bonjour
suit au flash de mon teos en 2.2
jai essayer de installer lagfix mais impossible jai essayer plusieurs tuto et tous ne marche pas voisi le message :
Pushing required files to /sdcard.
* daemon not running. starting it now *
* daemon started successfully *
71 KB/s (0 bytes in 2297.000s)
21 KB/s (0 bytes in 1032.000s)
3 KB/s (0 bytes in 59.000s)
587 KB/s (0 bytes in 28180.000s)
295 KB/s (0 bytes in 9460.000s)
385 KB/s (0 bytes in 18520.000s)
833 KB/s (0 bytes in 93396.000s)
285 KB/s (0 bytes in 13708.000s)
301 KB/s (0 bytes in 9636.000s)
632 KB/s (0 bytes in 111336.000s)
1506 KB/s (0 bytes in 4001493.002s)
1526 KB/s (0 bytes in 976824.000s)
"Running lagfix now"
Enter apps partition size in megabytes (MB):1024
umount: can't forcibly umount /system/sdtemp: No such file or directory
umount: can't forcibly umount /system/sddata: Invalid argument
umount: can't forcibly umount /system/sdext: Invalid argument
Error: Partition doesn't exist.
Warning: WARNING: the kernel failed to re-read the partition table on
/dev/block/mmcblk0 (Device or resource busy). As a result, it may not reflect
all of your changes until after reboot.
Information: You may need to update /etc/fstab.
mkfs.vfat: lseek: Value too large for defined data type
mkfs.ext2: can't open '/dev/block/mmcblk0p2': No such file or directory
mount: mounting /dev/block/mmcblk0p2 on /system/sdext failed: No such file or di
rectory
dd: /system/sdext/data.ex2: No space left on device
mknod: /dev/loop10: File exists
mkfs.ext2: image is too small
mount: mounting /dev/loop10 on /system/sddata failed: Invalid argument
Lagfix did not apply. Restart your phone and try again.
mount: Device or resource busy
umount: can't umount /system/sddata: Invalid argument
umount: can't umount /system/sdext: Invalid argument
Lagfix Completed. Restart your Phone
Appuyez sur une touche pour continuer...
sa me mais sa maintenemt
mkdir failed for /data/lag, File exists
64 KB/s (0 bytes in 1032.000s)
880 KB/s (0 bytes in 28180.000s)
591 KB/s (0 bytes in 9460.000s)
578 KB/s (0 bytes in 18520.000s)
1459 KB/s (0 bytes in 93396.000s)
856 KB/s (0 bytes in 13708.000s)
602 KB/s (0 bytes in 9636.000s)
1391 KB/s (0 bytes in 111336.000s)
1337 KB/s (0 bytes in 4001493.002s)
763 KB/s (0 bytes in 976824.001s)
rm failed for /system/sddata, Device or resource busy
mkdir failed for /system/sddata, File exists
rm failed for /system/sdext, Device or resource busy
mkdir failed for /system/sdext, File exists
umount: can't forcibly umount /mnt/sdcard: Invalid argument
umount: can't forcibly umount /mnt/secure/asec: Invalid argument
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
125184 inodes, 499968 blocks
0 blocks (0%) reserved for the super user
First data block=0
Maximum filesystem blocks=4194304
16 block groups
32768 blocks per group, 32768 fragments per group
7824 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912
dd: can't open '/system/sdext/data.ex2': Invalid argument
losetup: /dev/loop10: No such file or directory
Filesystem label=
OS type: Linux
65536 inodes, 262144 blocks
First data block=0
8 block groups
8192 inodes per group
puis comme quioi c fini et faut que je redémarre
apres redemarage il me manque le 1 go mais avec le quadrant test sa apas bouger
