Posté(e) (modifié)
[ROM][JULE15]-=Virtuous Galaxy v. 1.0.5=- [HC 3.1 / TouchWiz UX][Kernel: UNITY V7]
lien post original :
http://forum.xda-dev...d.php?t=1143368
Based on Samsung Galaxy Tab 10.1 (P7500) P7500OXAKFF (30 June 2011) ROM (Honeycomb 3.1)
Kernel:
2.6.36.4 UNITY V7 OC Kernel
- 99.9 stock Galaxy Tab 10.1 P7500
- Awesome TouchWiz UX
- Multilanguage
- Improved EXT4 performance
- Ultra Fast
- Virtuous CPU scaling scripts - READ MORE
- Deodexed
- Zipaligned
- 216-1200MHz default
- Photo Editor
- 3D Photo Browser
- Asus weather widget
- Busybox / Superuser
- 3G modem support (Huawei)
- Nano text editor support
- Bash command shell support
- and more
Issues (WIP):
- you tell me
Code:
v.1.0.5:
- Updated kernel to UNITY V7 (based on Acer official source code)
--- Updated video/camera/media drivers from nvidia git
--- Updated bcm4329 drivers
--- Boost overall performance
--- Other minor tweaks & configs
- Other minor fixes
v.1.0.4 Update 1:
- Fixed audio
- Battery % mod
- Camera 5MP default
- Removed no needed settings
- admob fix
- HeroOfSparta fix
v.1.0.4:
- In progress
- New base P7500OXAKFF_P7500XXKFF
- Really fixed Exchange
v.1.0.3:
- Fixed camera (5.0Mpx now)
- Newest kernel UNITY V5
- Fixed Exchange
v.1.0.2:
- Newest kernel V4
- Removed Screen calibration from settings (didnt work with our sensor)
- Removed Haptic intensity settings
- Added Google video editor
- Improved works with 3G modems
- Fixed search on page
v.1.0.1:
- Proper kernel Unity V3
---- Some cleanups & configs
---- Added PS3 support & alot USB HID devbices
---- Added audio boost (experimental)
---- Added HFS/HFS+ support
---- Added NTFS RW support
- Added Swipe keyboard
- Updated ES File Explorer
- Updated Google Maps
- Removed samsung shutdown animation
- Other minor fixes & tweaks
v.1.0:
- Newest kernel UNITY V3
---- Updated Wi-Fi drivers
---- Tweaked video drivers
---- Back to NOOP I/O Sheduler (Experiment)
- Added stock Email app (with Exchange account support)
- Added stock MobilePrint app
- Fixed Haptic feedback
- Fixed Social Hub
- Added 3D Photo Browser
- Added TegraZone app
- Added Google Videos Service
- Added Asus Weather widget
v.0.2 Beta:
- Wi-Fi fixed
- Camcorder fixed
- Improved overall performance
- PolarisOffice fixed
- "SamsungApps" app removed
- Removed Swipe
- Removed QuickOffice
v.0.1b Alpha:
- Initial release
- Flash via ClockworkMod Recovery: https://market.andro...coveryInstaller
V1.0.5 Full ROM:
http://www.multiupload.com/USOV8QNQBT
faire un full wipe lors du premier flashage
Credits: Google, Virtuous Dev Team (rmk, Flemmard, Diamondback, Chrisch1974, m-deejay, seo), fguy
Thanks: sc2k, vache, Dexter_nlb, and others (i forgot)
Modifié par grandiosa
  • Réponses 79
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
bon je l'utilise pas mais elle va percer cette rom donc je créer ce topic çà éviteras d'en polluer d'autre même si pour moi elle est beaucoup moins fluide que la Picasso
Je n'arrive pas à l'installer! Installation aborted à chaque essai (X3). Une idée?
acer recovery installer a jour ?
taille de ton fichier zip: Virtuous_Galaxy_v.1.0.2.zip (348.8 MB)
Posté(e) (modifié)
Oui aux 2 questions Grandiosa...Enfin le zip fait 366 Mo plutôt.
