Derek182 Posté(e) 5 janvier 2017 Share Posté(e) 5 janvier 2017 (modifié) Sujet original sur xda : https://forum.xda-developers.com/lg-g3/development/rom-crdroid-t2955012 CyanogenMod n'est plus, mais est remplacée LineageOS sur laquelle est basée crDroid (ou du moins les tout derniers travaux de l'équipe Cyanogen). Je n'ai pas encore testé la rom, mais c'est pour bientôt vu les retours positifs. LineageOS - Liste des mods et ajouts : StatusBar: Network TrafficStatusBar: SU icon toggleStatusBar: TickerStatusBar: Hide/Show iconsStatusBar: BatteryBar customizationStatusBar: Battery stylesStatusBar: Tap to SleepStatusBar: Clock stylesStatusBar: crDroid logo customizationQuickSettings: Tiles customizationQuickSettings: Brightness slider toggleQuickSettings: Optional brightness iconQuickSettings: Vibrate on TouchQuickSettings: WiFi easy toggleQuickSettings: Bluetooth easy toggleQuickSettings: Data easy toggleNavigation: Toggle navbarNavigation: PIE navigationNavigation: DUI - SmartBar / Fling ToggleNavigation: Pulse - smart visualizationNotifications: Power notification controlsNotifications: Force expanded notificationsNotifications: Toggle immersive mode messagesLockScreen: Screen shortcutsLockScreen: Toggle longpress for screen shortcutsLockScreen: Swipe shortcutsLockScreen: Toggle media cover artLockScreen: Toggle clockLockScreen: Toggle dateLockScreen: Toggle alarmLockScreen: Tap to sleepLockScreen: Toggle longpress torchLockScreen: Cutomize number of notificationsLockScreen: Toggle power menu for secure lockscreenRecents: Immersive RecentsRecents: Hidden appsRecents: Toggle OmniSwitch as default RecentsSound: Toggle screenshot soundSound: Live customization for number of volume stepsSound: Less frequent notification soundsMiscellaneous: Clock WidgetMiscellaneous: Toggle suggestions on Settings dashboardMiscellaneous: Toggle summaries in SettingsMiscellaneous: Toggle auto-start music player on headset detectionSettings/Display: Expanded Desktop customizationSettings/Sound: Increasing Ringtone12 New Quick Settings Tiles including Caffeine mode, Expanded Desktop and Sync.Settings/Security: Quick PIN/Password UnlockDefault sounds from latest Nexus image.Stability and performance improvements.OMS Substratum support. Avant l'installation, faites un full backup, juste au cas où c'est toujours plus sur. Téléchargement : - pour la version Européenne D855 - Autres versions - OpenGAPPS (7.1.1, micro ou mini) La ROM est déjà rootée, pas besoin de flasher de SuperSU. Avant d'installer la Rom assurez vous d'avoir le bon modem (21C) compatible avec Android Nougat, sinon vous pouvez le télécharger et le flasher normalement via TWRP : http://www32.zippyshare.com/v/Ub9TXvYN/file.html Dans le doute, faite le. Première installation : - Avoir un custom recovery installé (TWRP ou CWM) - Copier les GAPPS et la ROM crDroid sur votre carte SD - Redémarrer en mode Recovery - Wipe system, data et cache (faites un backup avant !) - Flasher la ROM - Flasher les GAPPS - Faire un Wipe Data/factory Reset - Redémarrer Mise à jour depuis une précédente version de crDroid : - Copier la ROM sur votre carte SD - Redémarrer en mode Recovery - Faire un wipe system et cache - Flasher la ROM - Flasher les GAPPS - Redémarrer ENJOY Ne pas flasher de kernel custom par dessus la ROM, elle dispose déjà du sien avec ses tweaks. Si vous souhaitez tout de même en flasher un il doit être compatible avec LineageOS. Merci à tgauville pour nous avoir fait découvrir cette ROM. Modifié 15 janvier 2017 par Derek182 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tgauville Posté(e) 6 janvier 2017 Share Posté(e) 6 janvier 2017 @Derek182 Merci à toi pour l'ouverture de ce sujet, comme tu le sais je suis utilisateur de cette rom depuis la version 1.5 et c'est que du bon. Perso j'utilise les Gapps pico et le launcher Google Pixel, très fluide et pour moi la batterie tient bien mais je ne suis pas un gros utilisateur de mon Tél, pas de jeux, video, ou réseaux sociaux juste les basiques appels, sms et messagerie, Bluetooth, Gps et données actifs que si besoin Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
