xxx31fr Posté(e) 11 mai 2011 Share Posté(e) 11 mai 2011 include $(call all-subdir-makefiles) #CODECS := alac ape flac wav wv mpc #codec-makefiles = $(patsubst %,$(call my-dir)/%/Android.mk,$(CODECS)) #include $(call codec-makefiles) ifneq ($(NDK_ROOT),) LOCAL_PATH:=$(NDK_ROOT)/apps/lossless/project/jni else LOCAL_PATH:=apps/lossless/project/jni endif # library for Android < 9 include $(CLEAR_VARS) LOCAL_MODULE := atrack8 LOCAL_CFLAGS += -O2 -Wall -DBUILD_STANDALONE -DCPU_ARM -DAVSREMOTE -finline-functions -fPIC -D__ARM_EABI__=1 -DOLD_LOGDH LOCAL_C_INCLUDES += $(LOCAL_PATH)/Android/include LOCAL_SRC_FILES := std_audio.cpp LOCAL_ARM_MODE := arm LOCAL_LDLIBS := -llog \ $(LOCAL_PATH)/Android/lib/libutils.so $(LOCAL_PATH)/Android/lib/libmedia.so include $(BUILD_SHARED_LIBRARY) # library for Android api >= 9 include $(CLEAR_VARS) LOCAL_MODULE := atrack9 LOCAL_CFLAGS += -O2 -Wall -DBUILD_STANDALONE -DCPU_ARM -DAVSREMOTE -finline-functions -fPIC -D__ARM_EABI__=1 -DOLD_LOGDH LOCAL_CFLAGS += -DBUILD_GINGER LOCAL_C_INCLUDES += $(LOCAL_PATH)/Android/include LOCAL_SRC_FILES := std_audio.cpp LOCAL_ARM_MODE := arm LOCAL_LDLIBS := -llog \ $(LOCAL_PATH)/Android/lib/gingerbread/libutils.so $(LOCAL_PATH)/Android/lib/gingerbread/libmedia.so include $(BUILD_SHARED_LIBRARY) # common codecs & startup library include $(CLEAR_VARS) LOCAL_MODULE := lossless LOCAL_STATIC_LIBRARIES := alac ape flac wav wv mpc LOCAL_CFLAGS += -O2 -Wall -DBUILD_STANDALONE -DCPU_ARM -DAVSREMOTE -finline-functions -fPIC -D__ARM_EABI__=1 -DOLD_LOGDH # $(LOCAL_PATH)/Android/include LOCAL_C_INCLUDES += $(LOCAL_PATH)/Android/include LOCAL_SRC_FILES := main.c std_audio.cpp LOCAL_ARM_MODE := arm LOCAL_LDLIBS := -llog \ $(LOCAL_PATH)/Android/lib/libutils.so $(LOCAL_PATH)/Android/lib/libmedia.so include $(BUILD_SHARED_LIBRARY) a la compilation avec cygwin, j'ai ca : $ /cygdrive/c/androidndk4/ndk-build Compile++ arm : atrack8 <= /cygdrive/c/androidndk4/apps/lossless/project/jni/st d_audio.cpp SharedLibrary : libatrack8.so Install : libatrack8.so => /cygdrive/c/androidndk4/apps/lossless/project/ libs/armeabi Compile++ arm : atrack9 <= /cygdrive/c/androidndk4/apps/lossless/project/jni/st d_audio.cpp SharedLibrary : libatrack9.so Install : libatrack9.so => /cygdrive/c/androidndk4/apps/lossless/project/ libs/armeabi Compile++ arm : lossless <= /cygdrive/c/androidndk4/apps/lossless/project/jni/s td_audio.cpp make: *** No rule to make target `/cygdrive/c/androidndk4/apps/lossless/project/ bin/ndk/local/armeabi/libalac.a', needed by `/cygdrive/c/androidndk4/apps/lossle ss/project/bin/ndk/local/armeabi/liblossless.so'. Stop. soit une erreur pour generer lossless... en vous remerciant par avance!!!!!!!! Lien vers le commentaire Partager sur d’autres sites More sharing options...
