florent38 Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 (modifié) --TripNMiUI "Iris" 1.7 Froyo! - ON THE ROAD TO REVOLUTION-- Source : Android.modaco jLets go for another sweet update! ROM: TripNMiUI "Iris" Froyo - Latest release 18-06-2011 - Rom version 1.7.* - Froyo 2.2.1 - 8.1MP HD-Ready Camera - Photo's can be made @ 8mp, HD1080, VGA - Videorecorder can be 1280x720@30fps and AAC audio (highest possible) - MIUI Themes - Wifi - GPS - Prepared for TripNFeatures - Needs baseband * for best results - Any baseband supported - New TripNMiUI theme - Radio hack ported from TripNMiUI Gingerbread - Improved screen quality! Just check the colours and you know what I mean. - Boot time 32seconds! Changelog 1.1.0: - Radio hacked (almost unified baseband) - Almost all radio files rebuiled for unified baseband (gives way better network connectivity) - Mobile data hacks to prevent speed drops should also be faster (let me know!) - TripNFeature 01 (Tweaks&Hacks) rebuilded for better results gingerbread will get this also, that will be even faster - Got up to 45 FPS (stock kernel) - Better implementation of the virtual machine - Improved connection stock kernel <-> froyo - Improved MTD connections (faster, less battery drain) note: battery drain should be much less then before, BUT i need feedback because some settings are very beta, if it drains faster then those will be removed and battery life will also be extremely improved - Added Gallery3D to replace MIUI Gallery - Battery temps drasticly reduced - Baseband 49/52 (bb patch unsupported, possible bootloops) (untested) - Much more things done, but i forget some things Changelog 1.2.0: - TOUCHSCREEN IS NOW 60HZ - Screen looks better then ever! - Overal speed is much improved - Possible mobile data fixes - FPS half uncaped, only in some apps you notice that the app comes trough (will be fixed later) - Possible wifi fixes - Videoplayback improved - TripNFeature 01 (Tweaks&Hacks) much further improved - Some little coding issues fixed - Did some tests for further improvements on the rom (confirmed working, will be implemented) Changelog 1.3.0: - FPS uncaped on stock kernel - 38 FPS stable in Quadrant - 150 FPS Average in FPS2D - Ultimate screen tweaks (just as vivid as in 1.0.8 again) - All kinds of video hacks included to make FPS uncap possible - Battery tweaks (temps arround 30 degrees, batterylife improved and much more) - Dont have to say anything about lag fix, because with the FPS uncap all lag should be fixed - PS dont forget this rom is still W.I.P. it dont takes long anymore, but still not fully final (because of the tweaks and hacks) Changelog 1.5.5: - All fixed for baseband - Tiny bugs fixed - Tweaks moved :-) Changelog 1.5.6: - Camera app from my CM6 rom ported to MIUI camera setting "high" is 720P - Updated TripNMiUI theme incl. bootanimation - Improved the screen, looks more "real" - Tiny bugs resolved - Radio system edited to work better with bb58 and higher - I forgot also some things but when I rember the OP is edited Changelog 1.6: - Possible bluetooth fixes - Unified baseband (connection rom to bb last thing needed to fix) - Default for baseband .49 - Alot of speed improvements - Many battery hacks added (not all visible) - Data connections tweaked en rebuilded for unified baseband - Roms feels totally new and fresh (like you got a new phone) - Screen quality upscaled to the maximum on stock kernel (i guess, maybe i find a way to...) ;-) Changelog 1.6.1: - SMS issues fixed Changelog 1.6.5: - Added more pixelformats, and oh yes! they are used! - Color depth hacked, pixels produce more output - Rebuilded texture rendering engine - Browser search bug fixed - Settings; "Update" section removed because FC (Settings - system - about phone - update, an lovely FC) - Settings; "CPU" changed to "Android version" - Possible market errors fixed - Radio improvements - Prepared for a few new TripNFeatures - Prepared for TripNAddons Changelog 1.6.9: - Updated auto-zipalign scripts (data and system) - 455MB internal memory after clean install - New lockscreen (fully functional and can be themed) - Again rom is faster - Fixes in network connections - Settings edited; removed network diagnostics (didnt work either) about phone screen changed removed builtin keyboard cause we dont have it - Led colors can be changed (settings - system - led) - Tuned auto brightness - TripNMiUI default theme some changes - Little optimised boot - Tweaked power profiles - Started working on native tethering - FC in sms app for some languages fixed - Rebuilded the rom completely (data restore cause issues) - Tweaks edited - SetupWizard looks changed to match Gingerbread - Edited xrecovery to match rom Changelog 1.7: - coming very soon TripNAddons upcoming T.B.A.!! Download ROM: Rom version 1: TripNMiUI 1.7 - basebands .54 .58 .61 .65 .67 supported http://www.mediafire.com/?uac6fd5azilo53b Rom version 2: TripNMiUI 1.7 - basebands .46 .47 .49 .52 supported http://www.mediafire.com/?aq2l4bo8x3etiw7 Download TripNFix 01-169: download fix if you have the problem that wifi wont connect http://www.mediafire.com/?2r64w5jln0os2vx Download TripNBB Patch AT&T USERS ONLY use this patch when you want to use rom version 1.6.1 or 1.6.5 on AT&T networks, this patch should also fix sms issues when you use bb65 on 1.6.