Pun_catid (Les ptites z'icones) en OpenSource
admin
Vous pouvez telecharger ici le plugin utilise sur le punbb de frandroid.
https://forum.frandroid.com/forum/extensions/pun_catid.tar
Baptiste Michaud
bactisme@frandroid.com
Licences
GPL Licence, based on pun_tags
Icons from famfamfam, Creative Commons Attribution 2.5 License, More icons on
http://www.famfamfam.com/lab/icons/silk/
INSTALLATION
1 . Open db.sql replace PUMBB_PREFIX_ by your database prefix;
2 . Execute the sql file on your db via phpmyadmin for example
3 . Move cat-menu to your punbb 'img' folder
4 . move pun_catid to extentions folder
5 . Line 95 in file viewforum.php,
find the lines:
> $query = array(
> 'SELECT' => 't.id, t.poster, t.subject, t.posted, t.first_post_id, t.last_post, t.last_post_id, t.last_poster, t.num_views, t.num_replies, t.closed, t.sticky, t.moved_to',
and chand it to:
> 'SELECT' => 't.id, t.poster, t.subject, t.posted, t.first_post_id, t.last_post, t.last_post_id, t.last_poster, t.num_views, t.num_replies, t.closed, t.sticky, t.moved_to, pun_catid',
6 . Activate extention in adminstration console
ISSUES
1 . There is no administration interface for the moment (maybe later), you have to
use phpmyadmin.
2 . Bugs on order field ?
3. Sorry to the punbb team, i did't realized that 'pun_*' names was extentions from the punbb's team
Tous retours, mises a jours, améliorations sont les bien venues :P
Amusez-vous bien !!
Baptiste M.
