loupio Posté(e) 23 mars 2011 Share Posté(e) 23 mars 2011 (modifié) La cronos 2.2.0.0 sense de Feeyo Hello community,As promised an 2.1.3 updated with OTA and kernel has been updated. Please note that if you want support then please use the Support thread. Note: Please reboot after any flash you do. This is very important. How to flash this rom: 1. Wipe 2. Flash ROM Release Notes: 15 March 2011 | Cronos 2.2.0.0 Sense Eclair by C0mpu13rFr34k * Patched up to latest OTA update * Latest Cronos EVO3 kernel added * Updated EGL * Fixed BusyBox * HTC Wallpaper mess cleaned up and Cronos wallpaper added * Google Maps and Street updated * Market updated * Moved some apps to /data 10 Feb 2011 | CD 2.1.4.1 Sense Eclair: * Updated kernel to latest EVO. * libegl_qcom updated. * Improvements to governor. * Improvements to IO Scheduler. 2.1.4.1 Repacked - 09 Oct 2010 * Updated to latest EVO kernel * Updated SuperUser App * Updated to latest gapps. * Updated to latest HotFix 01 2.1.4.1 Fix 0 * Fixed sdcard issue. 2.1.4.1 * Fixed Sense Crashes. * More Stable Build. * Fixed Syncing. 2.1.4 * Latest Opt-46 kernel included. * Tweaked build.prop * Latest OTA added. * Flash updated to 10.1 2.1.3 * Fixed /etc/init.d scripts. (Typo fixes) * kernel update: ** Memory leak ** Buffer overflow * Version Fix. 2.1.2 * Kernel tuned for more performance. * Improved Sound support. * Hardware accelerated Touchscreen. * Overclockable to 768Mhz. * Battery life is superior. * governor is conservative (default) * very fast refreshing of caching. * Low latency. * init.d script tweaked. * Improved HW3D (Needs testing though) * gpio patched up. * gzip fix added. * This kernel will also be available as a kernel update only in the kernel patches thread. 2.1.1 * Long boot Fix. * Youtube HQ Patched. 2.1 * Android 2.1 Sense, WWE release * Cronos Droid Wallpaper by Swiftwork * Lock Wallpaper Fixed * Wallpaper change Fixed * Fully deodexed by Bryanarby, Riemervdzee * including voicesearch and voicecall * JBED Support * Optimized apk's in app and framework. reducing memory usage * OpenVPN support * Some Optimization scripts added to /etc/init.d * New Kernel 2.6.29-33 with less frequency jumps * Kernel tweaked for a bit more performance * Kernel 768Mhz OC possibility * Kernel locked to 537Mhz when booting * Less Battery Draining Improved. * Update gmaps * tweaked up_threshold setting by Andro1d * Added conservative governor Note 1: First 2 boots can be a bit long as it will start doing some internal optimizations. Note 2: After installing new software on your Android the system will auto optimize it after a reboot. Download Full ROM (Latest): http://cronos.bertol.de/Cronos_2.2.0.0_Sense_Eclair.zip MD5SUM: 82cf8e641f5184ffbed91b623ab9e023 Download Default QComLibs Patch: http://www.multiupload.com/OLMBJ0O8YV Download Default Font Patch: http://www.multiupload.com/HA6S0X1K3B HTC_CIME(optional): http://forum.xda-developers.com/attachm ... 1275881210 I want to thank everyone for the support they are giving the Cronos Development! Modifié 23 mars 2011 par loupio Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
armand78990 Posté(e) 23 mars 2011 Share Posté(e) 23 mars 2011 Quelqu’un l'a t'il testé ? y a t'il des bug ? Je suis actuellement sur Cronos Ginger 1.9.3 qui me satisfait mais sens me manque tout de même Cordialement Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
loupio Posté(e) 23 mars 2011 Auteur Share Posté(e) 23 mars 2011 (modifié) Quelqu’un l'a t'il testé ? y a t'il des bug ? Je suis actuellement sur Cronos Ginger 1.9.3 qui me satisfait mais sens me manque tout de même Cordialement Je suis dessus depuis 2 jours maintenant, c'est fluide et rapide pas de bugs ni FC pour le moment. Je dois dire que la batterie baisse un petit peu plus rapidement que sur une ROM Ginger, mais pour sense je prends sans attendre :) Modifié 23 mars 2011 par loupio Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
armand78990 Posté(e) 23 mars 2011 Share Posté(e) 23 mars 2011 Je suis dessus depuis 2 jours maintenant, c'est fluide et rapide pas de bugs ni FC pour le moment. Je dois dire que la batterie baisse un petit peu plus rapidement que sur une ROM Ginger, mais pour sense je prends sans attendre :) merci pour le retour. Je crois que je vais l'essayer rapidement car SENS il y a pas photo c'est vraiment bien . Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
loupio Posté(e) 23 mars 2011 Auteur Share Posté(e) 23 mars 2011 merci pour le retour. Je crois que je vais l'essayer rapidement car SENS il y a pas photo c'est vraiment bien . c'est vrai :) sa fait plaisir de le retrouver après un bon bout de temps sur l' UI par défaut d'android. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mephisto Posté(e) 23 mars 2011 Share Posté(e) 23 mars 2011 (modifié) Oh ca me tente bien ca dis donc !!!!!! Je suis actuellement en CronosGinger 1.9.3, avez vous des retours sur cette ROM pour ceux ayant franchi le pas. Modifié 23 mars 2011 par Mephisto Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
loupio Posté(e) 23 mars 2011 Auteur Share Posté(e) 23 mars 2011 Oh ca me tente bien ca dis donc !!!!!! Je suis actuellement en CronosGinger 1.9.3, avez vous des retours sur cette ROM pour ceux ayant franchi le pas. Je suis dessus depuis 2 jours maintenant, c'est fluide et rapide pas de bugs ni FC pour le moment. Je dois dire que la batterie baisse un petit peu plus rapidement que sur une ROM Ginger, mais pour sense je prends sans attendre :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florian Posté(e) 27 mars 2011 Share Posté(e) 27 mars 2011 Bonjour a tous Je suis intéressé par cette ROM, je n'ai pas réussi a la trouver sur le forum XDA d'ou elle doit venir. J'en ai trouvé 2 avec Eclair + Sense, mais pour les 2 l'appareil photo ne marchait pas, est ce que ici il fonctionne? Quelqu'un a le lien vers le forum? Je sens que je vais me lancer, car effectivement android 2.3.3 c'est bien mais Sense me manque! Florian Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florian Posté(e) 27 mars 2011 Share Posté(e) 27 mars 2011 Voila j'ai finalement trouvé le lien: http://www.cronosproject.org/forum/viewtopic.php?f=58&t=279#p9871 Pas encore lu toutes les pages, et je ne sais pas encore si APP2SD est là ou pas... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
averroes42 Posté(e) 1 août 2011 Share Posté(e) 1 août 2011 Zut aucun lien ne marche!!!!!!! Moi qui voulait y migrer... :(( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
averroes42 Posté(e) 3 août 2011 Share Posté(e) 3 août 2011 Personne n'aurait un lien????????? Merci d'avance! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
