[ROM] Villain 3.4 based on Eris 2.1
arunan
VillainROM 3.4
I take no responsibility for anything. The end.
VillainROM WIKI
Please check out the VillainROM Wiki; courtesy of some members of our mini-community. (Thanks in particular to Kendong, Piercy, LennyUK & anon2212). Sorry if I missed anyone!
Features of VillainROM3.4
INSTALL GUIDE
- Perform FULL Wipe
- Flash the ROM
- Wait up to 7 minutes for first boot
- On first boot, if you have widget issues, do this:
Settings>Applications>Manage Applications>HTC Sense> CLEAR DATA! (fixed!)
Customised/Ported/Optimized version of Manup's SenseHero theme. I've put several hours into getting this working in a 2.X Sense rom, as it was designed for 1.5.
If you spot any bugs in it, please let me know and I will fix.
GenieWidget
100% Working Weather Animation
Several Languages
VPN Working
Speed Tweaks
SMD Port error fixed (helps battery)
Navigator included (links to maps successfully)
MMS ZAP 2.0 (AUTO CONFIGURES!)
Minimised Battery Drain via several fixes
Sleep mode issue semi-resolved (Please feedback
HTC (Quietly Brilliant) Bootscreen (Please PM me with alternative boot options and I will add to this thread)
Added HTC Today in History Widget to /DATA
Added HTC Battery Widget to /DATA
Re-added Stock App & Widget
Re-added Gallery 3D MT - Still suffers from rotation bug
Replaced WIFI Tether with ANetShare - working
Apps2SD
HUGE APN list
Wifi using all 13 channels
Loads of languages added
Busybox
Root
Push working perfectly
Battery drain cannot be totally fixed, despite what some people are claiming. The battery issue is primarily due to the kernel itself, not the roms. Until we get a decent kernel from HTC, battery life will be an issue. I have, however spent a ridiculous amount of time attempting to resolve the Battery issue in this build.
Téléchargement : http://www.4shared.com/file/240338692/4198002a/newvill3.html
Topic Officiel : http://forum.xda-developers.com/showthread.php?t=622468
Modifié par arunan
  • Réponses 148
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Question lag et rapidité? c'est pareil que les autres d'aujourd'hui?
Franchement aucun Rom est aussi rapide que celui-là en 2.1 je trouve !!!!
Ta essayé les 4 roms présente ? car les nouvelles 2.1 sont les plus rapide mais après dire que villain plus rapide que les autres ça va être dur ...
par contre root explorer marche pas car il y a pas la popup pour le su :/
Idem pour EStrong / Adfree / DroidWall ...
Modifié par Invité
De mon côté aussi je suis très satisfait de la villain 3.0. Je test la 3.1 aujourd'hui.
EDIT : Gros problème de batterie par contre chez moi, en une nuit avec wifi/3G/synchro activé je suis passé de 100% à 68% de batterie.
Modifié par guimalherbe
j'ai installé la 3.0 mais le root ne fonctionnait pas. J'ai donc upgradé en 3.1 mais là c 'est la 3G qui ne fonctionnait pas (sympa pour un téléphone sensé être toujours connecté :P )
J'ai donc fait un wipe et réinstallé la 3.1 et toujours pas de 3G.
Quelqu'un d'autre a le même souci?
Autrement rom bien fluide, Sense 2 fonctionne nickel.
Pour la batterie en une nuit en mode avions, j'ai perdu 1% :)
Je ne fais que ca maintenant.
J'ai des soucis de reseaux chez moi...et parfois, le tel est eteint le matin a cause de la recherche de reseaux mobiles qui me pompe toute la batterie.
Un jour que je n'avais pas sous la main de cable pour le brancher...je l'ai mis en mode avion alors qu'il etait dans le rouge...et bien il a tenu toute la nuit :)
Alors, pour la 3G, c'est la liste des operateurs qui n'a pas été intégré dans la 3.1. Elle le sera dans la 3.2 dispo ce soir normalement (forum xda).
Pour les widgets HTC a priori il faut effacer la sd. Perso, sur la 3.0 j'avais tout qui marchait.
Pour moi la 3g fonctionne, mais j'ai du configurer manuellement l'APN.
Je vais de suite tester la 3.1 de villain !!!!!
Pour la batterie nickel je trouve, car j'avais une charge de 100 % avant d'installer la rom de villain et c'est maintenant que je recharge, mais entre temps j'ai du faire 30 min gps google, et pratiquement plus de 3heures d'internet 3g pour télécharger et puis apres j'ai testé les applica[color=red]tion[/color] et voila maintenant je recharge !!!
