NEW TESTED Temu Code ALZ754953 | ALU596295 — Verified Temu Coupon Codes, November 27, 2026
Temu Coupon Code for New Users 2026–2027: ALZ754953 & ALU596295 Review
Last Updated: November 27, 2026
Offer: Up to 40% Off + an Advertised $200 Coupon Bundle
Codes: ALZ754953 and ALU596295
Best For: New Temu users and eligible existing customers in the United States, United Kingdom, Canada, Australia, and New Zealand.
Looking for a working Temu coupon code for new users in 2026 or 2027? Two codes worth checking are ALZ754953 and ALU596295. Both are marked as verified today, November 27, 2026, and are listed as universal Temu promotions offering up to 40% off plus an advertised coupon bundle worth up to $200.
The two codes have an important difference: ALZ754953 is the first campaign to try, while ALU596295 is an independently issued alternative. If the first code is rejected, the second can be tested without rebuilding your shopping basket.
This review explains how the two Temu coupon codes work, how to enter them, what the advertised 40% discount and $200 coupon bundle actually mean, and what shoppers should check before completing an order.
Quick Answer: Which Temu Coupon Code Should You Try First?
Start with ALZ754953. It is marked as the newest campaign and is the first code recommended for testing. Its published instructions state that there is no minimum spend and that the campaign does not check whether a customer has ordered from Temu before.
If ALZ754953 is refused, try ALU596295. It is issued independently, so a rejection of the first campaign does not automatically mean that the second code is invalid. You can enter the alternative directly without creating a new basket.
Both codes are listed by MaCoupon as universal offers for new and existing customers. The advertised promotion is up to 40% off alongside a coupon bundle valued at up to $200. The final discount depends on the promotion displayed by Temu and the applicable coupon conditions.
For the latest listing and verification updates, see the MaCoupon Temu coupon codes page.
1. ALZ754953: The First Temu Coupon Code to Try
Code: ALZ754953
Status: Verified November 27, 2026
Offer: Up to 40% off + advertised $200 coupon bundle
Recommended action: Try this campaign first.
ALZ754953 is the newest of the two campaigns covered in this review. Its verification information specifically recommends starting here before trying the independent alternative.
One particularly useful detail is its stated eligibility rule. According to the published campaign information, the promotion does not read whether the shopper has ordered from Temu before. This makes it relevant to people searching for a Temu coupon code for new users as well as customers who already have an order history.
Another useful point is the stated absence of a minimum purchase requirement for this campaign. Shoppers can test the code without first having to increase their basket to meet a specified order threshold.
What makes ALZ754953 useful?
There are three practical reasons to start with this code.
First, it is identified as the newest campaign in the supplied verification information. Starting with the newest available option gives shoppers a straightforward first attempt.
Second, its published instructions state that there is no minimum spend. This removes one common obstacle associated with promotional codes, although other campaign conditions may still apply.
Third, the campaign does not check previous ordering history according to its published description. That makes it especially relevant to shoppers who are unsure whether a new-user promotion will work with an existing Temu account.
Where should you enter ALZ754953?
The supplied instructions identify two places:
  • The Temu app search bar.
  • The checkout area.
Copy the code carefully, enter it in the appropriate location, and check whether the promotional benefit appears before paying.
Do not assume that a code has been accepted simply because it was entered. The order summary should show the applicable discount.
2. ALU596295: The Independent Alternative
Code: ALU596295
Offer: Same advertised 40% discount and $200 coupon bundle
Recommended action: Try it if ALZ754953 is refused.
ALU596295 is not simply another spelling or replacement of the first code. Its campaign is issued independently of ALZ754953.
This distinction matters because promotional codes can belong to different campaigns. A rejection of one campaign does not necessarily establish that another campaign is expired or unavailable.
The practical recommendation is therefore simple: test ALZ754953 first. If Temu refuses it, keep your existing shopping basket and try ALU596295.
You do not need to rebuild the basket simply because the first code was rejected.
Why does having an independent alternative matter?
Imagine that you have selected several products and reached the promotional code stage. You enter ALZ754953, but the promotion does not appear.
