[ROM] Cronos Froyo Milestone 1.5.0
wello
Release notes:
Cronos Froyo Milestone Kernel update:
* Cronos IO Scheduler Added.
* EXT2, EXT3 modules Addded. (Not Working)
* Hopefully my HTC Hero sound improvement works on the Milestone. (New sound module Addded)
Cronos Froyo Milestone 1.5.0:
* Fully cleaned the blob profile to make use of proprietary only and the rest are 100% compiled.
* Hopefully battery drain fixed.
* Fully updated to latest sources.
* Default 700Mhz
* Default governor "ondemand"
Cronos Froyo Milestone 1.4.0:
* Recompile everything again based on Nadlabaks vendor profile.
* Experimental java improvements
* Used JIT library optimizations.
* As always included CM external application sources.
* CM Parts are included default, but filtered and added as CM Extra in menu.
* DalvikVM changes to give it a bit more speed.
* Fully optimized ARM flags compile.
* Big improvement to Performance V8 and Webkit.
* Allowed unaligned memory accesses on ARM targets that support it.
* Faster Z_HUFFMAN_ONLY and Z_RLE compression for images and other specialized compression.
* Latest gapps added.
* New Talking notification sounds
* Fixed Bluetooth.
* Set default speed to 700Mhz.
Requires 2.6.32 kernel and bpsw from the moto 2.2.1 test leak
If you need help installing this ROM, please check: viewtopic.php?f=41&t=456&start=60#p16888
Download Cronos Froyo Milestone 1.5.0:
http://www.multiupload.com/NUMBURWIA7
MD5SUM: 35c850f7fc3ed15b8d6e2672b92c3229
Kernel Modules Update 01:
http://www.multiupload.com/SMEJ7YTAPB
MD5SUM: cf6e4cf527ed57dd7e0f27779271836b
Camera APK:
http://www.multiupload.com/MAUHTDXM16
TUTO d'installation rom:
1-Téléchargez, copier l'update de CFMM-1.5.0, Kernel Modules Update 01 et les applications google dans "sdcard/openrecovery/updates"
2-Démarrer le téléphone en recovery
3-Faire un wipe data/factory + wipe dalvik cache
4-Appliquez l'update CFMM-1.5.0_ puis les apps google et les bugfixs (si disponible) avec l'option update du recovery
5-Paramétrez le clavier azerty, fix market ect... avec les options du recovery
6-Reboot
7-Appliquez le Kernel Modules Update 01
Latest gapps:
http://goo-inside.me/google-apps/gapps- ... signed.zip
Optional:
Download Flash 10.1:
http://www.multiupload.com/UG4QUIA9ML
Download Official Froyo Launcher:
http://www.multiupload.com/XD2D9T1954
Sources: http://www.cronosproject.org/forum/viewtopic.php?f=50&t=502
Modifié par wello
Le français est disponible ? Le clavier est en azerty ? Il n'y a pas besoin de GOT ? On peut flasher par dessus une GOT ?
Désolé si ce sont des questions bêtes...Merci :)
le francais est disponible,le clavier est en azerty et tu peux flzsher par dessus une got
bon pas moyen d'installer...
à partir de GOT 2.2.1, je mets dans le dossier /OpenRecovery/updates les 3 zips ( CFMM-1.5.0_.zip, CFMK001-2.6.32_sign.zip, gapps-hdpi-20101114-signed.zip).
Je redemarre en openrecovery ===> apply update pour rentrer dans l'openrecovery, wipe cache toussa... ==> puis je mets les updates CFMM-1.5.0_ puis les apps google ==> je mets ensuite le clavier en AZERTY ==> je refais un wipe data/factory + wipe dalvik cache ==> je reboot ==> je rerentre dans l'openrecovery puis je mets le patch kernel....
Mon tél redémarre avec le point d'exclamation et c'est tout.
J'ai essayé 2 fois mais toujours le même résultat.
Vous avez une idée?
ok au bout de 3 reboots...par contre mon clavier physique ne fonctionne pas ainsi qu aucun bouton,volume et appareil photo, le bouton de démarrage fonctionne quant a lui...grrr
Modifié par raumin
Vous avez une idée?
ok au bout de 3 reboots...par contre mon clavier physique ne fonctionne pas...grrr
essaye sans le deuxième reset et wipe dalvik cache Modifié par wello
* Report this post
* Reply with quote
Cronos Froyo Milestone 1.6.0
New postby Feeyo » November 25th, 2010, 3:05 pm
Hello Milestone Community,
Here you go Cronos froyo for the Milestone version 1.6.0.
Thanks to nadlabak and Skrilax_CZ for their awesome coding. Hope you guys can enjoy their work and of course my work on this build.
How to flash Cronos Roms:
1. Wipe
2. Flash ROM
3. reboot
4. Flash Hot Fix (If any)
5. reboot
6. flash kernel (If any updates)
7. reboot
Release notes:
25 Nov 2010 | Cronos Froyo 1.6.0:
* Full new compile based on my latest toolchain.
* Default Mail Client updated to support more IMAP + SSL
* getThumbnail memory leak fixed.
* Used JIT+ library optimizations.
* Sound Improvement.
* OpenCore improvements.
* SKIA (2D Render Engine) Improvements.
* New Kernel tweaks.
* Android System Tweaks.
* A lot of DalvikVM changes. This bad boy is a monster now.
* Shutdown and Reboot Menu is now faster.
* Removed blending and blur, to speed up system.
* Latest GAPPS.
* Talking notification sounds.
* Default 700Mhz
* Included DroidReign app. We are officially supporting them.
* Default 700Mhz
* Fixed Bluetooth.
Please note: You do not need the 2.2.1 SBF flash anymore.
Download: http://www.multiupload.com/OFNPGFJH8B
MD5SUM: ac63f963b346a2f03edcdd65047f31e5
Optional:
Download ADWLauncher:
http://www.multiupload.com/BV3YPKJ8IN
Latest gapps:
OC a la meme fréquence la Cronos reste plus rapide quand meme... De plus un net avantage sur cet Rom est la batterie qui tiens facilement 1 jour avec wifi 3g etc etc tandis que la Cyano tenais difficilement une journée avec les meme options coupé
Apres ce n'est que mon avis perso :P
Merci et niveau fluidité et wifi des problème a signaler?
