Kernel Radon 4.0 (kenzo/kate) pour MIUI 8 et CM/AOSP (MM/Nougat)
Le fil xda du kernel Radon http://forum.xda-developers.com/redmi-note-3/development/kernel-t3414884
Cpu Improvements -
  • New interactive and impulse cpu governors
  • Both impulse and interactive idle at 400mhz
  • Mild undervolt for both cpu and gpu, helps battery
  • Finely optimized impulse governor for kenzo
  • Frequencies are scaled properly based on load now
  • Fixed not able to set min cpu frequency of small cpu
  • Unlocked 1804mhz stable max frequency of msm8956
  • Wakeup boost, Hotplug boost, Touch boost
IO Improvements -
  • CRC32 hw accelarated module
  • Some optimizations for performance
  • Added fiops IO scheduler, use FIOPS or BFQ
  • Disabled IO crc check for more performance
Gpu/Display Improvements -
  • Adreno idler for better 19.2 mhz gpu idleing
  • Unlocked 133 mhz and 200 mhz for powersaving
  • Savoca's kcal color control, full control over colors
Charging/Battery Improvements -
  • Faster charging, full charge in almost 2 hr
  • Charge rate of stock charger has improved
  • Misc powersaving improvements
Other Improvements -
  • Compiled with stock aosp aarch64 toolchain
  • Powersuspend and faux's dynamic fsync
  • Default tcp congestion control is westwood
  • Enjoy new vibrator intensity control
  • NTFS, exFAT, F2FS filesystem support
Flashing Instructions -
  • Make backup of system, boot in twrp
  • Flash the kernel zip and reboot
Paramètres recommandés (se servir de Kernel Adiutor pour les modifications)
Recommended Settings -
Cpu -
  • Governor: Interactive for all kind of users (battery, balanced, gaming)
  • Frequency small cluster: 691-1440 (balance and gaming)
  • Frequency small cluster: 400-1440 (battery)
  • Frequency big cluster: 883-1804 (balance and gaming)
  • Frequency big cluster: 400-1804 (battery)
  • Interactive timer rate: 20000 (balance and gaming)
  • Interactive timer rate: 30000 (battery)
Memory -
  • ZRAM 256 for light miltitaskers, 512 for heavy multitaskers
  • ZRAM will increase battery consumption a little
  • Keep ZRAM off if you need extra battery backup
IO Scheduler -
  • FIOPS for good performance and battery
  • Read ahead 512 on both internal and external
Screen -
  • Adjust this yourself, I don't know what you like
Misc -
  • Dynamic Fsync - On for high performance, Off for better battery.
  • Vibration intensity - I use 65, select whatever you like here.
  • Powersuspend Mode - LCD Panel or Userspace (if you have slow wakeup problem)
Screen -
  • I use saturation intensity 45, set it to whatever value you like
  • I use screen value 129, set it to whatever value you like
  • I use contrast 138, set it to whatever value you like
Note - All settings are compatible with kernel adiutor mod.
_____________________________________________________________________________________
Downloads -
Downloads
Installation du kernel Radon
  • Téléchargez et copiez le kernel sur la mémoire interne ou la carte SD
  • Rentrez dans le TWRP Recovery
  • Cliquez sur Install
  • Pontez sur l'archive du kernel (Radon-V2.0-Kenzo-Miui.zip)
  • Il installe le kernel et vous pouvez redémarrer de suite après (pas besoin de faire un Wipe cache et Dalvik)
  • Au redémarrage, installez Kernel Adiutor depuis xda http://forum.xda-developers.com/android/apps-games/kernel-adiutor-mod-singularity-kernel-t3333549
  • Retournez sur votre bureau et cliquez sur l'icone "Sécurité" / Permissions / Démarrage automatique / Sélectionnez Kernel Adiutor (il est impératif qu'il soit en démarrage automatique pour la sauvegarde des paramètres au reboot). Capture n°2
  • Ouvrez Kernel Adiutor et donnez lui les droits root à la première ouverture
  •  Si vous voulez revenir à votre configuration précédente (kernel stock), soit vous restaurez un backup crée avec le TWRP, soit vous flashez la ROM qui est sur votre RN3P, par dessus (sans Wipe). Le kernel stock sera réinstallé automatiquement.
