[ROM] TastyFroyo 1.2 - Android 2.2.2
Fredouye
Voici la nouvelle ROM de RaduG, auteur du noyau RaKern et de la ROM ChocolateFroyo.
http://forum.xda-developers.com/showthread.php?t=906114
TastyFroyo is a result of my Android experience. It combines looks with functionality and performance. I'd dare to say that it brings the Hero back to life, but it's up to you to judge it.
I won't post any screenshots for the first hour to leave it as a surprize for the ones who flash the ROM
Details:
- based on CyanogenMod 6.1
- Gingerbread Launcher(credits: paulobrien) and Keyboard
- Miui Music player(credits: tazzpatriot)
- customized and optimized UI
- kept it clean and efficient
- battery friendly
- RaKern-200 kernel @ 691/176 with dual-governor configuration enabled(see post #2 for instructions)
- no Facebook and Twitter apps included, so you can download the latest version from the market if you need them
- great bootanimation(credits aankun)
- EXT A2SD and Froyo A2SD, both working 100%
- 90 degrees accelerometer orientation only(sense-style)
- no ads in apps and on the web
... and another BIG surprize which I will let the first ones who flash discover by themselves - will add it here after the screenshots are up
EVERYTHING WORKS!
To do:
- I'm now working on a custom dialer app for this ROM, no ETA yet as I haven't got as much spare time as before
- more system optimizations on the list for the next version
Instructions:
Download, wipe EVERYTHING and flash from Recovery. First boot should take less than 5 minutes. If it takes longer, it means that your Hero does not support running @691MHz -> FOLLOW THE INSTRUCTIONS IN POST #2. Don't tell me it doesn't work if you didn't follow the instructions there yet.
Modifié par Fredouye
Mauvaise nouvelle de la part du dev...
Well, guys, it seems that I have to give you some bad news. I've just received an offer to buy a Moto Milestone at a very good price. That means I have to sell my Hero to make the money... I wish I could keep the Hero and continue the development, but I can't.
What I can do meanwhile is to finish this ROM/update it. But that's about it.
Tant qu'il termine le développement de cette Rom, moi ça me va ;-))
Une question: Comment fait-on pour changer les applications type contacts, music etc...je les ai placé à la racine de ma carte SD et il me dit à chaque fois qu' linstallation n'a pas réussie :emo_im_undecided:
Modifié par olovo
Petit retour:
-l'autonomie est très bonne
-l'appareil photo ne fonctionne pas
-Quelques problèmes de téléchargement sur le market (pas réussi à installer Angry birds)
-C'est très fluide
Après un peu plus de 24h d'utilisation, j'en suis ravie !
Mise à jour en version 1.1 "The grand finale"
TastyFroyo 1.1 Changelog:
- OpenGL enhancements
not so much CPUfreq dependent anymore
some games(e.g. Angry Birds) seem to work better
- compatibility mode disabled by default
- fixed all graphical glitches
- translucid status bar
- TastyFroyo Extra Settings(update package coming soon)
- update packages for those who can't run at 176/691
To answer possible question: I haven't included the OpenGL 1.1 posted here because it seems to be more
Visiblement, pas mal de problème avec les textes sur fond blanc : il est impossible de lire quoi que ce soit!
Exemple flagrant : le menu redémarrer ou on doit y aller au hasard :D
EDIT : je parle de la 1.1. Sur la 1.0 c'est le noir sur noir qui ne fonctionne pas
Modifié par Sunflare
Je suis toujours en 1.0:
-la galerie photo mais beucoupe de temps à charger les anciennes photos
Chose étrange, après avoir tenu une journée et demi sans recharge, mon hero s'est déchargé brusquement entre hier midi et hier en fin d'apes-midi. Je vais voir si ça me fait la même chose aujourd'hui.
Edit: Même topo aujourd'hui, la batterie s'est brusquement vidée, c'est plutot embettant :(
Modifié par olovo
J'en suis très satisfait également, absolument TOUT fonctionne sur mon Hero (même la réception de MMS).
Un petit détail, le launcher Gingerbread n'est pas aussi fluide que Launcher Pro, mais ça se modifie en 30 secondes :)
rien à dire tout fonctionne très bien et même les mms qui n'avaient jamais fonctionnés !
que veux tu dire ?
[/b]rien à dire tout fonctionne très bien et même les mms qui n'avaient jamais fonctionnés !que veux tu dire ?
J'ai juste installé Launcher Pro, avec des icônes Gingerbread trouvées sur XDA.
A propos de cette ROM :
Updates in the weekend for both ChocolateFroyo and TastyFroyo.
:D