phileg Posté(e) 6 janvier 2017 Share Posté(e) 6 janvier 2017 Est ce que tout les connexions fonctionnent bien ? wifi, BlueT... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tgauville Posté(e) 6 janvier 2017 Share Posté(e) 6 janvier 2017 Pour moi Wifi ok et Bluetooth dans véhicule ok Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
phileg Posté(e) 6 janvier 2017 Share Posté(e) 6 janvier 2017 Je viens de l'installer et effectivement tout est ok niveau connexion. Wifi très rapide et le bluetooth fonctionnent du premier coup. Mieux de AICP du coup avec autant d'options, juste le Pie control un peu limité. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
phileg Posté(e) 6 janvier 2017 Share Posté(e) 6 janvier 2017 Le seul "problème" est le dièse du binarie qui s'affiche en haut comme sur toutes les rom 7.1.1... en attente d'une mise à jour sans doute. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tgauville Posté(e) 6 janvier 2017 Share Posté(e) 6 janvier 2017 @phileg Dans Paramètres / crDroid settings / Status bar / Enable SU icon 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
phileg Posté(e) 6 janvier 2017 Share Posté(e) 6 janvier 2017 a oui !!! ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Derek182 Posté(e) 7 janvier 2017 Auteur Share Posté(e) 7 janvier 2017 (modifié) Rom installée ! Mais elle est géniale ! Des trucs tout bêtes que j'attendais de voir depuis longtemps, surement que d'autres le font aussi mais j'en attendais autant d'un rom CM : une navbar dynamique, la taille paramétrable c'est du déjà vu, mais la couleur de la navbar en fonction des applis OUI ! Enfin lol. Marre de cette barre toujours noire (ou blanche) alors que la statut bar change elle. Bref des tas d'options et de paramètres pour faire mumuse, à découvrir *_*. Et super fluide ! Bon y'a aucune apps en même temps, pour l'instant... Modifié 7 janvier 2017 par Derek182 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
phileg Posté(e) 7 janvier 2017 Share Posté(e) 7 janvier 2017 J'ai une centaine d'appli et toujours fluide. Pas de perte de réseau non plus, consommation de la batterie normal, wifi très rapide... aucun plantage ou reboot. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tgauville Posté(e) 8 janvier 2017 Share Posté(e) 8 janvier 2017 j'ai essayé brièvement presque toutes les roms en 7.1.1 basées sur CM / LOS ( Xenon, Resurection remix, AICP, CypherOs, N&N, etc... ) et pour moi la crDroid est de loin la meilleure Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Derek182 Posté(e) 8 janvier 2017 Auteur Share Posté(e) 8 janvier 2017 J'ai des force close avec l'application Amazon. C'était déjà le cas sur CM14, mais je mettais ça sur le dos d'une installation pas clean. Ici avec crDroid j'ai fait le plus clean possible et j'ai toujours ces FC. Parfois ça fait reboot le tel. Quelqu'un d'autre a ce genre de soucis ? Envoyé de mon LG-D855 en utilisant Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tgauville Posté(e) 9 janvier 2017 Share Posté(e) 9 janvier 2017 Pas de soucis avec l'appli Amazon ( boutique Amazon ) ou Amazon Underground personnellement Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
phileg Posté(e) 9 janvier 2017 Share Posté(e) 9 janvier 2017 Pas installé.. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fab51 Posté(e) 10 janvier 2017 Share Posté(e) 10 janvier 2017 rom installée ce soir, tout va bien a part la traduction.... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bundy12 Posté(e) 10 janvier 2017 Share Posté(e) 10 janvier 2017 Au niveau autonomie, elles se valent toutes .toutes les ROM 7.1.1 vident la batterie rapidementSent from my LG-D855 using Forum mobile app Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
