[THEME][METAMORPH] Buuf - Galaxy Edition 2010 (Cupcake & Donut)
• SCREENSHOTS :
mini_552012device01.png mini_152925device02.png mini_442744device10.png mini_716993device03.png mini_657335device04.png
mini_513658device05.png mini_830417device07.png mini_777957device08.png mini_937350device09.png mini_663743device06.png
mini_437672device12.png mini_861585device11.png mini_153270device13.png mini_778632device14.png mini_935215device15.png
mini_740065device17.png mini_754821device18.png mini_563708device19.png mini_728158device22.png mini_36878device24.png
mini_353092device37.png mini_861080device32.png mini_116169device30.png mini_809875device36.png mini_178371device29.png
• CREDITS :
Metamorph app by stericson
Galaxo rom by drakaz
Buuf artworks by mattahan
Original Buuf build by dthadamaja
Present Buuf build by DeaDnuLL
Buufed Widgets by Asphalto
Buuf Galaxy Edition 2010 by TerryFX,
including icons by manup456
• CUPCAKE RELEASE
BUUF - GALAXY EDITION 2010
v1.0
Metamorph Theme by TerryFX
02/18/10
ANDROID 1.5 CUPCAKE - GALAXY RUNNING GALAXO
METAMORPH REQUIRED.
CAUTION
I am not responsible for any damages done to your phone with this theme.
ALWAYS make a NANDROID BACKUP before installing or updating a theme. You have been warned.
DOWNLOAD LINK : Buuf - Galaxy Edition 2010 - CUPCAKE
• DONUT RELEASES
v1.6b1
02/25/10
ANDROID 1.6 DONUT - GALAXY RUNNING GALAXO 1.6.1
METAMORPH REQUIRED.
Be careful, this is a beta release for testing purposes only
CAUTION
DOWNLOAD LINK : Buuf - Galaxy Edition 2010 v1.6b1 - DONUT
v1.6b2
Metamorph theme by TerryFX
03/10/10
ANDROID 1.6 DONUT - GALAXY RUNNING GALAXO 1.2/1.6.1
METAMORPH REQUIRED
This is still a beta release.
CAUTION
I am not responsible for ANY damages done to your phone with this theme.
1.6b2 changelog :
* enhanced 9.png (calendar/music/camera/searchbar widgets)
* suppressed useless icons from original v1.0 cupcake release
* added some missing icons
DOWNLOAD LINK : Buuf - Galaxy Edition 2010 v1.6b2 - DONUT
v1.6b3
03/20/10
METAMORPH REQUIRED
CAUTION
1.6b3 changelog :
* added metamorph fonts changer
 you just have to add your favourite fonts in the BUUF-GE2010 'fonts' folder
* added metamorph status-bar notifications color changer
 white notifications are now included in the Buuf GE 2010 theme
* fixed maps icons
 full compatibility with new Maps releases
DOWNLOAD LINK : Buuf - Galaxy Edition 2010 v1.6b3 - DONUT
CAUTION : v1.6b3 is NOT fully compatible with the new Galaxo 1.6.2.
If your Galaxy is running Galaxo 1.6.2, you have to : FIRST delete the 'services' BUUF-GE2010 subfolder, THEN flash the whole theme.
v1.6b4
04/09/10
(1.6.2 users : do NOT morph the 'services.cpy' metamorph part!!)
METAMORPH REQUIRED
CAUTION
1.6b4 changelog :
* dark theme (launcher/status_bar/popup/lockscreen)
* improved status_bar icons
DOWNLOAD LINK : Buuf - Galaxy Edition 2010 v1.6b4 - DONUT
CAUTION : v1.6b4 is NOT fully compatible with Galaxo 1.6.2.
v1.6b5
05/14/10
ANDROID 1.6 DONUT - GALAXY RUNNING GALAXO 1.6.3.1 ONLY
METAMORPH (1.9.8.5 or newer) REQUIRED
CAUTION
1.6b5 changelog :
* original light brown buuf, including dark popups & lockscreen
* themed eclair dialer
* graphic fixes & improvements
[NEW] DOWNLOAD LINK : Buuf - Galaxy Edition 2010 v1.6b5 - DONUT
>>edit 02/17/10 : added some screenshots (cupcake) & credits<<
>>edit 02/18/10 : added disclaimer/download link (cupcake)<<
>>edit 02/25/10 : added new disclaimer/download link (donut)<<
>>edit 02/25/10 : added some screenshots (donut)<<
>>edit 02/26/10 : updated screenshots (donut)<<
>>edit 03/11/10 : added new disclaimer/download link (donut)<<
>>edit 03/21/10 : added new disclaimer/download link (donut)<<
>>edit 04/03/10 : updated screenshots (donut)<<
>>edit 04/06/10 : added new disclaimer (donut)<<
>>edit 04/07/10 : added link to flashback<<
>>edit 04/10/10 : added disclaimer/download link (donut)<<
>>edit 05/14/10 : added disclaimer/download link (donut)<<
WE HAVE TO GO BACK, KATE
get tired of buuf and want to go back to the galaxo original theme? easy, guys : see here for details
Modifié par TerryFX
  • Réponses 127
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
je viens d'ajouter quelques screenshots supplémentaires dans le message original.
quelques précisions utiles :
>la police de caractères utilisée sur les screenshots ne pourra être distribuée car elle est sous copyright.
