Vache Posté(e) 30 janvier 2011 Share Posté(e) 30 janvier 2011 Metalounay 1.1 Acerless Update 1.1 : -Based on Acer_LiquidMetal_1.100.05 --Updated Apps --Updated Framework --Updated some libs -Fix Charging icon -Fix sync icon -Added many scripts from malez --Support now App2SD --Preconfigured Apps and Settings --ZipAlign @ boot --Backup/Restore SMS -Added scripts to enable/disable app2sd -Added scripts to use Camera key as next song or wake up -Updated GingerBread Theme -Now using ADW as default launcher -Updated boot -Updated Google Voice -Updated Barcode Scanner -Removed useless *.png from framework-res You will find a folder named "scripts" on your homescreen. There is some usefull in it, like :a2sd on/off : to move apps to SD Ext ad2sd on/off : to move apps and data to SD Ext nextOn/Off : to use focus key as next song wakeOn/Off : to use focus key to wake up the phone backup/retore/purge SMS How to enable apps2sd :Backup important files from your SDCard Reboot in recovery Go in "Partition sdcard" menu, and choose Partition SD Set Swap size to 0, and choose the size of the SD Ext for your apps Reboot the phone, use the provided scripts to activate apps2sd Reboot. Full changelog : http://vache-android.com/files/Metal/changelog.txt How to install : --Reboot in recovery --NANDROID --Wipe ALL --Flash --Reboot Testée et fonctionnelle (sans Radio FM) sur : Acer_LiquidMetal_1.000.23_EMEA_GEN1 Acer_LiquidMetal_1.001.01_EMEA_GEN1 Acer_LiquidMetal_1.001.02_EMEA_GEN1 Acer_LiquidMetal_1.001.05_EMEA_GEN1 Acer_LiquidMetal_1.001.06_EMEA_GEN1 Avec Radio FM : Acer_LiquidMetal_1.100.00_EMEA_GEN1 Acer_LiquidMetal_1.100.05_EMEA_GEN1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
