Gmail disparu ?
Bonjour @ tous,
Je viens de reboot mon Desire, et il me dit que Gmail n'est plus installé sur mon smartphone. De plus il a disparu de mon market ! Des idées ? Suis-je le seul avec ce problème ?
EDIT : il n'est même plus dispo sur la page officiel du Market !! https://market.android.com/developer?pub=Google+Inc.&start=0&num=12
C'est bon j'ai ma réponse ! http://www.google.com/support/forum/p/Google+Mobile/thread?tid=238802989b888e9c&hl=en
Hi folks,
We're aware that the updated Gmail app which came out yesterday in Market (version 2.3.4) is crashing for some users. There is a bug that only affects users who installed Gmail 2.3.4 over Gmail 2.2. In other words, if you had Gmail 2.3 or Gmail 2.3.2 installed prior to updating yesterday to 2.3.4, you aren't affected.
As a workaround for those who might be stuck with this crashing version of Gmail, we recommend uninstalling the update ( < Home > >Settings > Applications > Manage applications > Gmail > Uninstall updates).
We've removed Gmail from Market for the time being, and we're working as fast as we can to patch the app.
Apologies for any inconvenience this may be causing.
Regards,
Ethan
