[Wopad][ROM ]FroYo 2.2 (root) [13/03/11]
Re,
voili une FroYo 100% fonctionnelle,cet exploit n'est pas de moi donc un grand merci a Li0nHeart du Slatedroid Forum.
j'ai donné un p'ti coup de main a son créateur afin de rendre opérationnelle son système pour qu'il soit compatible avec notre Wopad a écran Capacitif ;)
Change log:
v0.6.1 - 080311
- Added sensors.rk28board.so
- Fixed orientation
- Updated /system/bin/wpa_supplicant file
- Updated Market 2.3.3
- Removed RotateD.apk
v0.5c - 110211
- Added the necessary binaries to make jit work (thanks Lfd)
- Removed MidSettings.apk because it was messing up the Settings Menu after a QuickBoot reboot
v0.5b
- enabled multi-touch
- removed no network coverage icon in status bar
- removed no network coverage from lock screen
v0.5a (Needs full wipe)
- added RotateD.apk, which allows for manual rotation to Portrait or Landscape. For this to work you need to enable the option Preferences - General - Sensor Rotation in Zeam.
- Mounted /ext3 system also on first boot, so no need to boot again after first boot
- Fixed Market using gapps from Archos 7HT v2 Froyo.
- Fixed Market also provides all Google apps, I am missing some apps though I think (can't find Angry Birds)
- Replaced Market, Gtalk and Gmail with current versions
- Added compcache script
- For Market Fix, sometimes it goes to 2.1 style Application menu (don't know why) if so, press Menu, Filter, All
v0.4c
- Updated recovery.img (by melvinz)
- A lot of symlinks in /system/bin to busybox
- dalvik-cache bound on /cache/dalvik-cache (in /temp/check_ext3)
- swappiness setting (in /temp/check_ext3)
- Market WORKAROUND : mount pad to PC, in other words, make sure NAND flash is unmounted. Now Market works.
v0.4b
- Fixed SDcard issue. Brings back Market not wanting to install. APKs are downloaded to /mnt/sdcard/download . You can install them from there with the Explorer until this is fixed.
- Angry Birds (and probably all big apk's) want to install to sdcard. This fails. No solution yet.
v0.4
- added extra /system partition which gets copied on first boot. First boot takes longer (5-10 minutes). When fully booted, reboot again and you'll have an rw /system
- Replaced Launcher with Zeam (my launcher of choice)
- Market is working
- For full market access, see below.
- ANGRY BIRDS starting to work-> after starting the game, just switch the screen off and on, and the game is visible. I think Compatibilty Mode also needs to be turned off in SpareParts.. it's slow though.
v0.2
- Changed bootloader back to version 5.00 (the one in Flip and Feu's ROM), just to be safe
- added youtube, midsettings.apk, quickboot.apk
- jithack by LeFeudeDieu
v0.1
- used kernel.img from a wopad rom
- rooted
- slightly enlarged /data from more room there for apps and so on.
[ROM]FroYo 2.2 v0.6.1 :
http://code.google.com/p/wopad-froyo/downloads/detail?name=TR718D-Froyo-2011-03-08-rls-0.6.1.img&can=2&q=
Le forum et moi-même ne serions être tenue responsable en cas de mauvaises manipulations (BRICK).
Re,
voili une FroYo 100% fonctionnelle,cet exploit n'est pas de moi(un grand merci a Li0nHeart).
j'ai donné de l'aide a son créateur afin de rendre opérationnelle son système pour qu'il soit compatible avec notre Wopad a écran Capacitif ;)
[surligne]Change log[/surligne]:
Vous devez re-booter aprés install,pour rendre le système monté en écriture
Zut, donc pas compatible avec la flytouch 2 :mad:
