cdelaval Posté(e) 5 novembre 2010 Share Posté(e) 5 novembre 2010 bonsoirJoOoSs, j'ai essayé de suivre ton tuto pas à pas, mais j'ai rencontré plusieurs problèmes : à la commande : $ while 'true';do ./m7;done, j'ai la réponse : $ while 'true';do ./m7;done while 'true';do ./m7;done ./roc/603/cmdlineexit! exit! exit! reroc/609/cmdline[ WIN! 609 EIP: b0000100 Instruction executed: e1a000 Wrote shellcode e0400000 line 0 Wrote shellcode e3a07023 line 1 Wrote shellcode ef000000 line 2 Wrote shellcode e0400000 line 3 Wrote shellcode e3a07017 line 4 Wrote shellcode ef000000 line 5 Wrote shellcode e0433003 line 6 Wrote shellcode e28f0014 line 7 Wrote shellcode e50d0008 line 8 Wrote shellcode e50d3004 line 9 Wrote shellcode e24d1008 line 10 Wrote shellcode e24d2004 line 11 Wrote shellcode e3a0700b line 12 Wrote shellcode ef000000 line 13 Wrote shellcode 7379732f line 14 Wrote shellcode 2f6d6574 line 15 Wrote shellcode 2f6e6962 line 16 Wrote shellcode 6873 line 17 Wrote shellcode 0 line 18 [ Overwritten 0xb0000100 # usage: reboot [-n] [-p] [rebootcommand] usage: reboot [-n] [-p] [rebootcommand] usage: reboot [-n] [-p] [rebootcommand] à la commande insmod /data/local/bin/tattoo-hack.ko, j'ai la réponse suivante : # insmod /data/local/bin/tattoo-hack.ko insmod /data/local/bin/tattoo-hack.ko insmod: can't open '/data/local/bin/tattoo-hack.ko' à la commande : # /data/local/bin/flash_image recovery /sdcard/recovery_amonra.img réponse: /data/local/bin/flash_image recovery /sdcard/recovery_amonra flashing recovery from /sdcard/recovery_amonra.img mtd: erase failure at 0x00000000 (Input/output error) mtd: erase failure at 0x00000000 (Input/output error) mtd: skipping write block at 0x00000000 mtd: erase failure at 0x00020000 (Input/output error) mtd: erase failure at 0x00020000 (Input/output error) mtd: skipping write block at 0x00020000 mtd: erase failure at 0x00040000 (Input/output error) mtd: erase failure at 0x00040000 (Input/output error) mtd: skipping write block at 0x00040000 mtd: erase failure at 0x00060000 (Input/output error) mtd: erase failure at 0x00060000 (Input/output error) mtd: skipping write block at 0x00060000 mtd: erase failure at 0x00080000 (Input/output error) mtd: erase failure at 0x00080000 (Input/output error) mtd: skipping write block at 0x00080000 mtd: erase failure at 0x000a0000 (Input/output error) mtd: erase failure at 0x000a0000 (Input/output error) mtd: skipping write block at 0x000a0000 mtd: erase failure at 0x000c0000 (Input/output error) mtd: erase failure at 0x000c0000 (Input/output error) mtd: skipping write block at 0x000c0000 mtd: erase failure at 0x000e0000 (Input/output error) mtd: erase failure at 0x000e0000 (Input/output error) mtd: skipping write block at 0x000e0000 mtd: erase failure at 0x00100000 (Input/output error) mtd: erase failure at 0x00100000 (Input/output error) mtd: skipping write block at 0x00100000 mtd: erase failure at 0x00120000 (Input/output error) mtd: erase failure at 0x00120000 (Input/output error) mtd: skipping write block at 0x00120000 mtd: erase failure at 0x00140000 (Input/output error) mtd: erase failure at 0x00140000 (Input/output error) mtd: skipping write block at 0x00140000 mtd: erase failure at 0x00160000 (Input/output error) mtd: erase failure at 0x00160000 (Input/output error) mtd: skipping write block at 0x00160000 mtd: erase failure at 0x00180000 (Input/output error) mtd: erase failure at 0x00180000 (Input/output error) mtd: skipping write block at 0x00180000 mtd: erase failure at 0x001a0000 (Input/output error) mtd: erase failure at 0x001a0000 (Input/output error) mtd: skipping write block at 0x001a0000 mtd: erase failure at 0x001c0000 (Input/output error) mtd: erase failure at 0x001c0000 (Input/output error) mtd: skipping write block at 0x001c0000 mtd: erase failure at 0x001e0000 (Input/output error) mtd: erase failure at 0x001e0000 (Input/output error) mtd: skipping write block at 0x001e0000 mtd: erase failure at 0x00200000 (Input/output error) mtd: erase failure at 0x00200000 (Input/output error) mtd: skipping write block at 0x00200000 mtd: erase failure at 