How To Setup Netgear Router?
routerloginwiz
It's easy to set up your Netgear router. First, use an Ethernet wire to link your router and modem. After turning on both gadgets, watch for the LED lights to level out. Next, establish a Wi-Fi connection between your computer and your smartphone. Navigate to routerlogin.net via a web browser. Enter the default login information (located on the router label). To establish your network settings, including your SSID and password, adhere to the on-screen directions. After finishing, restart the router and save the adjustments.  Your Netgear router setup is now complete! Try again after resetting the router if you have problems. With your Netgear router, take advantage of a quick and safe internet connection.