Edit: c'est pas la rom en cause j'ai le même problème avec la vituous PIcasso...
Clockworkmodrecovery v5.0.0.0 (Thor2002ro rev1.3.4)
Le zip ne doit pas être dézippé on est d'accord?
Edit 2: j'ai réinstallé Acer Recovery via le market, essayer d'autres Roms, refait des wipes...et toujours Installation aborted :emo_im_lips_are_sealed: Formatage de la SD?
-- Installing : /sdcard/Virtuous_Galaxy_v.zip
Finding update package...
Opening update package...
Installing update
Installation aborted.
Edit3: probleme en partie résolu, le probleme venait des mes zips...Donc installation de Virtuous Galaxy Done! Mais maintenant je suis bloqué sur le logo android!!!! Une idée?
Modifié par k0en
Posté(e) (modifié)
Ya pas eu de bug dans les downlaod?
Edit en reponse a l edit 3 : telecharge a nouveau, tu les mets ta rom sur la sd et tu recommence l installation....
Modifié par Alex62
Posté(e) (modifié)
je viens de relancer l'installation...j'obtiens comme dernier message: INstall from Sd card complete! Donc normalement ça roule...
ensuite reboot system et là ca tourne en boucle...
Edit: au moment du reboot il apparait un message d'erreur mais j'arrive pas à voir ce qui est écrit....
Modifié par k0en
Posté(e) (modifié)
Plus de 5 min???
Je me demande si ca vient pas du kernel V4...
Car au reboot j'ai pas le nid d'abeille comme sur la vidéo mais le logo android classique...
Je vais tenter une install de vituous picasso pour voir si ca fait une différence
Modifié par k0en
plus de 5 mn non...mais sinon si tu reboot en restant appuyé sur le bouton power ca reboot bien? Sinon essais de reboot en mode CWM et de refaire les wipes sans l installation
Posté(e) (modifié)
oui ca rebbot bien avec start appuyé...
je vais retenter les wipes...
Edit: aucun changement...
Edit2: tien je vois de voir ce message
E: unknown volume for path (/sd-ext)
Modifié par k0en
Stp essaye de pas editer les messages quand il y a eu une reponse... Apres pour se retrouver ce n est pas evident.....
Ta carte sd est formater dans quel type de format? Essai en FAT :)
Resolu avec la rom picasso, je pense que le probleme vient du kernel...
Pour info mon pad xbox 360 est reconnu direct et je peux commander ma tablette avec!
J'ai quasiment testé toutes les roms et je peux vous dire que la virtuous galaxy c'est de loin la meilleure car la plus rapide. La recherche et affichage des pages internet se font en un éclair. J'ai au boulot un ipad 2, j'ai testé l'ouverture d'une page qui est relativement longue comme CDISCOUNT, l'acer avec cette rom a mis quasiment 3 secondes dans la vue à apple. La clé 3G fonctionne désormais avec cette rom et on perd quasi rien en rapidité. Franchement à installer d'urgence...
@Zeyd : désolé je n'ai pas encore le câble pour tester ....
@Jojo856 : Tu as raison elle est vraiment top et à mon goût aussi !
Posté(e) (modifié)
J'ai quasiment testé toutes les Roms et je peux vous dire que la virtuous galaxy c'est de loin la meilleure car la plus rapide. …
C'est vrai, mais malheureusement encore en développement.
Exemple: Impossible d' "Avancer" & "Reculer" dans les vidéo Youtube. (Youtube App ou Navigateur). Pour Dailymotion: plantage! C'est vraiment dommage, car pour mon utilisation elle est parfaite.
Par contre le défilement rapide des pages Web est hyper fluide, plus de ces horribles pavés gris qui apparaissent avec certaines ROMs.
J'ai aussi l'impression qu'elle pompe un peu plus la batterie.
Mais cette ROM promet (si le développeur la continue?)
Modifié par verdigny
