kartl Posté(e) 10 octobre 2011 Share Posté(e) 10 octobre 2011 Bonjour, Etant Dj et faisant de la MAO depuis un moment, un des gros manques sous Android etait pour moi les logiciels de MAO (Musique Assistee par Ordinateur) pour la musique electronique. Je ne m etais pas penche sur le probleme depuis un moment, chose rattrappee ce week end :) donc voici une liste non exaustive de soft de sons qui fonctionne sous notre Folio (version Honeycomb Ifffo) : Caustic : un reason like pour ceux qui connaisse, absoluement formidable et plus que prometteur : * 1x Virtual analog subsynth * 2x PCM synths (23 demo samples included) * 2x 303-like BassLine synths * 1x Sampling drum machine (9 demo kits included) * 1x Mixer desk with Delay/Reverb and 7 insert effects * 1x Song sequencer RD3 HD : groovebox like - Virtual analog synthesizer - 3 types of waveforms - Reminiscent of the legendary 303 synthesizer - Programmable drum machine - High-quality or regular filter modes - Real-time step sequencer - 4 bars with 16 steps per instrument - 3 play modes: Solo, loop or random - Multi-touch control - Cut/copy/paste pattern - App2SD SPC : Musical Features: - 16-pad screen mixes loops and sequences - Pad play options: Loop, One Shot and direct sample play - Three pad start options: Instant, Next Beat, Next Bar - Tap Tempo Loops: - Edit feature with 4 variations for each loop pad - Waveform display - Configurable volume and pan envelope - Slicer for recombining loop elements - Loop recorder with quantization and overdub function - Reverse and normalize function - Up to 8-bar long loops Samples and sequencer: - 4-bar sequencer for each sample pad - Keyboard for setting note information for each step - Waveform display - Gain, pan and tuning knobs - Envelope control with attack and decay - Recording of one-shot samples with a microphone - Reverse and normalize function Electrum drum machine : boite a rythme G-stomper drum machine : boite a ryhtme, sequence... (groovebox like) U-loops : fruity loop like (studio multimedia), helas pas de mode offline Musicien... Enjoy :) moi je me fais bien plaisir et c etait le gros manque pour moi J essaierai de tenir cette liste a jour a fil de mes decouvertes, je cherche encore en autre, un bon sampler ainsi que des multi effets KartL Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AtrKaInN Posté(e) 31 janvier 2012 Share Posté(e) 31 janvier 2012 salut j'aurais une question, cela fait plusieur jour que je cherche d'autre kit batterie pour electrum drum, saurais tu ou je pourrais en trouver? Merci d'avance, en tout cas merci pour le poste c'est bien utile d'avoir ces applis répertorié Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
JérômeGautier Posté(e) 31 janvier 2012 Share Posté(e) 31 janvier 2012 merci je sens que je vais tester ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kartl Posté(e) 2 février 2012 Auteur Share Posté(e) 2 février 2012 Helas pour les kits je ne sais pas par contre, j ai trouve un artiocle interessant sur le pourquoi du retard des applications de musiques electroniques sur Android par rapport a d autres systemes (que je ne citerais pas lol ;)) http://www.musiquetactile.fr/android-est-tres-en-retard-sur-ios/ en bref le probleme vient d un gros probleme de latence sur le noyau Linux d Android ce qui pose de gros probleme au dev d applis de sons... en bref comme sous Debian par exemple, il faudrait un noyau real time pre-emptif pour le son afin d eviter cette latence mais malgre des demandes de dev pour le moment rien ne bouge cote Google... pour soutenir la demande d un noyau low-latency pour l audio sous Android... c est ici : http://code.google.com/p/android/issues/detail?id=3434 ++ Kart L Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
