[app drawer] alt drawer 0.6.1
j'en entends régulièrement dire qu'il n'utilisent pas les roms sense 2.3 à cause du défilement des applis par pages ou que miui serait fantastique avec un app drawer.
Et bien voila un app drawer personnalisable personnalisable qui s'améliore peu a peu.
post original
0.6.1 - 22/07/11
  • New icon (Thanks to ebbinger_413!)
  • Edit name and/or icon of an app
  • Sort by name, most used and installation date
  • [FIX] Some little bugs
  • First try to close the drawer after opening an app
0.5.1 - 16/07/11
  • Horizontal paged scroll
  • SHOULD stay in memory
  • [FIX] Bug on create shortcut
  • Option to low-quality background (improves scrolling)
  • Custom font type (to install a new font, put it into /sdcard/AltDrawer/fonts)
0.4 - 11/07/11
  • Option to remember or not, last list position
  • Improved scrolling
  • [FIX] Font size not changing bug.
  • [FIX] Menu button available for Honeycomb tablets.
  • Home button at right when device in landscape (perfect for tablets)
  • Hide apps function available
  • No longer need to refresh when an app is installed/uninstalled
0.3.2 - 07/07/11
  • Added version info in settings
  • Added german translation
  • Improved speed when rotating screen
  • Screen orientation: by sensor, always portrait or always landscape
  • Change background (image/wallpaper) transparency
  • [FIX] Home button position setting (center, left, right)
  • [FIX] Big resolution problems
  • Improved general speed (first loading and launching apps)
  • Hardware acceleration enabled (Honeycomb tablets)
  • The drawer does not closes when opening an application
  • Other little changes
0.2 - 06/07/11
  • Now the drawer closes when open an app
  • Fullscreen mode (hides status bar)
  • Change home button position: bottom, top, left or right
  • [FIX] When uninstall an app, drawer refreshes
  • [FIX] Some spanish translations
0.1 - 04/07/11 (First release)
  • List view
  • Grid view
  • Uninstall app from drawer
  • Create shortcut for any app
  • Portrait or landscape mode
  • Change row spacing
  • Number of columns on grid view
  • Font color
  • Font and icon size
  • Background (color, image or wallpaper)
  • Show 'Home button' or not
O_O Chapogrelo Je t'aime ! c'est exactement c'que je cherchais depuis un moment :D
EDIT : Enfaite c'est pas encore le top x) j'aurais voulu qu'il remplace carément le launcher d'origine, car là j'vais avoir un bouton pour l'ancienne app drawer qui me sert stricement à rien :s (je suis sous virtuous unity)
bon ça fait son taff, un petit peu long à se lancer et se quitter quand même mais c'est qu'une toute première version, donc à suivre.
Et aussi, sur sense en tout cas, il ne remplace pas le drawer d'origine, faut le lancer à partir de l’icône de l'application.
J'ai rencontré un ralentissement dans le mode grille avec 5 colone en paysage.
Je suis sur que y'a moyen pour que ça sois une super appli une fois bien optimisé =)
  • 3 weeks later...