  • Il faudra réinstaller le kernel à chaque mise à jour de la ROM
  mini_436342Screenshot20160724154359137co   mini_394971Screenshot20160724170745676co    mini_466075Screenshot20160724154407758co    mini_510093Screenshot20160724154415262co   mini_168296Screenshot20160724170405252co    mini_283576Screenshot20160724153050189cc    mini_355743Screenshot20160724113828598co   mini_926741Screenshot20160720182837282cc
Kernel Adiutor  http://forum.xda-developers.com/android/apps-games/kernel-adiutor-mod-singularity-kernel-t3333549
Optionnel
3C Toolbox (partie CPU) https://play.google.com/store/apps/details?id=ccc71.at.free&hl=fr  (captures 6 et 8)
CPU Float (core en direct + d'autres infos - très pratique)  https://play.google.com/store/apps/details?id=com.waterdaaan.cpufloat&hl=fr
Perfmon (core en direct - capture n°7)  http://www.mediafire.com/download/uwiodzeext1d19q/PerfMon-v1.21.apk  (installation de Perfmon : copiez l'apk dans /system/priv-app et donnez les autorisations 644 -rw-r--r-- puis reboot).
Modifié par kuan
  • Like 4
Mise à jour du kernek Radon en version 1.7
 Changelog For CM/AOSP Version -
  • Rebased my kernel, more smoother than before
  • Unlock 133, 200 frequencies for gpu, user selectable
  • Adjusted adreno idler defaults for better responsiveness
  • Switched back to stock interactive cpu governor, smoother
  • Charging has improved, less aggressive thermal throttle
  • Attempt to fix noise on high senstivity earphones
  • Battery drop by 2% has been fixed now
Changelog For MIUI Version -
  • Fixed camera for everyone, front and back both
  • Charging has improved, less aggressive throttle
Read Before Flashing -
  • Miui version is only for lollipop, don't try on marshmallow
  • CM/AOSP does not work on santhosh cm13, don't complain
  • Read mode on miui doesn't work, use kcal, xiaomi's fault
  • To check your actual charge rate, check this post
  • Recommended settings are in 2nd post, read it
Downloads -
For CM/AOSP roms -
Radon V1.7 CM/AOSP
For MIUI LP roms -
Radon V1.7 MIUI
Modifié par kuan
Bon même avec la 1.8 j'ai la batterie bloqué à 50℅ c'est vraiment chiant car j'ai envie de la testé mais ne pas savoir où j'en suis niveau batterie pose vraiment problème
Envoyé de mon Redmi Note 3 en utilisant Tapatalk
Skulldead , xs3mt3ck
Ben pas pareil pour ma part ... J'ai fait la maj ce matin du kernel (version 1.7 à 1.8) après la maj via OTA de l'AICP (superbe ROM au passage) et là il est en train de charger et je suis à 75 %
Modifié par Saxo
@Saxo le problème ne provient pas de la rom, ni d'un flash non clean, mais des composants matériels qui diffèrent selon les Redmi Note 3 Pro et dont Xiaomi n'a pas forcément publié les sources ^^. Du coup il y en a pour qui tout fonctionne sur la dernière dev de Miui, et d'autres non :/.
Avec la version 1.6 certains avaient des problèmes avec la caméra et le fingerprint, ce qui n'était pas mon cas :).
Envoyé de mon Redmi Note 3 Pro ;).
Update Radon V1.8 -
  • Switched back to my old kernel source (Same as V1.6), has better battery backup
  • Interactive governor is totally stock for hardcore interactive governor users
  • Brought back darkness governor, for extreme battery users who don't mind minor lag
  • Brought back vibration intensity controls which was missing in my V1.7
  • Little more undervolt for 400 mhz cpu frequency, check updated 2nd post
  • Undervolted cpu frequencies 400, 691, 883 for better battery backup
  • Darkness governor for extreme battery biased users
  • Misc performance and IO improvements
Important Information -
  • Dt2w is not stable for everyone, So I'll not add it in my stable kernel builds, I might give Dt2w testing version later, don't ask for it.
