backup the current system, which are often unsupported by stock recoveryimages. – WIKI
PRE-REQUISITE TO ROOT AND INSTALL TWRP RECOVERY ON LG K7
  • This Guide is for How to Root and Install TWRP Recovery on LG K7 with lgms330 and lgk330
  • You need either Laptop or PC
  • Download Chainfire SuperSU.zip
  • Charge your phone to at least 70%
  • Back up your device just in case if you need it later
  • Download Minimal ADB Tool – CLICK HERE or Download the Full ADB setup for Windows / Mac here  and Extract it.
  • Download TWRP and Copy it to extracted ADB and Fastboot Tools Folder
  • Make sure you have followed the steps properly. Don’t Skip and Read ! – We are not responsible for any damage that you make to your phone.
STEPS FOR How to Root and Install TWRP Recovery on LG K7.
    • First of all enable the USB Debugging
    • To Enable the USB Debugging you need also active the developer option, Now Go to your Settings -> About Phone -> Now Tap on the Build Number 7-8 Times until you see a toast message “Developer option enabled“ activate developer option lg
    • Once your developer option is active, Go back to your settings -> Open developer option -> Enable USB Debugging
    • Unlock the OEM by settings -> Open developer option -> Enable OEM Unlockingusb oem LG
  1. Now on your PC/Laptop, Open the extracted ADB Folder and Open Command Window by pressing Shift Key + Right Mouse Click Root and Install TWRP Recovery on Elephone Trunk
  2. Now connect the PC to Mobile with USB Cable
  3. You need to Reboot the phone into Bootloader – Type the Command from below in your Command window that you opened
    adb reboot bootloader
  4. Your device will boot into bootloader, If it don’t check if your cable or drivers working properly. Now type the below command in your command window
    fastboot devices
  5. To flash the recovery, Type the command
    fastboot flash recovery twrp-image-3.img
  6. Root and Install TWRP Recovery on Elephone TrunkNow if it shows the command like this then reboot your device. TWRP has successfully installed. Enjoy
  7. TO REBOOT INTO RECOVERY, TURN YOUR PHONE OFF, PRESS VOLUME UP + POWER BUTTON TOGETHER TO ENTER RECOVERY. TWRP recovery
HOW TO ROOT LG K7 WITH TWRP RECOVERY
  • You may have downloaded the SuperSu zip file from the section above PREREQUISITE, If not – CLICK HERE to Download SuperSU
  • Now move the SuperSu zip file to the root of your internal memory
  • Boot your phone into recovery by pressing “Volume Down + Power” button simultaneously.
  • In TWRP Recovery, Click the INSTALL menu and Browse and Select the SuperSu Zip
  • Now Swipe to Install SuperSu
  • Yes, Now the root must be working if you properly installed the Kingroot
  • To verify, Go to Google Play and download the Root Checker app to check the root status. If root checker app says root access available then Enjoy you have root on your LG K7
