[ROM]-VILLAIN (HTC Sense Enabled Android 2.1)
johndoe
je sens que celle la va rester sur mon hero :D
source : http://forum.xda-developers.com/showthread.php?t=622468
CHANGELOG:
Added:
- Chinese Keyboard
- HTC PhotoWidget
- 1.5 Cupcake style Dialler (quicker)
- OPTIONAL Espresso-Rosie (Highly optimized & slightly altered – no bubbles!)
Changes:
- Camera fixed. I have just taken over 30 photographs at various settings, and it’s absolutely fine.
- gapps FC fixed
- HTC Sense FC fixed
- (AGAIN) fixed doubling of HTC widgets
- Made changes to synchronisation settings within the build
- Further customised the kernel
- Several memory leaks resolved (Free memory is still on the low side, but that’s to be expected with a Sense build – Instead of the 50-60mb free in
2.0.1, there’s now 70-80mb free after install.
- Fixed network location for data connection (before it only worked 100% with wireless)
ATTEMPTED to fix:
- Exchange sync (please test)
- Gmail (again, and again, and again, and again – please test)
Install Steps:
- Run Nandroid Backup
- Flash VillainROM2.1
- Boot the phone up
- Reboot/Turn off
- OPTIONAL – Add Espresso Rosie Optimized (attached)
2.0.1
The update adds:
- Optimized Rosie (PNG Optimized) - should be quicker
- Added HTC Stocks App & Widget
- Attempted FIX on Media Uploader (Please test)
- Attempted MMS FIX (Please test)
- FIXED Doubling of HTC Widgets
Fixed Market Issues (All paid apps + camera apps available)
Fixed Root Access
Fixed HTC Settings widget (blue highlights)
Added Bookmarks Widget
Added SimToolKit (stk.apk) - Working
Added JBED & JBED Lib file
Added Chinese fonts to font directory
Removed Android Stock Dialler
Removed Android Stock Contacts App
Items definitely still not working:
- Gmail Push, autosync
- Superuser
- Open GL (The drivers are there, but it WILL NOT work)
1.2.1
- FIXED Network Location
- Added HTC Ringtones, Notifications & Alarm Sounds
- Added latest Superuser App, ready for tomorrow's SU fix.
1.2 CHANGELOG:
- Several Sense UI based bugs fixed
- FIXED EXCHANGE! Please test, as it's working for me on a test account that a forum member provided me with!
- Fixed a lot of FCs.
- Removed several of the third party apps people wanted removed.
- Added HTC Music Player & Widget
- Added HTC Twitter & Widget (Working!)
- Added HTC Calendar & Widget (Working!)
- Swapped Android Facebook Sync for HTC Facebook Sync (Apparently MORE stable, but you’ll need to test this. Any issues, and I’ll revert to Android Facebook sync)
- Added Stock Android Dialler & Contacts (Several people PMd me to request - you have the option of either now)
- Youtube working correctly now.
1.1
Removed CPU Overclock
Removed Google Maps (see below)
Added NavLauncher (Thanks MadCow) - Use this to install Google Maps, or install from market
Added HTC IME Keyboard & Dictionary(WORKING!)
Added HTC Messaging app (WORKING!)
Added HTC MAIL (for Exchange) (Seems to be working... I don't use it, so please test)
Added HTC Contacts Widget (WORKING!)
FIXED Network Location (WORKING!)
A few bug fixes
So, to the FEATURES/Working list:
- It's FAST!
- HTC Widgets (weather, clock, messaging, etc - all working)
- Stock HTC Lockscreen
- Google Search by Voice working perfectly
- Camera works at 5MP - (oh yeah!)
- Nexus One Bootscreen
- Facebook sync working to contacts
- New HTC Browser from 2.1 - with MULTITOUCH!
- Gallery Working
- GPS, DATA, Calls, etc etc - all functions work
- Very Stable
What's included:
- vizBattery Widget (Nice looking battery widget)
- Internal Memory Widget
- SD Card Memory Widget
- CPU Overclock Widget (update in market first before using, weird bug)
- Market Enabler
- aNetShare for Wireless Tethering
- MountUSB
- Google Maps 3.3.1 for ROOT Users (Nav outside of USA - UNTESTED)
Modifié par johndoe
  • Réponses 239
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
faudrait pas la rajouter dans le comparatif rom
si elle est si bien que ca
et c est vrai que d apres les post elle a l air super
faut que je corrige mon pb de root qui marche pas pour titanium backup et je teste
( le root ) marche en command adb et aussi le log shootme
je comprends pas
Pour le clavier on peut le rajouter après sinon je vais m'empresser de la télécharger :p Merci Jonhdoe pour ta réactivité :p Je pense qu'on peut dire que le Hero a la meilleure communauté de développeur depuis sa sortie, espérons que ceux sur le Milestone et Nexus vont avoir des développeurs ^^.
