johndoe Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 (modifié) et encore une rom en 2.1 presque totalement fonctionnelle, j'attendrais juste l'app2sd pour install :D source : http://htcpedia.com/forum/showthread.php?t=1448 Changelogv1.8 - reverted back bootscreen to Hero's (as it is a Hero rom) - fixed HTC's worldclock and weather (from Espresso) - added HTCsync (from Espresso) - removed USB Mount - added ProximitySensor (from Tom Reay) - moved HtcPlurk to /data - added HtcContact Widget - added Nav Launcher (to /data/app) v1.7 - SU Permissions fixed - Market fixed, changed build.prop a bit - Nexus bootscreen added, thanks to Kendog2@XDA for his work on that! - GenieWidget from Nexus added and working - Brut.ALL's Modified Maps for navigation added (requires Nav Launcher 2.1.3 from Market) - HTCWeather & Weather widget removed due to the GenieWidget addition v1.6 - A2SD added (need to be manually enabled, read first post) - Some apps moved to data/app for easy uninstall - Added AOSP's Gallery app - Added SlideMe app store - Corrected Jbed error - Maps 3.3.1 - Zipaligned apk and jar files, may improve performances - Added wifi tether + Some other things I forgot v1.5 - Commuity release - One full update and one no-wipe update for thoose flashing over 1.4 BOTH VERSIONS: - Widgets fixed - Mount USB added - Added Facebook app FULL VERSION -New apns list V1.4 - corrected com.htc.bgp error - added htc widgets - added some htc apps - added some htc configuration (weather, location etc.) - rosie from HTC's 24/11/2009 test build - APN list (is it latest one?) V1.3 - fresh build on HTC's 03/12/09 test build - added gapps - added calendar - added rosie (still buggy) - added htc apps, ime etc. - added youtube V1.1 - V1.2 - internal buggy builds V1 - 2-12-2009 - first release Modifié 24 décembre 2009 par johndoe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gutsu Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 Des retours... Des retours !! :p Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragonn Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 Je vais tester mais faut t'il refaire la sauvegarde NANDROID si je l'ai déjà fait pour ma première rom modaco? ou il suffit juste faire un wipe et d'installer la rom? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
belgiancynic Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 des screenshot ? J'attend un retour pour test. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gutsu Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 Je vais tester mais faut t'il refaire la sauvegarde NANDROID si je l'ai déjà fait pour ma première rom modaco? ou il suffit juste faire un wipe et d'installer la rom? Non, c'est pas la peine du moment que tu as les dernières infos... Par contre, je la ferais quand même pour avoir une save de la rom 3.0. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cheap Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 J'aurais bien testé pour voir l'avancement du travail par curiosité, mais franchement la fleme de créer un compte sur le forum pour ça ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Profete162 Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 Je suis étonné de ne pas voir une tempête de réactions et de testeurs face à ce post ( peut-être la prudence..lol) Je me lancerai la dessus ce w end et partagerai mes impressions. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cheap Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 si t'as trouvé un autre lien pour la ROM ... :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 (modifié) J'ai mis la ROM mais il ne bootait pas (resté 15minutes sur HTC (meme s'il y a eu l'animation Hero avec le Droid et la petite sonnerie). Je remet donc la Modaco 3.0 ;) Modifié 4 décembre 2009 par Zoozloz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cheap Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 tu as wipe ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 (modifié) Je m'appretais a re-abandonner mais après 10min il s'est démarré, j'éditerais ce message pour mettre mes commentaires :). En tout cas soyez patient :D. Installation : Tout se passe bien, la possibilité de choisir quand le téléphone se synchronise (Wifi + Mobile, Wifi ou manuellement) donc pratique pour ceux qui n'ont