Problème de root
GoxThai
Je voudrais avoir votre aide pour le root de mon htc legend depuis hier soire je cherche mais j'ai trouvé aucune solution , Alors mon problème c'est quand je lance crackin.bat j’obtiens une succession d'erreur est le htc redémarre plusieurs fois.Biensure j'ai bien réussi a faire la Goldcard mais quand je l’insére dans le htc il me dit que la carte est endommagée merci de m'aidé.
C:\androidSDK>crackin.bat
"Copying tools"
adb server is out of date. killing...
* daemon started successfully *
936 KB/s (698452 bytes in 0.728s)
488 KB/s (76044 bytes in 0.152s)
1144 KB/s (655360 bytes in 0.559s)
"Freeing primary PERM linker"
error: protocol fault (no status)
* daemon not running. starting it now on port 5037 *
** daemon still not runningerror: cannot connect to daemon
rm failed for /data/DxDrm/fuse/*, No such file or directory
rm failed for /data/DxDrm/fuse, No such file or directory
rmdir failed for /data/DxDrm/fuse/, No such file or directory
cannot create /data/DxDrm/fuse: directory nonexistent
Unable to chmod /data/DxDrm/fuse: No such file or directory
"Freeing secondary PERM linker"
rmdir failed for /data/DxDrm, No such file or directory
error: device offline
link failed File exists
ADB server didn't ACK
* failed to start daemon *
error:
"Rebooting to normal mode to unlock CHMOD links"
error:
rm failed for /data/DxDrm, No such file or directory
link failed Permission denied
"Rebooting to normal mode to downgrade ROM"
/dev/mtd/mtd0: Permission denied
cr--rw---- 1 1001 2002 90, 0 Feb 12 19:59 /dev/mtd/mtd0
error writing misc: Permission denied
"Freeing links"
rm failed for /data/dontpanic, Permission denied
C:\androidSDK>cd /