  • Radon is not booting yet on Santhosh cm13 yet, I'm working on it, till then you can try my cm13, link is there in my signature.
  • I have updated recommended settings for V1.8 in 2nd post, you can check that for smooth performance with good battery backup.
Downloads -
Radon V1.8 CM/AOSP
Radon V1.8 MIUI
Cpu -
  • Frequency big cluster 883 mhz - 1804 mhz
  • Big cluster governor Impulse
  • Frequency small cluster 400 mhz - 1440 mhz
  • Small cluster governor Impulse
  • Touch boost : I keep this on, makes scrolling smooth
  • Hotplug boost, wakeup boost, I keep both of them off
IO Scheduler -
  • BFQ for good performance
Screen -
  • I use saturation intensity 40(+10), select whatever you like here
Misc -
  • Vibration intensity - I use 75, select what you like
  • Dynamic Fsync - I keep it on only
  • Powersuspend Mode - Hybrid
Modifié par kuan
Changelog For CM/AOSP -
* Fixed batterymeter stuck at 2% or 50% for users with new hardware, thank you @alex9yust
* Enabled missing livedisplay features (reduce power consumption, color enhance, outdoor mode)
* Properly enabled CONFIG_HZ_300 for better responsiveness, default tick rate is 300 now
* Tweaked entropy values keeping power conservation in mind, read value 256 write value 512
* Removed gpu frequencies 133 and 200, min is now 19 on idle and 266 on touching screen for better responsiveness
* Instead of underclocking, gpu frequencies are now undervolted for good performance and less power consumption
* Fixed the invert screen option not working in screen section of kernel adiutor
Changelog For MIUI -
* Tweaked entropy values keeping power conservation in mind, read 256 write 512
* Gpu frequencies are now undervolted for good performance and less power consumption
* Not able to change min small cpu frequency is a kernel adiutor bug, try kernel adiutor mod or some other app
* Working/Not Working list is properly maintained in 1st post, always read 1st post before asking questions
* Recommended settings are always up to date in 2nd post, always check that for good battery with smooth performance
Downloads -
Radon V1.9 CM/AOSP
Radon V1.9 MIUI
Sent from my Xiaomi Redmi Note 3 Pro *.*.
@Fushi
Je suis sur la Mokee, et cela marche avec quelques ajustements:
- désactiver le verrouillage de l'écran, sinon impossible d'arriver sur le bureau après redémarrage, ou sinon (voir la FAQ), supprimer les fichiers .key dans /data/system dans le file manager de TWRP;
- il faut flasher les fichiers modems/radios afin de pouvoir réactiver, notamment, le fingerprint.
Sinon, toujours faire une sauvegarde complète dans TWRP, version alka pour moi, cela peut aider si on veut retourner sur la version kernel de la ROM (restaurer seulement la partition boot).
Modifié par barrjean
Avec la dernière maj de Kernel Adiuor impossible de baisser la fréquence mini sur 400.
J ai trouvé ça cette info pour y remédier :/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
And replace 400000 by 691200 ... Mais comment enregistrer modifier le fichier ?
Modifié par sylford
Petit retour sur le Kernel Radon 1.9 :
Après le "Reboot system" dans TWRP tout fonctionne parfaitement, mais après un redémarrage le FingerPrint ne fonctionne pu.
Donc je suis revenu sur la version 1.8 avec le fix d'indicateur de batterie, tout fonctionne parfaitement avec Kernel Adiutor Mod pour permettre d'avoir en fréquence minimum 400Mhz ^^.
* Just a small stability update to fix reboots for some users
* Back to aosp aarch64 toolchain for the sake of stability
* Removed gpu UV and bring back 133 and 200 mhz UC
* Removed gpu UV for the sake of stability
Downloads -
Radon V2.0 CM/AOSP
Radon V2.0 MIUI
Thanks to @yog12 for a lot of testing whenever I needed.