pas d'abonnement 3G et quui ne veulent synchroniser qu'en Wifi. Clavier un peu lent à réagir (quand on appuye vite). SInon tout s'est bien passé. :) Barre de Notifications : L'icone GMail a changé et c'est désormais le logo de GMail en Noir et Blanc (l'enveloppe rouge habituelle mais le rouge > noir). Je n'ai pas la barre de notifications transparente contrairement aux anciennes versions de cette 2.1 GMail : Aucun changement, pas de multitouch... Musique : Pas de changement dans l'interface et un beau "Force Quit" lorsque l'on veut afficher les chansons par listes et non par pochette. Applications installées : On a "Plurk" (icone en forme de jambon ^^") et un "RSS Reader" avec une icône ressemblante auy style HTC donc peut etre une nouveauté de Sense 2.1 :D ! Je confirme qu'il s'agisse d'une application HTC car l'interface est similaire aux autres. Market : Alors on se retrouve avec la nouvelle interface du Market (celle apparue avec la 1.6), après un loooooooong "chargement en cours" les applications apparaissent ! Cela change radicalement du market 1.5 et renforce une idée de maturité du Market (suspens pour le 11 décembre ! :D) Une mise à jour de Google Maps est disponible (pour la Navigation il me semble). Finalement j'ai une "Erreur d'installation" : "La signature du fichier du package est incorrecte". Donc pour avoir Navigation, il faudra télécharger par d'autres moyens :p RSS Reader : L'application intègre des flux intégrés suivante différentess catégories. J'ai sélectionné 01Net Actualités, après une recherche du RSS, cela s'affiche correctement ! Un beau design pour l'application ! Dans les widgets HTC il y a l'apparition de "News", cela doit etre en rapport mais quand je veux mettre le widget, cela me met une erreur "RosieUtility". Navigateur : Alors là par cotnre c'est lent, le navigateur détecte s'il existe des flux RSS dans la page avec une petite icone dans la barre URL. La barre de chargement comporte bien l'animation verte avec des petites étoiles, encore une fois HTC a soignée l'UI ! :) Le multitouch est aussi réactif que sur les ROMs actuels (difficile de faire mieux :)) Cependant dans les paramètres du navigateur, tout n'est pas totalement traduits en francais (cela se retrouve un peu partout). On peut activer ou désactiver le chargement de Flash durant la navigation. Il semblerait qu'il y ait l'option "Enable plugins" et donc cela peut présager l'ajout de pack au navigateur de base. Avis Sur la lenteur : Ca va encore je trouve, je m'attendais à d'avantage de lags s'agissant d'une version bogguée. GMaps réagit bien (je n'ai pas trouvé Navigation...) Par contre certains applications lags meme si cela ne se ressent pas trop dans l'interface. Téléphonie : Les touches durant un appel ont changés à l'écran. TOUS Les contacts facebook (ceux qui ont ajouté leur numéro sur le site bien sur) sont automatiquement synchronisés dans la liste des contacts possible ! Pour vous rassurer : l'HTC Hero téléphone avec cette ROM ! :D SMS : l'affichage des SMS reste identique et encore une fois il envoie bien des SMS :D Widget : Meme si pour le moment les widgets bug (on ne peut pas en rajouter), on voit l'apparition d'un bouton "Get more HTC Widgets", cela charge mais un message nous disant "unable to download data" apparait. En tout cas là encore, cela laisse présager un bon suivi d'HTC pour son interface Sense ! :D Que du bonus ! :D. On peut utiliser les widgets mis par défaut sur chaque thème mais cela bug pour les ajouter mais sinon ils sont bien là. Une petite "animation" lorsque l'on appuye sur la touche Menu pour revenir au bureau, la fenetre précédente glisse vers la gauche pour laisser place au bureau. Twitter : On ne voit plus l'application "Peep" d'HTC et il n'y a plus de Twitter dans la liste des widgets HTC. PS: Je ne sais pas faire d'impression écran sur mon Hero, désolé. Modifié 6 décembre 2009 par Zoozloz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragonn Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 Ca lag méchant? et tout marche (sms, appel)? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 Ca lag méchant? et tout marche (sms, appel)? Pour le lags comme je l'ai indiqué ca reste raisonnable, je m'attendais à que cela soit plus lent. Mais bon il y a quand meme une différence comparé à nos ROMs actuelles. Pour les fonctions SMS/Appels, pas encore testé, je vais le faire bientôt :) (là je découvre l'appli' RSS qui me parait étrange :)) J'aimerais vous mettre des screens mais je sais pas faire :(. