[ROM][2.1 Sense] BeHero v1.3.2 Legendary Edition [13/03/10]
Gutsu
http://htcpedia.com/forum/showthread.php?t=2196
Hop une nouvelle rom, celle-ci vient de la part de Behnaam...
A voir, n'hésitez pas à tester !
BeHero
Port of the Eris 2.1 leak
Thanks to MaXo64 for his 3G fix I had issues with and Raiderx for help. I fixed WiFi and FC bug. Heavy optimization coming soon
Including:
Most goodies from 2.1
Working WiFi
Working:
Almost everything
Not working:
Gsensors
EDIT : hé ben ils sont tous au taquet apparement :p
Originally Posted by e.japonica
hope soon can fix the Gsensors
Im working on it!
Highly optimized rom for tonight! it will be nice!
A suivre de près cette rom :p
Heavy optmization going on right now! Tonights release will be blazing fast!!
Hummmm, Vivement ce soir !! :p
CHANGELOG v1.2.4
- Made a init.d script to give pptp vpn correct permissions
- Removed Stock app, to free up space
- Cleaned up a little
- SMD Port logcat error fixed
CHANGELOG v1.2.5
- MMS issues solved by hyriands MmsZap that, big props to him!
- Sqlite3 support added
- Weather animation fixed
CHANGELOG v1.2.6
- Optimized most htc apps + widgets
- Moved dalvik-cache back to /data
- Alot better battery life
- VPN now fully fixed with right permissions!
CHANGELOG:
v1.3
- Rebased on HTC Legend leak
- SIM contacts can now be disabled
- All the goodies from before
- Friendstream + Friendstream widget
- Louder Volume hack
CHANGELOG: v1.3.1
- Shutdown working
- Speaker working
- Incoming/outgoing mic fixed
CHANGELOG: v1.3.2
- Mic volume fixed!- Heavly optimized build, about 6MB gain (all sense apps optimized)
- New Low Mem killer in init.d to boost speed, thanks to RaiderX for the mod
- Media folder moved to /data to free up space in system
- New lockscreen look from the newer Legend leaks!
Modifié par Gutsu
  • Réponses 319
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Je pense l'installer enfin j'hésite avec l'autre :p
v1.2
- HTC Bootsanimation from HTC Legend
- init.d scripts added like apps2sd and low mem killer
- added some apps to /data/app like jbed and navstarter
- Busybox
- Added more language support, needs wipe!
Je confirme, la nouvelle 1.2 boot bien et on peut voir le joli bootscreen du Legend a savoir : fond blanc HTC en vert avec "quietly brillant" qui s'affiche. L'avis de la ROM arrive bientot ;)
Test :
Accelerometre OK !
>Quelques légers détails graphiques nouveaux dans Sense (ca charme l'oeil :p)
>Le "Unlocking SIM Card" est long, cliquez sur Home, cela passe (votre SIM est bien activée ;))
>Francais inclus ! :)
>Transition de screen de droite a gauche comme dans Android 2.1 donc bien au rendez vous ! :)
>wifi fonctionnel !
>Clavier tres fluide !
>La liste d'APN contient les réseaux francais
>Pinch Zoom du bureau vraiment fluide ! :) Appuyer sur Home quand on est sur le bureau, active la vue 7 écrans ;)
>Pour un premier boot, l'ensemble est très fluide pour etre une beta ! :o
>Différenciation Widget Andorid et Widget HTC dans le menu (pas comme dans les vidéos de présentation)
>Pas de FriendStream mais le widget Twitter de Sense 1 ... :o
>L echange de fichiers par bluetooth devrait marché car on peut afficher sur le bureau le raccourci : "Bluetooth recu"
>Meme probleme que Profete, l'icone Mail du bureau ne renvoit pas vers l'appli', enlever et remettez le raccourci ;)
>La trackball clignote rapidement pour signaler le debut d'un téléchargement sur le market ! :)
>Possibilité de désactiver le flash du navigateur
Un jeux Miniclip en flash se lance bien !!
En n'ayant rien killer depuis le demarrage et en lancait a droite a gauche pleins de programme pour tester, le Hero ne bronche pas et est toujours aussi fluide ! :rolleyes:
J'éditerai ce message
Modifié par Zoozloz
@Zoozloz : Peut être une question bête, je supprimerai si c'est le cas, mais qu'entends tu par : >Transition de screen de droite a gauche comme dans Android 2.1 donc bien au rendez vous ! ?
Dans Android 2.1 le passage d'un écran a l autre au sein d'une application (n'importe laqeulle) se fait par un "slide" de la gauche vers la droite, par exemple dans GMail, tu clic sur un mail, la page l'affichant va venir de la droite. Un détail graphique incorporé a Android 2.1 ;)
Pour ma part: ( j'éditerai ce message aussi)
* L'appli mail sur le bureau ne se lance pas ( linked program is not installed) - En fait c'est juste le raccourci du bureau qui foire.. lol
* Démarrage OK et rien à signaler, synchro en cours
* Ca respire la rapidité
*premier contact avec le market, quand on va sur download, on retrouve effectivement toutes ses anciennes applis! Super cool!
*On a encore droit à HTC widget et android widget, je pensais que les 2 avaient été réunis..
* Pas de Synchro facebook ( il me trouve aucun ami!)
* Enfin un widget agenda valable!!!! ( du genre pure calendar mais en moins beau et moins pratique!)
Modifié par Profete162
Je suis bluffé par le flash sur le navigateur, les jeux sont bien meme si forcemment ca lag un peu parfois, j'aurais pas cru que le Hero tournerait aussi bien ! :o A voir en utilisation quotidienne et pour les refractaires a Flash,on peut désactiver ;)
Profete, peut tu me confirmer ce phénomène :
>J'ouvre le market, je retourne sur le home, j ouvre un taskiller et je vois bien le processus "Market" en mémoire, j'ouvre le navigateur, je reviens, j'ouvre taskiller, j'ai bien le processus Navigateur mais plus le processus Market ? oO
En killant tout on est a 100Mo en tout cas ;)
Modifié par Zoozloz
fait peter farmville :D
Je vais voir :p Double tap sur un jeux flash et on l'a en grand écran :) Pour FarmVille, on lance le site, le jeux se lance, double tap pour un plein écran et encore un double tap pour avoir un zoom correct ! :) Le chargement du jeu se bloque vers 95% je ne sais pas pourquoi oO (jeux lourd en lui meme) (J'ai lancé le jeu avec tout killé et 100Mo de mémoire dispo ;))
Modifié par Zoozloz
