mankey Posté(e) 22 mars 2011 Share Posté(e) 22 mars 2011 Pour commencer, bonjour nouveau sur le forum , je ne suis pas sur d'avoir poster au bonne endroit, je m'en excuse si s'est le cas ! Je possède un Samsung Galaxy S sous Andoid 2.2 J'ai installer il y as quelque temps une application pour faire les nœud de cravates et l'antivirus ma indiqué que s'était un "Malware" et ma proposer de la désinstaller. Jusque la ok! Mais le soucis, j'ai reçu un mail ou je ne comprend pas vraiment tout qui est le suivant: You are receiving this message to inform you of a critical issue affecting your Android Market account. Hello, We recently discovered applications on Android Market that were designed to harm devices. These malicious applications ("malware") have been removed from Android Market, and the corresponding developer accounts have been closed. According to our records, you have downloaded one or more of these applications. This malware was designed to allow an unauthorized third-party to access your device without your knowledge. As far as we can determine, the only information obtained was device-specific (IMEI/IMSI, unique codes which are used to identify mobile devices, and the version of Android running on your device). However, this malware could leave your device and personal information at risk, so we are pushing an Android Market security update to your device to remove this malware. You will soon be receiving a notification on your device that says "Android Market Security Tool March 2011" has been installed. You are not required to take any action from there, the update will automatically run. You may also receive notification(s) on your device that an application has been removed. Within 24 hours of receiving the update, you will receive a second email confirming its success. To ensure this update is run quickly, please make sure that your device is turned on and has a strong network connection. For more details, please visit the Android Market Help Center at http://market.android.com/support/bin/a ... er=1207928 Que faut il vraiment faire pour résoudre le problème ???? Merci d'avance ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
CastleRoad Posté(e) 22 mars 2011 Share Posté(e) 22 mars 2011 Jete un petit coup d'oeil à cette news Frandroid : http://www.frandroid.com/62951/les-applications-malicieuses-du-market-sont-supprimees-des-telephones-infectes/ En gros tu ne vas pas tarder à recevoir une MAJ par push ;) Sinon il me semble que tu peux anticiper et la télécharger toi même mais il est préciser qu'il est préférable de la laisser venir tout seul Lien vers le commentaire Partager sur d’autres sites More sharing options...
Albert Fritz Posté(e) 22 mars 2011 Share Posté(e) 22 mars 2011 L'antivirus est pas vraiment utile sur android, je te conseille une appli comme cia qui t'oblige a confirmer l'instalation d'une application avant que celle ci se fasse Lien vers le commentaire Partager sur d’autres sites More sharing options...
mankey Posté(e) 23 mars 2011 Auteur Share Posté(e) 23 mars 2011 J'ai bien regarder le lien mais moi je n'est pas reçu d'autre mail que celui du dessus ! Pas reçu de mise a jours ou de correctif ! Bisard non ? Le seul truc j'ai fait ma mise a jour du micrologiciel en version 2.2.1, c tout ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