There can be several explanations, including a campaign allocation issue, a temporary eligibility condition, a regional difference, or a change in the promotion.
Instead of assuming that every available Temu coupon has expired, test ALU596295 separately.
Its independent campaign status means the first rejection does not automatically determine the second campaign's result.
Where do you enter ALU596295?
The supplied instructions also identify the Temu app search bar or checkout as possible entry points.
After entering the code, review the updated order total. Continue only when Temu displays the discount or coupon benefit that applies to your order.
3. ALZ754953 vs. ALU596295: Which Code Is Better to Try First?
The two codes have similar advertised promotional benefits but different campaign instructions.
Feature
ALZ754953
ALU596295
Verification
November 27, 2026
November 27, 2026
Advertised offer
Up to 40% + $200 bundle
Campaign
Newest campaign
Independent alternative
First attempt
Recommended
Backup attempt
Minimum spend
No minimum stated
Not separately specified in supplied instructions
Previous order history
Does not check previous orders, according to its description
Listed as universal on MaCoupon
Entry location
App search bar or checkout
What to do if refused
Try ALU596295
Check the promotion and account conditions
The most useful difference is not the headline discount. It is the order in which the codes should be tested.
ALZ754953 is the recommended starting point. ALU596295 gives shoppers an independent second campaign to test if the first attempt fails.
There is no reason to enter both and assume they will combine into one larger discount. Temu generally applies one coupon per order, so a second code should be treated as an alternative rather than an additional percentage to add to the first.
4. What Does Up to 40% Off Plus a $200 Coupon Bundle Mean?
Promotional headlines can be confusing, particularly when a retailer combines a percentage discount with a coupon bundle.
The offer covered here has two different elements:
The percentage discount: The advertised promotion offers savings of up to 40%, subject to the campaign and the discount actually displayed during checkout.
The coupon bundle: The advertised bundle has a stated value of up to $200. It should be understood as a collection of promotional coupons, not automatically as $200 in cash or an instant $200 reduction on one shopping basket.
These are two different forms of promotional value.
For example, a shopper may see a headline referring to a $200 coupon bundle but discover that individual coupons inside the bundle have separate conditions.
Those conditions can include minimum purchase amounts, eligible products, expiry dates, account eligibility, or restrictions on how and when each coupon can be used.
That is why it is important to inspect the actual coupons offered in the Temu account.
Is the $200 coupon bundle the same as a $200 discount?
No. The advertised bundle value should not be confused with an unconditional $200 reduction on a single order.
A coupon bundle can contain several individual discounts. Each coupon may have its own qualifying purchase amount and usage conditions.
The total advertised value is not necessarily what every customer can save immediately.
The sensible approach is to examine the individual coupons after the promotion has been accepted and calculate the value that can actually be used.
Is the 40% discount guaranteed on every order?
The headline says up to 40%, which is a maximum promotional claim rather than a promise that every customer will receive exactly 40% on every item.
The final percentage and savings should be confirmed in the order summary.
Always use the amount displayed by Temu as the basis for your purchasing decision.
5. How to Use a Temu Coupon Code for New Users
Redeeming a Temu coupon code is straightforward, but the exact entry point may depend on the promotional campaign.
Here is a practical process for testing the two codes.
Step 1: Open the Temu app or website
Sign in to your account or complete the registration process if you are a new shopper.
Make sure you are using the correct regional version of Temu for your country.
Step 2: Select the products you want
Browse the products and add your preferred items to the shopping basket.
Before placing an order, review the product prices, quantities, delivery information, and any relevant product conditions.
There is no need to purchase unnecessary items simply to chase a promotional headline.
Step 3: Test ALZ754953 first
Copy the following code:
ALZ754953
Enter it in the Temu app search bar or checkout area, as indicated by the campaign instructions.
Check the result before continuing.
Step 4: Review the discount
Open the order summary and look for the promotion or coupon adjustment.
Compare the original order amount with the updated amount.
Check whether the discount applies to the products you selected and whether any minimum purchase condition appears.