phileg Posté(e) 10 janvier 2017 Share Posté(e) 10 janvier 2017 Pas remarqué ça, c'est sur que Lolipop était un poil plus économe, mais je dirais que MM et N sont identique pour l'instant. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matt1563 Posté(e) 10 janvier 2017 Share Posté(e) 10 janvier 2017 Bonsoir, j'ai installé la rom et les gapps mais petite question : dans l'appli appareil photo, je n'ai pas l'option du stockage sur la carte sd, est-ce que j'ai oublié qualquechose? merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tgauville Posté(e) 11 janvier 2017 Share Posté(e) 11 janvier 2017 Il y a 13 heures, bundy12 a dit : Au niveau autonomie, elles se valent toutes .toutes les ROM 7.1.1 vident la batterie rapidement Sent from my LG-D855 using Forum mobile app Effectivement les premières versions sous Nougat étaient gourmandes en batterie, le capteur de luminosité n'était pas géré entre autre alors qu'il fonctionne maintenant bien que cela pour moi fonctionne moins bien que sous MM, je tournais avec la rom Fulmic 6.7 précédemment, de plus avec la crDroid le cpu est overclocké de 10% environ ( 2.76 ghz pour moi au lieu des 2.5 d'origine ) a près dans les paramètres de batterie il y a la possibilité d'utiliser différents profils d'utilisation du cpu Il y a 11 heures, matt1563 a dit : Bonsoir, j'ai installé la rom et les gapps mais petite question : dans l'appli appareil photo, je n'ai pas l'option du stockage sur la carte sd, est-ce que j'ai oublié qualquechose? merci Est ce que ta carte sd est bien reconnue par ton téléphone, dans l’explorateur de fichier par exemple ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matt1563 Posté(e) 11 janvier 2017 Share Posté(e) 11 janvier 2017 Salut, oui ma sd est bien reconnue dans les paramètres de stockage et sur Google Play Music, j'ai bien accès à l'option de stockage sur ma carte. Par contre sur Appareil photo, je ne vois même pas l'option de l'emplacement de stockage... Vous l'avez chez vous? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tgauville Posté(e) 11 janvier 2017 Share Posté(e) 11 janvier 2017 Il y a 1 heure, matt1563 a dit : Salut, oui ma sd est bien reconnue dans les paramètres de stockage et sur Google Play Music, j'ai bien accès à l'option de stockage sur ma carte. Par contre sur Appareil photo, je ne vois même pas l'option de l'emplacement de stockage... Vous l'avez chez vous? Oui dans les paramètres en glissant sur l'écran de gauche à droite puis " Emplacement de stockage " Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matt1563 Posté(e) 12 janvier 2017 Share Posté(e) 12 janvier 2017 (modifié) Merci de ton aide. C'est bizarre, je n'ai même pas l'option, l'appli Google "Appareil photo" est installée par la rom ou les gApps? J'ai la version 2.5.052, ça me parait étrange, le problème ne viendrait pas de là? Modifié 12 janvier 2017 par matt1563 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tgauville Posté(e) 12 janvier 2017 Share Posté(e) 12 janvier 2017 (modifié) il y a une heure, matt1563 a dit : Merci de ton aide. C'est bizarre, je n'ai même pas l'option, l'appli Google "Appareil photo" est installée par la rom ou les gApps? J'ai la version 2.5.052, ça me parait étrange, le problème ne viendrait pas de là? Mois j'ai l'appli photo 2.0.002 d'origine cyanogen mais j'ai utilisé les Gapps pico qui n'installe que le playstore donc je pense que tu as toi l'appli google installée par les Gapps ( je ne sais pas quelle version tu utilise ) Dans la liste des applis tu n'as pas une autre appli photo par hasard ?? Perso j'installe la version pico et ensuite éventuellement les applis google que je veux depuis le playstore Edit : Nouvelle version de la crDroid la 2.0 Après vérification ta version est bien une version google et elle date de juin 2015 ?? Un conseil refait une installation ou une mise à jour avec la version 2.0 et installe que les gapps pico, tu verras ensuite pour le reste des applis google dont tu te sert Modifié 12 janvier 2017 par tgauville Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matt1563 Posté(e) 12 janvier 2017 Share Posté(e) 12 janvier 2017 (modifié) Merci pour le retour. Alors, j'ai installé la nouvelle version de la rom et les GApps mini, du coup j'ai l'appareil photo cyanogen avec l'option du stockage Modifié 12 janvier 2017 par matt1563 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tgauville Posté(e) 12 janvier 2017 Share Posté(e) 12 janvier 2017 il y a 4 minutes, matt1563 a dit : Merci pour le retour. Alors, j'ai installé la nouvelle version de la rom et les GApps mini, du coup j'ai l'appareil photo cyanogen avec l'option du stockage Ok merci ça roule ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