-Ca s'installe comme toutes les autres ROM :)
-Pour le moment elle est en anglais mais il me semble que sur le market, il y a une application pour la mettre en francais.
Ah tiens la nouvelle barre de notifications Espresso/Sense qui indique les taches en cours récentes effectuées ! :o Un vrai + !!! On peut switcher à tout moment !
Ok merci tu peux me dire le nom de l'application?Et celle pour avoir le clavier HTC aussi ce serait sympas!
Merci d'avance
Quelques petites précision :p :
Actuellement quand on kill tout : 100/105Mo. De base, il reste 105Mo de libre sur la ROM
>Installer "Morelocale2" depuis le market et en un clic, vous avez la ROM en francais ! :)
>Très fluide
>Application "Calendrier" d'Android de base.
>Application Album de Sense et non "Galerie" 2.1
>Navigateur : très très bon :p Edit : Il a besoin d 'etre plus approfondie (je pense que HTC va faire le necessaire) car il rame un peu sur le sgrosses pages web.
>Nouvelle barre de notifications (voir mon message du dessus)
>Possibilité de désactiver le chargement des animations flash pendant la navigation
>J'ai l'icone 3G et non HSDPA mais le débit est rapide donc je pense qu'il s'agisse bien du HSDPA (3G+)
>Nouvelle application "Horloge" avec possibilité de mettre de mettre le Hero comme une horloge de bureau.
>Trackball fonctionnel partout
>Lockscreen d'Espresso (barre horizontale)
>Nouvelles transitions entre les applications (l'ancienne aprt vers la gauche pour laisser place à la nouvelle).
>Nouvelles fonctions de l'APN : balance des blancs, luminosité, contraste, saturation, effet, qualité, minuteur...
>C'est bon j'arrive à télécharger :p : plus de souci après un reboot
>Notifications de mises à jours d'application
>Widget HTC Sense disponibles : Horloge, Mail, Messages, Paramètres et Météo pour le moment.
>Pas d'application Musique mais nswPlayer, ca ressemble un peu à Nemo (teintes bleues), cela fait lecteur vidéo/musique et visionneuse d'image. Cependant j'ai un bug quand je clic sur une musique mais les vidéos fonctionnent correctement.
>Nouvelle application Youtube d'Android 2.1
>Pas de LiveWallpaper
>Possibilité de mettre sur le lockscreen, un des fonds d'écran de Sense et non uniquement une image venant de la carte SD comme cela était le cas avant.
Voilà pour le moment, je mettrais à jour ce post.
Modifié par Zoozloz
>Très fluide, mémoire dispo' de la ROM et de la RAM à venir :p
>J'arrive pas à télécharger sur le market (téléchargement en cours indéfiniment) mais je dois etre le seul à l'avoir car aucun souci sur le topic de la ROM.
C'est con pour la galerie,et google navigation fonctionne?
Merci Floxo pour l'info
Pour Maps Navigation, je n'ai pas testé (en intérieur : pas de GPS et il n'y a pas actuellement la localisation réseau dans la ROM) mais de toute facon si cela ne marchait pas, suffit de télécharger l'application fournie dans un post de FrAndroid : https://www.frandroid.com/8048/google-navigation-de-nouveau-en-europe/
>Floxo : oui j'ai vu sur le topic mais j'arrive pas à la télécharger ^^"
J'ai testé rapido :
- j'ai des force close de sense au démarrage
- le fait que ca soit en anglais uniquement par défaut c'est un peu galère même si apparemment on peut ajouter le FR
- google navigation semble en effet fonctionner
- le clavier HTC ca manque grave dans les contacts pour rechercher avec la recherche "intelligente"
- je trouve ca moins fluide que la modaco 3.0 et pourtant j'ai fais un wipe avant installation
- il y a un paquet d'applications installées de base, à voir ce que ca apporte
Invité Shippo
'tite question, est-ce que quelqu'un a testé un casque bluetooth avec cette rom ? D'un autre côté si nswPlayer est vraiment foireux ya plus trop d'intérêt :p