Step 5: Try ALU596295 if the first code is rejected
If ALZ754953 does not apply, copy the alternative:
ALU596295
Enter it separately using the indicated search bar or checkout method.
You can keep your basket rather than rebuilding it from the beginning.
Step 6: Confirm the final total
Before completing payment, verify the following:
  • The promotion is visibly applied.
  • The final amount is correct.
  • The shipping charge is clearly displayed.
  • The selected products are eligible.
  • The coupon conditions are acceptable.
A successful code entry is not the same as a confirmed discount. The order summary is what matters.
For additional instructions, consult Temu's coupon redemption support information.
6. Do These Temu Coupon Codes Work for Existing Customers?
Although the search phrase Temu coupon code for new users is popular, not every attractive promotion is restricted to first-time shoppers.
MaCoupon lists ALZ754953 and ALU596295 among its universal codes for new and existing accounts.
This is particularly relevant to customers who have already placed orders and want to check whether they can still access a promotional offer.
ALZ754953 has an additional detail in its published instructions: it does not check whether a shopper has ordered before.
ALU596295 is independently issued, and its listing also identifies it as a code for new and existing users.
However, universal campaign classification should not be interpreted as a guarantee that every order in every location will qualify indefinitely.
Promotions can change, campaign allocations can end, and regional conditions may differ.
The safest approach is to test the code in the account you intend to use and confirm that the expected discount appears.
7. Review: Advantages and Limitations of ALZ754953 and ALU596295
A useful coupon review should explain both the benefits and the limitations.
It is easy to publish two promotional codes and repeat a discount headline. It is more useful to explain what shoppers should expect when they actually try them.
Advantages
1. Two independent campaign options
The main practical advantage is having two separate codes rather than relying on one promotional campaign.
If the first code is rejected, the shopper can test the second without assuming that the entire offer has ended.
2. Useful for new and existing accounts
Both codes are categorized as universal on MaCoupon, making them relevant to a wider group of shoppers than campaigns restricted to first orders.
3. No minimum spend stated for the first code
ALZ754953 is particularly interesting because its campaign instructions explicitly state that no minimum spend is required.
This makes it easier to test without adding unnecessary products to the basket.
4. Flexible entry locations
Both codes list the Temu app search bar and checkout as possible entry points.
This offers shoppers more than one way to test the promotions.
5. Daily verification information
The supplied code cards display a Verified today label dated November 27, 2026.
MaCoupon also publishes information describing its approach to testing promotional codes. Its verification guide explains that published codes are applied to live checkout and rechecked regularly.
Limitations
1. Promotions can change
A coupon that works today may not work tomorrow. Campaigns can be updated, withdrawn, or replaced.
That is why the verification date matters.
2. The headline does not explain every coupon condition
The $200 bundle is an advertised total value. Individual coupons may have their own conditions.
Read each coupon before treating the advertised bundle as an immediate saving.
3. A rejected code is not a guarantee that another will work
The independent campaign structure gives you another option, but it does not guarantee that the alternative will be accepted on every account or shopping basket.
4. The maximum discount is not necessarily the actual discount
Up to 40% does not mean every product or every order automatically receives a 40% reduction.
Check the exact amount at checkout.
5. One coupon per order
Temu's general coupon guidance states that only one coupon can be used per order. Do not assume that ALZ754953 and ALU596295 can be stacked together.
Overall, the two codes offer a practical testing sequence, but the final result must always be checked against the terms displayed by Temu.
8. How Are the Codes Verified?
The words verified, tested, and working are common on coupon websites. However, readers should be able to understand what those labels mean.
The supplied campaign cards show both ALZ754953 and ALU596295 as Verified today on November 27, 2026.
This is useful because a dated status is more informative than an undated statement that a coupon is always working.
MaCoupon also has a dedicated explanation of its verification approach:
How MaCoupon verifies Temu coupon codes.
The guide describes a live-checkout approach, daily rechecking, and removing codes when they stop working.
For readers, the most important questions are:
  • Is the code accompanied by a recent verification date?
  • Is there an explanation of where the code should be entered?
