Étrange problème avec un ArrayList
Bonjour tout le monde!
J'ai un problème étrange avec mon ArrayList d'un objet personnalisé
public ArrayList<MonObject> getXMLResult(){
	mObjectList = new ArrayList<MonObject>();
	try {
           // creates and returns new instance of SAX-implementation:
           SAXParserFactory factory = SAXParserFactory.newInstance();
           // create SAX-parser...
           SAXParser parser = factory.newSAXParser();
           // .. define our handler:
           MonHandler handler = new MonHandler();
           // and parse:
           parser.parse("file:///sdcard/fichierxml.xml", handler);
       } catch (Exception ex) {
           ex.printStackTrace(System.out);
       return mObjectList;
private static final class MonHandler extends DefaultHandler {
    	private String lastElement = "null";
       	static MonObject actualObject = new MonObject();
        // invoked when document-parsing is started:
        public void startDocument() throws SAXException {
            System.out.println("Document processing started");
        // notifies about finish of parsing:
        public void endDocument() throws SAXException {
            for(int i = 0; i<mObjectList.size();i++){
		MonObject focusedObject = mObjectList.get(i);
		System.out.println(focusedObject.getName());
            System.out.println("Document processing finished");
        // we enter to element 'qName':
        public void startElement(String uri, String localName,
                String qName, Attributes attrs) throws SAXException {
            if (qName.equals("maintag")) {
            } else if (qName.equals("MonObject")) {
            	actualObject.setName(attrs.getValue("name"));
            	mObjectList.add(actualObject);
            /* if (...)
                        } */ else {
                throw new IllegalArgumentException("Element '" +
                        qName + "' is not allowed here");
            setLastElement(qName);
        // we leave element 'qName' without any actions:
        public void endElement(String uri, String localName, String qName)
            // do nothing;
		public void setLastElement(String lastElement) {
			this.lastElement = lastElement;
		public String getLastElement() {
			return lastElement;
Mais les System.out de la boucle donnent
object2
object2
object2
au lieu de donner
object0
object1
object2
Pourtant juste avant de l'ajouter dans l'arraylist je fais un MonObject.getName() j'obtient le nom correct
Donc quand j'ajoute un élément à mon ArrayList, tout les autres éléments prennent la valeur du dernier.
Si au lieu de faire un ArrayList de MonObject je fais un arraylist de String là sa marche mais c'est pas le but car j'ai plusieurs variables puis plus tard une liste dans une liste à retourner.
Quelqu'un aurait une solution?
C'est logique puisque ton objet "actualObject" est déclaré static donc c'est une instance de classe donc unique pour ta classe.
En enlevant static ça devrait fonctionner.
  • Auteur
               try {
           // and parse:
       return mObjectList;
private final class MonHandler extends DefaultHandler {
                       mObjectList.add(new MonObject(actualObject));
                   /* if (...)
                               } */ else {
                   // do nothing;
                               return lastElement;
Merci mais le problème est toujours présent, j'ai enlevé le static dans la déclaration de actualObject, j'ai même testé en l'enlevant dans la déclaration de la class du handler, et pour éviter un problème de passage par référence j'ai créer dans la classe MonObject un constructeur qui va copier les variables "new MonObject(actualObject);"
Là je ne trouve vraiment pas le problème
Effectivement bizarre. Peux tu donner le code de ta classe MonObject ... j'imagine qu'elle n'est pas statique ;)
et un exemple de ton fichier xml.
Ainsi je le lancerai chez moi pour voir ça.
  • Auteur
Problème résolu, en voyant la réponse de nbbu j'ai regardé les variables de ma classe MonObject, la classe n'étai pas en static mais les variables oui.
Merci !! :D
