banditdvd Posté(e) 11 mai 2017 Share Posté(e) 11 mai 2017 Salut à tous. Voila je suis tombé par hasard sur cette page: http://www.gearbest.com/cell-phones/pp_627537.html? Voici les specification au cas ou il la retirerais:* Tip: Unlocked for Worldwide use. Please ensure local area network is compatible. click here for Network Frequency of your country. Please check with your carrier/provider before purchasing this item.The ROM on this Phone supports OTA and is multi language.OnePlus 5 4G Phablet 5.5 inch Android 7.1 Snapdragon 835 Octa Core 2.35GHz 8GB RAM 64GB ROM 16.0MP + 23.0MP CamerasMain Features:Display: 5.5 inch, 2560 x 1440 pixels 2K screenCPU: Snapdragon 835 Octa Core 2.35GHz System: Android 7.1Camera: 23.0MP rear camera + 16.0MP front cameraSensor: Accelerometer, Ambient Light Sensor, E-Compass, Gyroscope, Hall Sensor, Proximity Sensor, Touch SensorSIM Card: dual SIM dual standby, Nano SIM / Nano SIMFeature: GPS, A-GPS, GLONASSBluetooth: 4.2Network: GSM 850/900/1800/1900MHz CDMA EVDO BC0WCDMA B1/B2/B5/B8 TD-SCDMA B34/B39FDD-LTE B1/B3/B5/B7/B8TD-LTE B38/B39/B40/B41 Voila si cela peut faire avancer la chose. Lien vers le commentaire Partager sur d’autres sites More sharing options...
