un spl "unlocked" pour le hero par modaco
johndoe
Default 24/11 - Finally, an unlocked SPL for Hero!
I've had this unlocked Hero SPL for a while now, and it's super useful for flashing unsigned updates and cool stuff like custom splashes. Unfortunately i've not been able to distribute it... until now!
WARNING
A PROBLEM FLASHING THE SPL CAN BRICK YOUR DEVICE - as such, proceed with caution. Don't flash this unless you need it, flash at your own risk, flash only to a GSM Hero and do not interrupt the flashing process (which happens on the first reboot after applying the zip). YOU HAVE BEEN WARNED!
The SPL, version 1.76.2007, is in the usual update zip format.
Download: MoDaCo
Enjoy!
comme il le dis si bien, c'est a vos risques et peril, j'assume absolument rien de ce que vous en ferez, par contre si quelqu'un pouvais me resumer l'interet de la chose :D
source : http://android.modaco.com/content/htc-hero-hero-modaco-com/296389/gsm-24-11-finally-an-unlocked-spl-for-hero/
et sinon il va aussi mettre a jour sa rom et la radio en Version: 63.18.55.06JU_6.35.08.29 d'ici ce soir normalement
Modifié par johndoe