* note: patch is beta, i have no AT&T so it needs to be tested http://www.mediafire.com/?e4cl113985g3h79 For users without call conference or sms problems: Xrecovery: * Factory Reset * Wipe Cache Partition * Advance Options --> Wipe Dalvik Cache * Advance Options --> Wipe Battery Stats * Reboot Flash Tool 2.9.1 * Flash BB49 (Trips One) Xrecovery * Install Custom Zip ---> Install ROM 1.6.5 * Reboot * No signal * Crashed the System Server Many Times * No Signal Xrecovery * Whithout any Wipe * Install Custom Zip --->Install BB54 ATT Patch * Reboot * Got Signal * Got Call Conference * Did not get SMS * Whitout Wiping AnyThing (From Flashtool 2.91) Flashed BB065A (the one that uses AT&T) * Reboot * Got Signal * Did not get Call Conference * Got SMS Xrecovery * Whitout Wiping AnyThing * Install Custom Zip --->Install BB54 ATT Patch (Again !!) * Reboot * Got Signal * Got Call Conference * Got SMS have fun have fun Installation classique : 1- Flasher votre x10 via SEUS 2- Formatez la SD 3- Rootez et installez busybox et xrecovery via flashtool 4- Flasher le baseband .67 via flashtool ( apres le x10 n'a plus de réseau, c'est normal )Lien pour flasher le baseband 5- Redémarrer sous xrecovery et faire les wipes ( factory reset, wipe cache partition, wipe dalvik cache et wipe stat battery ) 6- Sous "install custom Zip" flasher la rom 7- Redémarrer le telephone 8- Profitez :D Modifié 22 juin 2011 par florent38 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lilyum Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 Une trés bonne rom !!! j ai utilisé quelque temps la 1.0.6, avec le custom kernel. une tres grande fluidité ! par contre ayant eu longtemps des iphones... l interface m a vite gonflée... ( possibilité de changer le bureau mais pas le menu ) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
flo44 Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 Pas de reconnaissance de la BB .52 pour ma part, je fous un coup de SEUS, change la BB, et je reflash ROM puis kernel. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AdrienDegremont Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 la batterie tien bien le coup?je suis bien tenter par celle la? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AdrienDegremont Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 bon je me lance et je verai bien aprés lol. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
flo44 Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 P'tin j'ai flash la BB .49 sous le FW stock de SE et elle est pas reconnue.. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AdrienDegremont Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 moi le baseband 52 passe nikel Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AdrienDegremont Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 parcontre lilyum est ce que le zoom de la camera fait force close pour toi?samele fait cela Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AdrienDegremont Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 petit retour de la rom aprés une courte utilisation.je la trouve super.bon faut aimer le coté iphone .mais sinan fonctionne nikel a pars le zoom quan faides photos.voila pour ceux qu'il veulent l'utiliser ba sais parfait Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lilyum Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 Pour le zoom il faut passer par des applis comme vignette.... comme touez les 2.2... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
napster23 Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 je viens juste d'installer, et pas de réseau ^^ , j'ai aussitôt installer la BB.52 mais toujours pas de réseau, même après un Crash du System Server.... vous avez une soluc ? (j'ai déjà était confronter à ce genre de problème et j'avais juste à installler la BB et tout était bien) Merci. Cordialement napster23. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gwadaeln Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 (modifié) J'ai installer avec la BB52, changer le dock (laucher pro) et fait plusieurs petit changement (comme a chaque version de cette rom) et je n'ai aucun problème. J'ai eu aussi un force close avec le zoom de l'apn mais à la deuxième tentative sa a marché. Edit: En faite, le zoom marche si on passe en caméra puis que l'on retourne sur l'apn. Modifié 19 mai 2011 par gwadaeln Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