  • Does the published offer distinguish between a percentage discount and a coupon bundle?
  • Are restrictions and possible rejection scenarios explained?
  • Can the discount be confirmed in the actual checkout summary?
It is better to provide this kind of verification information than to rely on unsupported claims about a coupon being guaranteed forever.
No independent customer testimonials or success percentages are assumed in this review. Any customer review should be based on a genuine shopping experience and published with the customer's permission.
9. Which Countries Should Check These Temu Codes?
Temu operates across different regional markets, and promotional availability can vary.
MaCoupon identifies the United States, United Kingdom, Canada, Australia, and New Zealand among the markets covered by its Temu coupon pages.
Shoppers in those locations can use the relevant regional storefront to check the current promotion.
The practical steps are the same:
  1. Open the local Temu app or website.
  2. Select the products you want to purchase.
  3. Try ALZ754953.
  4. If refused, test ALU596295 independently.
  5. Review the discount displayed in your local currency.
  6. Confirm all conditions before payment.
A promotional banner may display a dollar-denominated headline, but the final order summary may use pounds, Canadian dollars, Australian dollars, or New Zealand dollars.
The amount displayed in the customer's local checkout is more important than a converted example on another website.
Do not assume that every market receives exactly the same coupon structure simply because the headline promotion is similar.
10. Why Might a Temu Coupon Code Not Work?
A coupon rejection can be frustrating, especially when a code was recently marked as verified.
However, a rejection does not always mean that a code is universally expired.
There are several possible explanations.
Campaign availability
Promotional campaigns can be limited or changed. A code may be listed shortly before an allocation changes.
Account eligibility
Some promotions distinguish between new accounts, returning users, and users with previous purchases.
Even when a campaign is described as universal, customers should check the conditions shown in their own accounts.
Regional restrictions
A promotion may have different availability depending on the country or regional storefront.
Coupon entry location
Some codes are intended for the main app search bar, while other types of promotions are entered into the checkout coupon field.
Using the wrong field can prevent a promotion from being applied.
Basket conditions
Some coupons have qualifying purchase amounts or eligible product restrictions.
The absence of a minimum spend in the ALZ754953 instructions should not automatically be applied to every other coupon inside a promotional bundle.
Expired or updated campaigns
An older article may continue showing a code that has already been replaced.
Look for a recent verification date rather than relying only on the publication date.
What should you do when the first code fails?
Keep the basket and test the independent alternative, ALU596295.
Then check the order summary again.
If neither code applies, avoid completing the order based on an expected discount that is not displayed.
11. Is MaCoupon a Useful Place to Find Updated Temu Coupon Codes?
A coupon listing is only useful when shoppers can understand which offers are available and which conditions apply.
MaCoupon organizes Temu promotions by different customer types and promotional categories, including new-user offers, existing-customer codes, app promotions, and universal codes.
That structure makes it easier to distinguish between a welcome promotion and an offer intended for returning shoppers.
The website also provides information about verification and coupon usage, rather than presenting every code as interchangeable.
For a shopper comparing promotions, three features are especially useful:
Recent verification dates: These help establish when the published status was last checked.
Campaign descriptions: They explain whether a code is a first option, an independent alternative, or a promotion for a particular account type.
Usage instructions: They help shoppers identify where to enter the code before completing checkout.
Readers can find the current offers and their listed conditions on the MaCoupon Temu coupon page.
This is a useful starting point, but Temu's own checkout remains the final confirmation of whether an offer applies to an individual transaction.
12. Planning Ahead: Temu Coupon Codes for 2027
Searches for Temu coupon codes are not limited to one shopping season.
New users and returning customers continue looking for promotional offers throughout the year, including during:
  • January shopping campaigns.
  • Valentine's Day promotions.
  • Spring sales.
  • Summer shopping events.
  • Back-to-school periods.
  • Black Friday.
  • Cyber Monday.
  • Christmas and end-of-year promotions.
This makes the 2026–2027 period relevant for shoppers who want to keep track of new offers rather than relying on a single old promotional page.
However, including 2027 in a search title does not mean that a particular coupon code is guaranteed to remain active throughout the year.
