finger paint
mohammedlaifi
salut tout le monde je coince depuis un bout de temps dans le fameux finger paint je sui novice dans android et java et je veux inserer une image en arriere plan dans mon application mais le prob c ke l'image ne s'affiche pa sur tt l'ecran de mon terminal et voila mn code
package com.dessin;
import android.app.Activity;
import android.content.Context;
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
import android.graphics.BlurMaskFilter;
import android.graphics.Canvas;
import android.graphics.Color;
import android.graphics.EmbossMaskFilter;
import android.graphics.MaskFilter;
import android.graphics.Paint;
import android.graphics.Path;
import android.graphics.PorterDuff;
import android.graphics.PorterDuffXfermode;
import android.os.Bundle;
import android.view.Menu;
import android.view.MenuItem;
import android.view.MotionEvent;
import android.view.View;
public class dessin extends GraphicsActivity
implements ColorPickerDialog.OnColorChangedListener {
 @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(new MyView(this));
        mPaint = new Paint();
        mPaint.setAntiAlias(true);
        mPaint.setDither(true);
        mPaint.setColor(0xFFFF0000);
        mPaint.setStyle(Paint.Style.STROKE);
        mPaint.setStrokeJoin(Paint.Join.ROUND);
        mPaint.setStrokeCap(Paint.Cap.ROUND);
        mPaint.setStrokeWidth(12);
        mEmboss = new EmbossMaskFilter(new float[] { 1, 1, 1 },
                                       0.4f, 6, 3.5f);
        mBlur = new BlurMaskFilter(8, BlurMaskFilter.Blur.NORMAL);
    private Paint       mPaint;
    private MaskFilter  mEmboss;
    private MaskFilter  mBlur;
    public void colorChanged(int color) {
        mPaint.setColor(color);
    public class MyView extends View {
        private static final float MINP = 1f;
        private static final float MAXP = 1f;
        private Bitmap  mBitmap;
        private Canvas  mCanvas;
        private Path    mPath;
        private Paint   mBitmapPaint;
        private Bitmap image;
        private Paint paint;
        public MyView(Context c) {
            super(c);
            mBitmap = Bitmap.createBitmap(1024, 1024, Bitmap.Config.ARGB_8888);
            mCanvas = new Canvas(mBitmap);
            mPath = new Path();
            mBitmapPaint = new Paint(Paint.DITHER_FLAG);
        @Override
        protected void onSizeChanged(int w, int h, int oldw, int oldh) {
            super.onSizeChanged(0, 0, oldw, oldh);
        @Override
        protected void onDraw(Canvas canvas) {
            canvas.drawColor(0xFFAAAAAA);
            canvas.drawBitmap(mBitmap, 0, 0, mBitmapPaint);
            canvas.drawPath(mPath, mPaint);
          Bitmap _scratch = BitmapFactory.decodeResource(getResources(), R.drawable.exea);
            canvas.drawColor(Color.WHITE);
          canvas.drawBitmap(_scratch,0, 100, null);
        private float mX, mY;
        private static final float TOUCH_TOLERANCE = 4;
        private void touch_start(float x, float y) {
            mPath.reset();
            mPath.moveTo(x, y);
            mX = x;
            mY = y;
        private void touch_move(float x, float y) {
            float dx = Math.abs(x - mX);
            float dy = Math.abs(y - mY);
            if (dx >= TOUCH_TOLERANCE || dy >= TOUCH_TOLERANCE) {
                mPath.quadTo(mX, mY, (x + mX)/2, (y + mY)/2);
                mX = x;
                mY = y;
        private void touch_up() {
            mPath.lineTo(mX, mY);
            // commit the path to our offscreen
            mCanvas.drawPath(mPath, mPaint);
            // kill this so we don't double draw
            mPath.reset();
        @Override
        public boolean onTouchEvent(MotionEvent event) {
            float x = event.getX();
            float y = event.getY();
            switch (event.getAction()) {
                case MotionEvent.ACTION_DOWN:
                    touch_start(x, y);
                    invalidate();
                    break;
                case MotionEvent.ACTION_MOVE:
                    touch_move(x, y);
                    invalidate();
                    break;
                case MotionEvent.ACTION_UP:
                    touch_up();
                    invalidate();
                    break;
            return true;
    private static final int COLOR_MENU_ID = Menu.FIRST;
   // private static final int EMBOSS_MENU_ID = Menu.FIRST + 1;
    //private static final int BLUR_MENU_ID = Menu.FIRST + 2;
    private static final int ERASE_MENU_ID = Menu.FIRST + 3;
    private static final int SRCATOP_MENU_ID = Menu.FIRST + 4;
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        super.onCreateOptionsMenu(menu);
        menu.add(0, COLOR_MENU_ID, 0, "Couleurs").setShortcut('3', 'c');
     //   menu.add(0, EMBOSS_MENU_ID, 0, "Emboss").setShortcut('4', 's');
      //  menu.add(0, BLUR_MENU_ID, 0, "Blur").setShortcut('5', 'z');
        menu.add(0, ERASE_MENU_ID, 0, "Efaccer").setShortcut('5', 'z');
        menu.add(0, SRCATOP_MENU_ID, 0, "SrcATop").setShortcut('5', 'z');
        /****   Is this the mechanism to extend with filter effects?
        Intent intent = new Intent(null, getIntent().getData());
        intent.addCategory(Intent.CATEGORY_ALTERNATIVE);
        menu.addIntentOptions(
                              Menu.ALTERNATIVE, 0,
                              new ComponentName(this, NotesList.class),
                              null, intent, 0, null);
        return true;
    @Override
    public boolean onPrepareOptionsMenu(Menu menu) {
        super.onPrepareOptionsMenu(menu);
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        mPaint.setXfermode(null);
        mPaint.setAlpha(0xFF);
        switch (item.getItemId()) {
            case COLOR_MENU_ID:
                new ColorPickerDialog(this, this, mPaint.getColor()).show();
                return true;
            /*case EMBOSS_MENU_ID:
                if (mPaint.getMaskFilter() != mEmboss) {
                    mPaint.setMaskFilter(mEmboss);
                } else {
                    mPaint.setMaskFilter(null);
                return true;
            case BLUR_MENU_ID:
                if (mPaint.getMaskFilter() != mBlur) {
                    mPaint.setMaskFilter(mBlur);
                } else {
                return true;*/
            case ERASE_MENU_ID:
                mPaint.setXfermode(new PorterDuffXfermode(
                                                        PorterDuff.Mode.CLEAR));
                return true;
            case SRCATOP_MENU_ID:
                                                    PorterDuff.Mode.SRC_ATOP));
                mPaint.setAlpha(0x80);
                return true;
        return super.onOptionsItemSelected(item);
svp aidez moi :(
  • 5 months later...
Salut
c'est peut etre un peu tard, mais je penses que la solution pour toi est d'utiliser le meme "paint" quand tu draw l'image pour tes traits.
j'ai du mal à être clair.
mais par exemple pour l'image :
Bitmap _scratch = prepareBitmap(getResources().getDrawable(R.drawable.image1), mCanvas.getWidth()-20, mCanvas.getHeight()-20);
            mCanvas.drawColor(Color.BLACK);
            mPaint.setARGB(0xff, 0, 0, 0);
            mCanvas.drawPaint(mPaint);
            mCanvas.drawBitmap(_scratch, 10, 10, mPaint);
        	invalidate();
et pour tes mises à jour :
@Override protected void onDraw(Canvas canvas) {
    	if (mBitmap != null) {
            canvas.drawBitmap(mBitmap, 0, 0, mPaint);
bon courage
