chopper69 Posté(e) 3 mai 2011 Share Posté(e) 3 mai 2011 (modifié) Bonjour à tous, En parcourant la toile, j'ai découvert un site qui détail très précisément les spécifications de la tablette Iconia Tab A500. Je vous fait par de ma petite découverte B) Url du site : Detailed Technical Specifications of Acer Iconia Tab A501 32GB Voici ce qu'on apprend : Detailed Technical Specifications of Acer Iconia Tab A501 32GB Brand: Acer Expected-Release:Date: May, 2011 Physical:Attributes Dimensions : 260 x 177 x 13.3 millimetres / 10.2 x 7 x 0.5 inches (width x height x depth) Bounding;Volume: 612.1 cubecentimetres Mass: 770 grams (battery included) Software_Environment Embedded+Operating+System: Google Android 3.0 Operating-System+Kernel: Linux 2.6.36.3 Microprocessor,_Chipset CPU-Clock: 1000 MHz CPU: NVIDIA Tegra 2 250 Width_of_Machine:Word: 32 bit CPU+Core: 2x ARM Cortex-A9 MPCore Instruction_Set: ARMv7-A Memory,:Storage-capacity RAM+type: LPDDR2 SDRAM RAM:capacity: 1024 MiB ROM:type: Flash EEPROM ROM_capacity: 30518 MiB ROM-capacity+in-bytes: 32 GB (billion bytes) Graphical-subsystem Display-Type: color transflective TFT display Display-Diagonal: 10.1 " (257 millimetres) Display-Resolution: 1280 x 800 (1024000 pixels) Viewable_Display_Size: 8.58 " x 5.36 " (217.94 x 136.21 millimetres) Pixel+density+(dot+pitch) 149.2 pixel/inch (0.17026 millimetre/pixel) Graphical;Controller: NVIDIA GeForce Video-out: 1920x1080 (1080p) resolution / HDMI Type D (HDMI 1.4) connector Audio_Subsystem Audio:Channel(s): stereo sound Microphone(s): mono sound Loudspeaker(s): stereo sound Audio:Output: 3.5mm plug Cellular_Phone Cellular+Networks: GSM850, GSM900, GSM1800, GSM1900, UMTS900, UMTS1900, UMTS2100 Cellular_Data-Links: GPRS, EDGE, UMTS, HSDPA, HSUPA Cellular-Antenna: Internal antenna Call_Alert: 40 -chord melody (polyphonic) Vibrating;Alert: Supported Speakerphone;: Supported Control_Peripherals Positioning+Device: Multi-touch screen Primary;Keyboard: Not supported Directional+Pad: Not supported Scroll+Wheel: Not supported Interfaces Expansion+Interfaces: microSD, microSDHC, TransFlash Supports High Capacity (SD 2.0/HC) memory cards with capacity of up to 32GB USB: USB 2.0 host/client, Hi-Speed (480Mbit/s) USB Series A connector Bluetooth-(802.15): Bluetooth 2.1 + Enhanced Data Rate, Internal antenna Wireless_LAN/Wi-Fi-(802.11): IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n Internal antenna Infrared+Gate: Not supported Multimedia;Broadcast Analog:Radio: Not supported Digital-Media+Broadcast: Not supported Built-in_Digital;Camera Sensor_Type: CMOS sensor Resolution: 2560 x1920 pixels (4.92MP) Autofocus_(AF): Supported Optical_Zoom: 1 x Macro;Mode: Not supported Built-in-Flash: mobile light (LED) Camcorder: 1920x1080 pixels Recordable+Image;Formats: JPG Recordable;Video_Formats: 3GP, MPEG4 Built-in:Secondary_Digital:Camera Sensor_Type: CMOS sensor Resolution: 1600 x1200 pixels (1.92MP) Camcorder: 0x0pixels Recordable:Image-Formats: JPG Power-Supply Battery+Technology: Lithium-ion polymer battery Battery_Build: Supported Estimated;Battery_Life: 8 hours Battery-Capacity: 3260 mAh Estimated+Average-Current: 408 mA Additional:Details Built-in_accelerometer: Supported Additional_Features: 1x USB A connector 1x micro-USB connector capacitive touch screen docking connector GPRS Class 10 EDGE Class 10 HSDPA 7.2 DLNA Bluetooth stereo audio profile (A2DP AVRCP) Dolby Mobile support image stabilizer face detection smile detection Google Maps Acer clear.fi Related:Page: http://www.acer.co.uk/ac/en/GB/press/2011/7745 Datasheet:State: Preliminary specifications Datasheet_Views: 6078 times Datasheet+Added: Mar 1, 11 14:06:24 Modifié 3 mai 2011 par chopper69 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
grandiosa Posté(e) 3 mai 2011 Share Posté(e) 3 mai 2011 un truc m interpelle hdmi 1.4 possibilité de gérer la 3D par mise à jour logiciel alors Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pilot83 Posté(e) 3 mai 2011 Share Posté(e) 3 mai 2011 j'ajoute a mon post, merci. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chopper69 Posté(e) 3 mai 2011 Auteur Share Posté(e) 3 mai 2011 Le 03/05/2011 à 11:23, pilot83 a dit : j'ajoute a mon post, merci. Mais je t'en prie, fais toi plaisir ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pilot83 Posté(e) 3 mai 2011 Share Posté(e) 3 mai 2011 Le 03/05/2011 à 11:39, chopper69 a dit : Mais je t'en prie, fais toi plaisir ;) c'est plus pour faire plaisir aux autres B) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zeyd Posté(e) 3 mai 2011 Share Posté(e) 3 mai 2011 Hsdpa ? On a une puce 3 g quoi ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
