Dishen Posté(e) 18 août 2016 Share Posté(e) 18 août 2016 I tried to Flash Custom Rom to my Huawei Mate S. Now phone does not on. So i want to go back to Stock Rom.. Can any one please give me Stock Rom.. and.. can i use Sp Flash tool? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mashik Posté(e) 19 août 2016 Share Posté(e) 19 août 2016 I think that you had better use Sp tool because it is simple and Huawei Mate S new Stock Rom is MTK Device 1. you should charge your device up to 50% 2. enable USB debugging and developer. 3, remove battery and connect your phone to PC 4.Download Sp tool and Stock Rom 5, Open SP tool. Locate the catter file. 6. Click the Download icon then it will start Flashing Download required files Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
