Invité lologuil Posté(e) 25 avril 2011 Share Posté(e) 25 avril 2011 A notre grand regret la team Cyanogen va arrêter le support du Hero. En effet, il n'y a plus de mainteneur et les créateurs de ROM basées sur CM ne reportent pas les bug rencontrés. Du coup le travail n'avance pas ou peu, ce qui les a incité à stopper le projet (du moins pour l'instant). Voici le message original : I would like to offer an Official status report on CM7 (Android 2.3) and CM support for the Hero GSM.As many of you know, Lox stepped away as CM Maintainer for your device sometime in January. Since then, we have continued to issue Nightlies, Betas and one ill-gotten stable build (which was subsequently pulled); all without an active maintainer dedicated to the Hero GSM. The team has come to the conclusion, that this is just not a sustainable and viable endeavor. With no active developer looking out for the GSM variant, items like that nasty memory leak sneak their way in. Additionally, it would seem that those in the Android community that do work on the CM source, and publish their own ROMS, are not contributing their fixes back to the CM source. Having a broken base serve as a stepping stone for closed fixed versions doesn't work for us, and is against our aims with CM. This decision is not irreversible, we simply would require commitment from a capable developer to maintain and manage the Hero vendor. Till that point, CM support for Hero GSM is hereby discontinued. ciwrl La fin définitive du Hero? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Geese Posté(e) 27 avril 2011 Share Posté(e) 27 avril 2011 C'est bien dommage, mais j'espère quand même qu'ils trouveront quelqu'un pour remplacer .. Comme il est écrit : "This decision is not irreversible" Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité lologuil Posté(e) 29 avril 2011 Share Posté(e) 29 avril 2011 Apparemment une partie de cet arrêt est du à Feeyo : http://forum.cyanogenmod.com/topic/15196-my-response-to-cronosproject-folks/ Feeyo a fermé le code source de ses rom chronos et n'a pas voulu aider la communauté cyanogen. Chronos étant basé sur Cyanogen, on est maintenant bloqué, plus de cyanogen ni de elelinux ni de chronos... Youpi!! L'ancien mainteneur du Hero chez cyanogen appelle au boycott des rom chronos, disant que c'est du warez : I discourage anyone to use that warez Rom and I encourage every developer here to contribute to CyanogenMod which is easy through http://review.cyanogenmod.com/ and explained here. Lien vers le commentaire Partager sur d’autres sites More sharing options...
badabim Posté(e) 6 mai 2011 Share Posté(e) 6 mai 2011 Du coup , qu'est ce que tu conseillerai comme ROM qui a le plus de chance d'evoluer ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 6 mai 2011 Share Posté(e) 6 mai 2011 Ce sujet n'est plus d'actualité... elelinux a repris la gestion du hero pour les roms cyanogen et pousse les modifications sur leur gitub les nightly builds et les roms elelinux resteront différentes sur certains point mais rien n'est mort Lien vers le commentaire Partager sur d’autres sites More sharing options...