paolopp1 Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 bonsoir a tous / je teste cette rom depuis hier et franchem.... rien a dire pour moi elle y est elle restera pour ceux qui veulent savoir ::: niveaux batterie c est pas mal du tout charger hier soir ver 23H en passant 5 ,6 appel fait des photos du wifi 1H30 aprox... du market en 3g il est 22H et il me reste encore 65% de batterie ,donc tout a fait correct non? Pour ce qui comme moi n aime pas l interface miui il y a le lanceur arc qui marche impec dessus voila!!! test quadrant 1435 ,linpack 35 avec l apli DX/D2 overcloker en low voltage a 1GHZ perso l apli est plus performante que setcpu du moin pour les rom 2.2 et 2.3 car ne marche pas avec les 2.1....... Merci gwadaeln pour l astuce pour le zoom ca marche impec bonne soirée atous Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ari_5 Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 il y a quoi comme changement par rapport à l'ancienne ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
paolopp1 Posté(e) 19 mai 2011 Share Posté(e) 19 mai 2011 Le 19/05/2011 à 20:15, ari_5 a dit : il y a quoi comme changement par rapport à l'ancienne ? perso je la trouve plus fluide est bien plus rapide et niveaux réseau aussi autant sur la 3g mais aussi le wifi la réception est impec.... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ajael44 Posté(e) 20 mai 2011 Share Posté(e) 20 mai 2011 Quelqu'un pourrait-il poster des screenshots de cette ROM svp ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lilyum Posté(e) 20 mai 2011 Share Posté(e) 20 mai 2011 1.0.8 out ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 20 mai 2011 Auteur Share Posté(e) 20 mai 2011 Le 19/05/2011 à 13:38, napster23 a dit : je viens juste d'installer, et pas de réseau ^^ , j'ai aussitôt installer la BB.52 mais toujours pas de réseau, même après un Crash du System Server.... vous avez une soluc ? (j'ai déjà était confronter à ce genre de problème et j'avais juste à installler la BB et tout était bien) Merci. Cordialement napster23. moi je suis en 49 et tous marche nikel. essaye de passer en 49 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 20 mai 2011 Auteur Share Posté(e) 20 mai 2011 (modifié) aller un petit flash en 1.0.8 je veut voir ça !! les 1500 sous quadrant actuellement je suis a 1200 avec la 1.0.7 et 28fps neocore Modifié 20 mai 2011 par florent38 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lilyum Posté(e) 20 mai 2011 Share Posté(e) 20 mai 2011 Le 20/05/2011 à 06:53, florent38 a dit : aller un petit flash en 1.0.8 je veut voir ça !! les 1500 sous quadrant actuellement je suis a 1200 avec la 1.0.7 et 28fps neocore Testée en speed ce matin, avec bb .52, aucun soucis, quadrant 1400 environ... linpack a peine plus de 33.000 et 27.9fps sur neocore... Bizarrement j ai l impression que la 1.0.6 tournait mieux... j avais de meilleurs benchmark... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
paolopp1 Posté(e) 20 mai 2011 Share Posté(e) 20 mai 2011 Le 20/05/2011 à 09:21, lilyum a dit : Testée en speed ce matin, avec bb .52, aucun soucis, quadrant 1400 environ... linpack a peine plus de 33.000 et 27.9fps sur neocore... Bizarrement j ai l impression que la 1.0.6 tournait mieux... j avais de meilleurs benchmark... salut a tous il faut tout installer voila ma proced..... installer la rom redémarrage une fois qu elle a démarrer correctement j ai instal... le patch cm6bb49.zip que vous trouvez la::::http://www.multiupload.com/U020F08R3N vaux aussi bien pour le BB49 que le BB52 redémarrage puis j ai instal... TripNKernel BTS /redemarage et puis FreeKernel-MOD 01 addon puis installer DX/D2 overcloker que j ai fixer en low voltage a 1GHZ resultat linpack 35 quadrant 1525 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quent01120 Posté(e) 20 mai 2011 Share Posté(e) 20 mai 2011 Yo TripKernel BTS c'est pour revenir a l'ancien noyaux le non améliorer donc tu ne teste pas la même version de la rom. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
paolopp1 Posté(e) 20 mai 2011 Share Posté(e) 20 mai 2011 Le 20/05/2011 à 10:49, Quent01120 a dit : Yo TripKernel BTS c'est pour revenir a l'ancien noyaux le non améliorer donc tu ne teste pas la même version de la rom. peut etre mais une fois que j ai installer TripKernel BTS je suis monter a 47 FPS dans le teste quadrant alors que sans je rester fixe a 32 :wacko: je sais c BIZ.... mais ca marche Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 20 mai 2011 Auteur Share Posté(e) 20 mai 2011 Le 20/05/2011 à 10:44, paolo a dit : salut a tous il faut tout installer voila ma proced..... installer la rom redémarrage une fois qu elle a démarrer correctement j ai instal... le patch cm6bb49.zip que vous trouvez la::::http://www.multiupload.com/U020F08R3N vaux aussi bien pour le BB49 que le BB52 redémarrage puis j ai instal... TripNKernel BTS /redemarage et puis FreeKernel-MOD 01 addon puis installer DX/D2 overcloker que j ai fixer en low voltage a 1GHZ resultat linpack 35 quadrant 1525 c'est quoi ce patch cm6bb49.zip ? il fait quoi moi j'ai les même perf avec la 1.0.8 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
CanislupusS Posté(e) 20 mai 2011 Share Posté(e) 20 mai 2011 (modifié) Bonjour, Je suis en train de tester cette rom qui me plait beaucoup ! Par contre j'ai un problème agaçant, je ne peux pas déplacer mes applications vers la carte SD : Un message d'erreur s'affiche comme quoi c'est un echec. Quelqu'un a une solution ? Merci ! Modifié 20 mai 2011 par Canislupus Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