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 4 décembre 2009 Auteur Share Posté(e) 4 décembre 2009 pour les screens y en a un gratos qui demande aucune pretention info picme il me semble -- Posté depuis BBFoC HTC Hero/hero Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 Ah c'ets bon, je vais vous mettre des screens :) Merci Johndoe ! :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragonn Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 J'aurais une question quand tu fais le "pincement" sur l'ecran de départ ce passe quelque chose? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 (modifié) J'aurais une question quand tu fais le "pincement" sur l'ecran de départ ce passe quelque chose? J'ai oublié :s Je suis repassé sur Modaco 3.0 car je ne pouvais pas monter ma carte SD et voir les images prises de la 2.1 dessus. Voici les screenshoot en question : Nouvelles Appli' RSS Reader Navigateur La barre URL apparait (comme sur l'iPhone :p) lorsque l'on remonte la page web tout en haut. Plutot pratique :). Notez l'icone indiquant un flux RSS :). Menu (La lecture des SMS en francais est absolumment bluffante ! Modifié 4 décembre 2009 par Zoozloz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
aluxzen Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 j'ai testé la rom ce soir...ca marche mais ca rame...passer d'une modaco à celle-ci est un grand retour en arrière d'un point de vu fluidité générale, mais soulignons l'effort des ces chefs qui font avancer les choses :) Alex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 4 décembre 2009 Share Posté(e) 4 décembre 2009 je suis repasse en 2.1 pour vérifier le mode exposé et IL MARCHE ! Même un petit pinch declenche le mode, vraiment pratique ! -- Posté depuis BBFoC Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
farlow Posté(e) 5 décembre 2009 Share Posté(e) 5 décembre 2009 D'après examiner.com la rom officielle 2.1 sortirait vers noël. http://www.examiner.com/x-11295-LA-Gadgets-Examiner~y2009m12d4-HTC-Hero-Official-Android-21-update-by-Christmas Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akex Posté(e) 5 décembre 2009 Share Posté(e) 5 décembre 2009 Si c'est comme pour le Eris (le hero aux us) alors la maj sera dispo normalement (d'après HTC) au premier trimestre 2010. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Profete162 Posté(e) 6 décembre 2009 Share Posté(e) 6 décembre 2009 Mhhh, je viens de voir les retours et la seule chose qui m'inquiete est qu'il impose de télécharger TOUS les contacts Facebook par défaut... Ce qui est un peu emmerdant quand on ne veut avoir dans sa liste de contact que 2 ou 3 pourcents de nos contacts dans le téléphone. Quelqu'un qui a essayé cette ROM peut-il confirmer? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 6 décembre 2009 Share Posté(e) 6 décembre 2009 Mhhh, je viens de voir les retours et la seule chose qui m'inquiete est qu'il impose de télécharger TOUS les contacts Facebook par défaut...Ce qui est un peu emmerdant quand on ne veut avoir dans sa liste de contact que 2 ou 3 pourcents de nos contacts dans le téléphone. Quelqu'un qui a essayé cette ROM peut-il confirmer? Juste lire mon feedback juste au dessus : "Les contacts facebook (ceux qui ont ajouté leur numéro sur le site bien sur) sont automatiquement synchronisés dans la liste des contacts possible !" :/ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 6 décembre 2009 Share Posté(e) 6 décembre 2009 C'est vrai que c'était pas totalement clair, j'ai édité :D. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zoozloz Posté(e) 6 décembre 2009 Share Posté(e) 6 décembre 2009 (modifié) Je penses qu'HTC a pensé à ce détail. Attendons de voir :D En tout cas c'est fou toutes les nouveautés de Sense, à coté de cela, tous les mobiles Android paraissent "simples" et sans "ame". Bourse, Météo, NewsReader, Contact Facebook, Exchange, Appli Email et j'en passe :p Cette phrase est une connerie : Meme le Droid (qui n'a pas le multitouch :p) ne m'intéresse pas au final. :D Modifié 6 décembre 2009 par Zoozloz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
