nexus35 Posté(e) 13 mai 2011 Share Posté(e) 13 mai 2011 (modifié) Nouveau BIN 3.016.00 Source modaco LiquidUsers Suivi de [ROM] Gingerounay 1.1/ 2.3.3 Avant tout : 1. Vous devez avoir installer le dernier bin GingerBread (3.016.00) que vous trouverez ici : http://localhostr.com/file/smkmP3q/Acer ... P-GEN2.zip - Utiliser cette version de Acer Download Tools pour l'installer : http://bit.ly/kH5C0C (ADT_Edit By Ma). 2. Vous devez installer la dernière version de la recovery pour GingerBread. V2.0 : http://bit.ly/kEbL7F http://bit.ly/l9lFK3 --------Based on the GingerBread leak (3.016.00), using stock kernel. (No O/C) ------Supported languages (imported translations for apps & framework-res from previous leak, it may be incomplet) : ------English, French, Deutsch, Spanish, Portuguese, Italian, Netherlands, Russian, Chinese, Chnise (simplified), ---Rooted ---App2SD (you can find some GScript scripts on your homescreen to activate it) ---Unsecure boot (to allow adb remount) ---Busybox ---Bash and other tools ---Optimized lowmemkiller settings ---Optimized Apps ---ES File Explorer / File Manager ---QuickBoot ---Move2SD Enabler (A2SD) ---CarHome with launcher ---HTC_IME ---Market unlocked (all apps) ---Terminal Emulator ---Updated Music app ---Updated Facebook & Twitter ---Updated Music app ---Added some ringtones and notification sounds ---Updated apps (Maps, Flash Player, Gmail....) ---New bootanimation Removed : Acer Clock Acer Nidus Acer Register Acer Registration Acer Sync Docs To Go RoadSync Spinlets UrFooz WaveSecure bootsound Books No O/C (we need kernel source) SuperUser Fix : http://localhostr.com/file/h9LRAGA/su_fix_signed.zip (A installer après la ROM) Merci à Vache !!! B) Modifié 14 mai 2011 par NEXUS35 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lagrenouilleemouvue Posté(e) 17 juin 2011 Share Posté(e) 17 juin 2011 (modifié) http://bit.ly/l9lFK3--------Based on the GingerBread leak (3.016.00), using stock kernel. (No O/C) ------Supported languages (imported translations for apps & framework-res from previous leak, it may be incomplet) : ------English, French, Deutsch, Spanish, Portuguese, Italian, Netherlands, Russian, Chinese, Chnise (simplified), ---Rooted ---App2SD (you can find some GScript scripts on your homescreen to activate it) ---Unsecure boot (to allow adb remount) ---Busybox ---Bash and other tools ---Optimized lowmemkiller settings ---Optimized Apps ---ES File Explorer / File Manager ---QuickBoot ---Move2SD Enabler (A2SD) ---CarHome with launcher ---HTC_IME ---Market unlocked (all apps) ---Terminal Emulator ---Updated Music app ---Updated Facebook & Twitter ---Updated Music app ---Added some ringtones and notification sounds ---Updated apps (Maps, Flash Player, Gmail....) ---New bootanimation Removed : Acer Clock Acer Nidus Acer Register Acer Registration Acer Sync Docs To Go RoadSync Spinlets UrFooz WaveSecure bootsound Books No O/C (we need kernel source) Quelqu'un peut m'aider ? Je suis bloqué à ce niveau là avec un téléphone en anglais :emo_im_undecided: . Je ne sais pas du tout comment mettre ces fichiers dans mon téléphone. Puis je n'arrive pas non plus à le rooter :( Modifié 17 juin 2011 par grenouilleemouvue Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
paugustin Posté(e) 17 juin 2011 Share Posté(e) 17 juin 2011 Quelqu'un peut m'aider ? Je suis bloqué à ce niveau là avec un téléphone en anglais :emo_im_undecided: . Je ne sais pas du tout comment mettre ces fichiesr dans mon téléphone. Au premier démarrage il doit te demander de choisir la langue. Sinon tu va dans paramètre (settings), language, select language. De quels fichiers parle-tu ? La liste au dessus ce sont des programmes déja présents dans la ROM. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
