LeEco Cool1 - 5,5" FHD - Snapdragon 652 / 32GB / 64GB de ROM - 3/4Go RAM
Wandy77
NETWORK Technology GSM / CDMA / HSPA / LTE
LAUNCH Announced 2016, August
Status Available. Released 2016, August
BODY Dimensions 152 x 74.8 x 8.2 mm (5.98 x 2.94 x 0.32 in)
Weight 167 g (5.89 oz)
SIM Dual SIM (Nano-SIM, dual stand-by)
DISPLAY Type IPS LCD capacitive touchscreen, 16M colors
Size 5.5 inches (~73.3% screen-to-body ratio)
Resolution 1080 x 1920 pixels (~401 ppi pixel density)
Multitouch Yes
  - EUI 5.6
PLATFORM OS Android OS, v6.0 (Marshmallow)
Chipset Qualcomm MSM8976 Snapdragon 652
CPU Octa-core (4x1.2 GHz Cortex-A53 & 4x1.8 GHz Cortex-A72)
GPU Adreno 510
MEMORY Card slot No
Internal 32 GB, 3/4 GB RAM or 64 GB, 4 GB RAM
CAMERA Primary Dual 13 MP, f/2.0, phase detection autofocus, dual-LED (dual tone) flash
Features Geo-tagging, touch focus, face detection, panorama, HDR
Video 2160p@30fps, 1080p@30fps, 720p@120fps
Secondary 8 MP, f/2.2, 1.4 µm pixel size, 1080p
SOUND Alert types Vibration; MP3, WAV ringtones
Loudspeaker Yes
3.5mm jack Yes
  - Active noise cancellation with dedicated mic
COMMS WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
Bluetooth v4.1, A2DP, LE
GPS Yes, with A-GPS, GLONASS, BDS
Radio To be confirmed
USB Type-C 1.0 reversible connector
FEATURES Sensors Fingerprint, accelerometer, gyro, proximity, compass
Messaging SMS (threaded view), MMS, Email, Push Email
Browser HTML5
Java No
  - Fast battery charging: 50% in 30 min (Quick Charge 2.0)
- Xvid/MP4/H.265 player
- MP3/WAV/eAAC+/FLAC player
- Document viewer
- Photo/video editor
BATTERY   Non-removable Li-Ion 4060 mAh battery
MISC Colors Gold, Silver, Rose Gold
Sur le papier il a l'air intéressant, mais que vaut-il en situation réelle. Bien que le disign n’évolue pas, je suis très intéressé par ce modèle, donc je vais attendre des tests qui devraient arrivés dans les prochaines semaines. Mais il y un autre modèle qui a attiré mon attention c'est le QIKU 360 Q5 ou Q5 plus, par contre pour ce modèle je ne sais pas où je pourrais me le procurer et de toute façon j'attends avec impatience des tests pour me faire une opinion personnelle.
Quelques tests en anglais :
Test de Compsmag
Comparaison des APN avec le Xiaomi Redmi Pro
Test de ChinaDeals
A priori beaucoup de positif dans ce que je lis, j'aimerais toutefois pouvoir lire un test réalisé par un site connu et français
Quelqu'un l'a déja commandé sinon ?
Salut.
Le paiement via PayPal amène une sécurité en cas de pb de non réception.
J'ai vu sur un autre forum que quelqu'un a commandé sans pb sur ce site.
Savez vous si le root est déjà possible sur le tel?
Et apparemment pas encore de roms multi langue (juste en/cn ), contrairement a ce qui est marqué sur le site.
Sent from my Letv X500 using Forum mobile app
  • 2 months later...
J'ai le Coolpad 1 en 5.5" version 64 Gb, je l'ai principalement acheté pour le travail afin de mettre la sim boulot (suisse) + perso (francais) dedans, pas de soucis, c'est 1 tres bon fone qui rend très bien service, et l'autonomie est hallucinante, meme en utilisation intense !
Si jamais quelqu'un est interessé je vais surement le vendre pour aller vers le Mate 9 our one plus 3T pour tester.
Quoi qu'il en soit, je recommande ce tel pour son coté qualité prix imbattable !
Modifié par smile68
Pour info, je vais le vendre dans les 150 € il a 1 mois 1/2 et etat neuf, en gold (qui est en fait plus proche de l'argenté). Pas de rayures, pas de pocs...nada...
C'est la version 64 Gb, MP si interessé, tous les accesoires d'origine,boite, et facture fournis
Infos interessante pour la Custom Rom :
http://www.sadroid.com/cm-14-android-nougat-7-1-rom-for-leeco-cool1-dual/
Modifié par smile68
