cedrikck Posté(e) 27 mai 2011 Share Posté(e) 27 mai 2011 (modifié) Pour rom stock et autres SAUF CM7 lien xda Video enhancements: -1080p @ 30fps in all quality settings. -No recording sound fix. -Memory buffer increase for extra speed (no real impact) -Audio bitrate increased from 64kbps to 128kbps and sample rate increased from 22khz to 44khz. -Increased (Variable) video quality for 1080p and 720p: (Found under video quality in the menu for each resolution) -1080P SUPER_FINE_ENCODER_BITRATE 9mb to 17mb -1080P FINE_ENCODER_BITRATE 7mb to 14mb -1080P NORMAL_ENCODER_BITRATE 5mb to 11mb -720P SUPER_FINE_ENCODER_BITRATE 4mb to 10mb -720P FINE_ENCODER_BITRATE 3mb to 8mb -720P NORMAL_ENCODER_BITRATE 2mb to 5mb Image enhancements: -Attempt to increase image resolution for 8mp. -Attempt at brightness fix. To install: Copy required zip to your memory card to flash in CWM, select install from zip. or Extract the camera.apk from the required zip file, copy to memory card and use root explorer to delete current camera.apk file then copy to system/app folder. Notes : -Reports state working with 64mb mod kernels, use compatible version. -Currently only working for froyo/stock/modaco roms. -Use Camera-1.1.1-Default Audio-64mbGPUHack-unsigned.zip if any1 is having audio issues with new build, 22khz/64kbps. -Camera-1.1.1-Enhanced Audio-Old-unsigned.zip uploaded if you want the following benefits: -1080P SUPER_FINE_ENCODER_BITRATE 9mb to 19mb -1080P FINE_ENCODER_BITRATE 7mb to 15mb -1080P NORMAL_ENCODER_BITRATE 5mb to 12mb Améliorations futures... Possible future to do list: -Enable autofocus in video. -Enhance tweak for Photo quality higher bitrate. -Add additional zoom options. -Tweak custom camera options to stick once restarted stored here: /data/data/com.android.camera/shared_prefs/arc_camera_prefs.xml -60fps mod (should be interesting, aim is for 720p). -Custom requests. -add user configurable settings in menu. -transparant menu? -fix for black bar covering setting menu image border in video mode. -Attempt fix CM7 camera 1080p 15fps cap. -fix camera bug for 720p max encoder bitrate of 10mb. Modifié 27 mai 2011 par cedrikck Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cedrikck Posté(e) 27 mai 2011 Auteur Share Posté(e) 27 mai 2011 (modifié) Pour CM7 Choisissez le mod 720p uniquement si vous utilisez un noyau avec les 64 Mo de RAM hack (il ne supporte pas 1080p). CM7 kernel.Bitrate (orig)-signed.zip vous ramènera aux paramètres que sur le CM7 nuit repo. Reinstall le noyau vork si vous voulez revenir aux réglages d'orig pour ve 64mb hack.I », a ajouté deux images à comparer 7 Mbit vs / s 20 Mbit / s (720p). Voici les différentes versions ici, vous pouvez choisir ;) Bien entendu, plus le bitrate plus c'est difficile, tout est poussé, les résultats peuvent varier (en particulier en fonction de la vitesse sdcard). la lecture de téléphone peut aussi être un problème. Il est impossible de casser quoi que ce soit de façon permanente, alors il suffit d'installer avec les paramètres d'origine si vous avez des questions. Retrouvez les zip des bitrates ici --------------- BitrateMod1.1-signed.zip----------- HD: 1080p@15fps and 17mbit/s High: 720p@30fps and 14mbit/s. ------------------------------------------------------- --------------- BitrateMod-signed.zip--------------- HD: 1080p@15fps and 12mbit/s High: 720p@30fps and 20mbit/s. ------------------------------------------------------- ----- BitrateMod(720p only)1.1-signed.zip-------- HD: 720p@30fps and 20mbit/s High: 720p@30fps and 10mbit/s. ------------------------------------------------------- -------- BitrateMod(720p only)-signed.zip-------- HD: 720p@30fps and 28mbit/s High: 720p@30fps and 20mbit/s. ------------------------------------------------------- ------------ Bitrate(orig)-signed.zip --------------- HD: 720p@30fps and 6-7mbit/s High: 720p@30fps and 4mbit/s. ------------------------------------------------------- ------------ Std. vork kernel settings-------------- HD: Disabled High: 720p@30fps and 4mbit/s. ------------------------------------------------------- ;--------------- BitrateMod_MAX.zip---------------- Video: HD: 1080p@15fps and 30mbit/s High: 720p@30fps and 30mbit/s. Still: Super fine: 100 (old value was 90) ------------------------------------------------------- All audio is 128 kbps aac. Sad bon apparemment sur CM7 on est encore un peu limité .... à 1080p à 30mbit / s, mais seulement à 15fps.... patience patience Modifié 27 mai 2011 par cedrikck Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
alessa Posté(e) 27 mai 2011 Share Posté(e) 27 mai 2011 merci ,je l'avais vu hier je l'ai installer et j'allait le poster ,mais tu a bien fait ca ;-) vu que je viens d'avoir le X2,ya une réel différence ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
XAkiranaiX Posté(e) 19 juin 2011 Share Posté(e) 19 juin 2011 D'habitudes je comprend l'anglais et le françaises. Mais ici dans les 2 cas je comprend rien je sais pas du tout quel prendre. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Delta-XIII Posté(e) 21 juin 2011 Share Posté(e) 21 juin 2011 Déjà le 1088p qu'elle en ai son utilité ? Je vais essayé de modifier le profil BitrateMod-signed.zip qui m'a l'air déjà pas mal ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
venom77 Posté(e) 26 juin 2011 Share Posté(e) 26 juin 2011 Dites-moi, j'ai pas envie de me planter alors j'prefere demander avant quelle version je dois installer ,j'ai mon 2x d'origine version 2.2.2, build frg83g. Merci de votre aide. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mooldo Posté(e) 26 juin 2011 Share Posté(e) 26 juin 2011 Dites-moi, j'ai pas envie de me planter alors j'prefere demander avant quelle version je dois installer ,j'ai mon 2x d'origine version 2.2.2, build frg83g. Merci de votre aide. Et bien le premier lien pour les ROM stock Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