>pour la même raison les fonds d'écrans ne seront pas fournis, vous pourrez cependant en trouver certains sur deviantart.
>certaines Gapps ne peuvent être directement métamorphées. pour ceux qui souhaiteront malgré tout les modifier, vous trouverez le mode opératoire sécurisé ainsi que tous les outils dont vous aurez besoin sur le site de DeaDnuLL, où vous pourrez également récupérer les widgets d'Asphalto.
>le theme buuf est connu pour être un theme atypique et surtout extrêmement complet, où tout ou presque est modifié. durant ces derniers mois, j'ai utilisé et retouché énormément de fichiers png pré-existants, tous issus du travail original de mattahan, des releases buuf officielles ainsi que d'autres themes majeurs. il s'agit donc plus de ma part d'un travail de refonte synthétique et d'adaptation sur galaxy que d'une véritable nouvelle version du thème.
Modifié par TerryFX
ton problème vient de l'utilisation de metamorph. marche à suivre :
1.installer metamorph, lui donner les droits super utilisateur dans SuperUser ('Always')
2.décompresser le .zip du theme tel quel dans le dossier 'AndroidThemes', créé automatiquement par metamorph sur la sd externe
3.lancer metamorph, choisir 'Thèmes Existants', rentrer dans le dossier du thème en question, puis pointer le fichier .thm à flasher
Je suis passé à ta version de buuf pour 1.6, comme j'avais déjà fait la mienne en 1.5 j'avais pas testé encore et j'ai bien aimé les changements d'animations du framework (zoom à l'ouverture des applis et rebondissement des menus), je ne les avais pas avant :D
tu les as choppé où ? y en a d'autres comme ça ? :D
Modifié par cikatrice
Salut, très beaux thèmes, cependant j'ai plein de widget qui bug, il y'a un affichage "impossible de charger le widget" dans un carré gris (notament retro clock et battery widget).
Je voudrais savoir, qu'elle sont les fichier à installer seul pour avoir juste la nouvelle animation pour les pages stp ?
s'agit d'effets d'animation zoom/blur/slide présents dans certains mods cyanogen, ainsi que dans l'appli spare parts. je trouve que ça rend le tél un peu plus bondissant, alors je les ai inclus directement dans le thème. content que ça vous plaise également.
pour les widgets récalcitrants, c'est normal. après un morph, faut simplement les mettre à la corbeille puis les recréer...en principe, tout rentre alors dans l'ordre.
...une version plus complète et légèrement remaniée de ce thème buuf devrait pouvoir être en ligne dans le courant de la semaine prochaine, au pire au début de la suivante.
en attendant, j'aurais aimé avoir les remontées des bugs éventuels, quelques avis de ceux qui l'ont installé ou même simplement ceux des visiteurs au vu des screenshots présentés sur le premier post...bref, un peu de vie sur le sujet.
je rappelle donc simplement que sous galaxo et avec une sauvegarde nandroid préalablement effectuée via le recovery de drakaz, il n'y a quasiment aucun risque à installer un thème metamorph: il marche pas, ou bien vous aimez pas le résultat, ben hop : recovery -> restore nandroid -> et c'est reparti comme avant le morph, c'est à dire sans aucune perte des appli et des réglages précédents.
pour résumer, metamorph c'est pas plus risqué qu'un thème 'classique' en update.zip à flasher via le recovery, et c'est surtout beaucoup plus user-friendly et paramétrable pour l'installation des thèmes. après, moi je dis ça je dis rien :D
un root simple activé par exemple depuis le recovery de drakaz ne suffit malheureusement pas. pour pouvoir utiliser metamorph, il faut obligatoirement un root total avec adb remount autorisé, plus une busybox complète installée.
dans ton cas, le plus simple serait donc d'installer galaxo 1.1.1 sur ton cupcake II5, ce qui te fournirait tout cela sans trop d'efforts. par contre il te faudra alors obligatoirement wiper.
...et à wiper, c'est à dire à devoir par la suite réinstaller toutes tes applis et refaire tes réglages, je te conseillerais donc plutôt de franchir directement le cap donut puis d'installer galaxo 1.2.1 dans la foulée : tu auras alors un galaxy parfaitement à jour, fluide, réactif, et prêt à être métamorphé et remétamorphé à volonté.
Modifié par TerryFX
je prefere largement metamorph ! au moins avec ça je peux m'amuser à faire des compo de théme déjà crée :) car je suis une grosse féniasse qui veux pas faire de théme alors que j'ai que [color=red][b]sa[/b][/color] afaire des fois. ^^