ALZ754953 and ALU596295 are marked as verified on November 27, 2026. Their future availability must be checked again.
For a reliable coupon experience, use pages with updated verification dates, check individual campaign conditions, and confirm the discount before ordering.
A useful habit is to review the current promotion before making a purchase instead of assuming that a code saved weeks earlier is still valid.
13. Frequently Asked Questions About ALZ754953 and ALU596295
What is the Temu coupon code for new users in 2026?
Two codes worth testing are ALZ754953 and ALU596295. Both were marked verified on November 27, 2026, and are listed as universal promotions for new and existing customers.
Does ALZ754953 offer 40% off?
The advertised promotion associated with the code is up to 40% off plus a coupon bundle valued at up to $200. The final savings must be confirmed at checkout.
Does ALU596295 include the $200 coupon bundle?
Yes. MaCoupon lists ALU596295 with the same advertised 40% promotion and $200 coupon bundle as ALZ754953. Individual coupons in the bundle may have separate conditions.
Which code should I try first?
Start with ALZ754953 because it is identified as the newest campaign in the supplied verification information. Try ALU596295 if the first code is refused.
Can I use ALZ754953 if I have ordered from Temu before?
The supplied campaign description says ALZ754953 does not check whether a customer has ordered before. MaCoupon also lists it as a universal code for new and existing customers.
Is ALU596295 different from ALZ754953?
Yes. ALU596295 is issued independently of ALZ754953. This means a rejection of the first campaign does not automatically establish that the second one is invalid.
Do I need to rebuild my shopping basket if ALZ754953 fails?
No. The supplied instructions recommend trying ALU596295 directly instead of rebuilding the basket.
Does ALZ754953 have a minimum purchase requirement?
The supplied information specifically states that ALZ754953 has no minimum spend. Always review the final promotion displayed in Temu before paying.
Does ALU596295 have the same no-minimum-spend condition?
The supplied campaign description does not separately specify a minimum-spend rule for ALU596295. Check the conditions shown when you apply it.
Can I use both codes on one order?
Do not expect to combine both codes on one order. Temu's general coupon guidance states that one coupon can be used per order. Treat ALU596295 as an alternative if the first campaign is rejected.
Where do I enter ALZ754953?
The supplied instructions identify the Temu app search bar and checkout as possible entry points.
Where do I enter ALU596295?
The supplied instructions also identify the app search bar and checkout for ALU596295.
Why was my Temu coupon code rejected?
Possible reasons include campaign availability, regional conditions, account eligibility, coupon conditions, or the entry method. Check the message displayed by Temu and test the independent alternative.
Is the $200 bundle an instant discount?
No. An advertised coupon bundle is not the same as an unconditional $200 reduction on one purchase. Individual coupons may have their own restrictions and minimum purchase amounts.
Are the two codes verified today?
The supplied code cards show both ALZ754953 and ALU596295 as verified today, November 27, 2026. Check the latest listing before relying on an older verification date.
Will these Temu coupon codes work throughout 2027?
Their inclusion in a 2026–2027 guide does not guarantee their validity throughout 2027. Temu promotions change, so both codes should be checked again when you are ready to purchase.
Final Verdict: Which Temu Coupon Code Should You Use?
For shoppers looking for a Temu coupon code for new users in 2026–2027, ALZ754953 and ALU596295 are two promotions worth checking.
Start with ALZ754953, the newest campaign in the supplied verification information. Its published description states that there is no minimum spend and that it does not check whether the shopper has ordered before.
If the first code is refused, try ALU596295. Its independent campaign gives you another option without rebuilding the basket.
Both codes are listed with an advertised offer of up to 40% off and a coupon bundle worth up to $200.
The most important step is to check the final order summary. Make sure the discount has actually been applied, read the individual coupon conditions, and confirm the amount before paying.
For the latest Temu coupon listings and verification information, visit:
Editorial note: This is an independent promotional-code review, not an official Temu announcement. Coupon availability, eligibility, and final savings are determined by the promotion displayed by Temu at the time of redemption.