0x00220000 (Input/output error) mtd: erase failure at 0x00220000 (Input/output error) mtd: skipping write block at 0x00220000 mtd: erase failure at 0x00240000 (Input/output error) mtd: erase failure at 0x00240000 (Input/output error) mtd: skipping write block at 0x00240000 mtd: erase failure at 0x00260000 (Input/output error) mtd: erase failure at 0x00260000 (Input/output error) mtd: skipping write block at 0x00260000 mtd: erase failure at 0x00280000 (Input/output error) mtd: erase failure at 0x00280000 (Input/output error) mtd: skipping write block at 0x00280000 mtd: erase failure at 0x002a0000 (Input/output error) mtd: erase failure at 0x002a0000 (Input/output error) mtd: skipping write block at 0x002a0000 mtd: erase failure at 0x002c0000 (Input/output error) mtd: erase failure at 0x002c0000 (Input/output error) mtd: skipping write block at 0x002c0000 mtd: erase failure at 0x002e0000 (Input/output error) mtd: erase failure at 0x002e0000 (Input/output error) mtd: skipping write block at 0x002e0000 mtd: erase failure at 0x00300000 (Input/output error) mtd: erase failure at 0x00300000 (Input/output error) mtd: skipping write block at 0x00300000 mtd: erase failure at 0x00320000 (Input/output error) mtd: erase failure at 0x00320000 (Input/output error) mtd: skipping write block at 0x00320000 mtd: erase failure at 0x00340000 (Input/output error) mtd: erase failure at 0x00340000 (Input/output error) mtd: skipping write block at 0x00340000 mtd: erase failure at 0x00360000 (Input/output error) mtd: erase failure at 0x00360000 (Input/output error) mtd: skipping write block at 0x00360000 mtd: erase failure at 0x00380000 (Input/output error) mtd: erase failure at 0x00380000 (Input/output error) mtd: skipping write block at 0x00380000 mtd: erase failure at 0x003a0000 (Input/output error) mtd: erase failure at 0x003a0000 (Input/output error) mtd: skipping write block at 0x003a0000 mtd: erase failure at 0x003c0000 (Input/output error) mtd: erase failure at 0x003c0000 (Input/output error) mtd: skipping write block at 0x003c0000 mtd: erase failure at 0x003e0000 (Input/output error) mtd: erase failure at 0x003e0000 (Input/output error) mtd: skipping write block at 0x003e0000 mtd: erase failure at 0x00400000 (Input/output error) mtd: erase failure at 0x00400000 (Input/output error) mtd: skipping write block at 0x00400000 mtd: erase failure at 0x00420000 (Input/output error) mtd: erase failure at 0x00420000 (Input/output error) mtd: skipping write block at 0x00420000 mtd: erase failure at 0x00440000 (Input/output error) mtd: erase failure at 0x00440000 (Input/output error) mtd: skipping write block at 0x00440000 mtd: erase failure at 0x00460000 (Input/output error) mtd: erase failure at 0x00460000 (Input/output error) mtd: skipping write block at 0x00460000 mtd: erase failure at 0x00480000 (Input/output error) mtd: erase failure at 0x00480000 (Input/output error) mtd: skipping write block at 0x00480000 mtd: erase failure at 0x004a0000 (Input/output error) mtd: erase failure at 0x004a0000 (Input/output error) mtd: skipping write block at 0x004a0000 mtd: erase failure at 0x004c0000 (Input/output error) mtd: erase failure at 0x004c0000 (Input/output error) mtd: skipping write block at 0x004c0000 mtd: erase failure at 0x004e0000 (Input/output error) mtd: erase failure at 0x004e0000 (Input/output error) mtd: skipping write block at 0x004e0000 error writing recovery: No space left on device pourrais tu me dire où est le problème ? Problème général de place disque insuffisant ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chacal11 Posté(e) 6 novembre 2010 Share Posté(e) 6 novembre 2010 Bonjour moi aussi je voudrais le passer en 2.1 mais il y a plus personne pour nous aider .je voudrais commencer a le faire pat par pat. Mais vous êtes ou la compagnie on a besoin de vous :mad: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
EowynCarter Posté(e) 6 novembre 2010 Share Posté(e) 6 novembre 2010 le "no space left", tu peut aussi aussi l'avoir quand tu n'a pas les droits pour ecrire. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
