[ROM] Villain 3.4 based on Eris 2.1
arunan
pour le GPS, la technique de booter l'OS, activer le GPS puis rebooter semble fonctionner chez moi (j'ai pas fixer complétement mais j'ai des signaux (avec l'appli GPS Status)
par contre pour les MMS, ca essai d'envoyer mais pas d'activitée 3G ... pas de message d'erreur ni rien, et le MMS n'arrive jamais à destination (ma chérie :p )
  • Réponses 148
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Update 3.3
Included/Changes:
** Apps in Data are removable
GenieWidget*
Added Morelocale2 to /DATA (*see News & Weather info below)
Re-added JBED to /DATA & associated lib
Weather animation now works as it should (on unlock)
Re-added languages
Fixed VPN
SMD Port error fixed (helps battery)
Resolved Widget issue (please feed back)
Removed Navigation & Nav Launcher
Optimization of PNGs
MMS Fix app (MMSZap)to /DATA
Minimised Battery Drain**
Added Autokiller 1.1 to /DATA (Thanks to Ratson)
Added Villain Bios Boot Animation (thanks Tristan202)
Added HTC Today in History Widget to /DATA
Added HTC Battery Widget to /DATA
Fixed Double Picture Frame Widget
Removed Stock App & Widget
Removed 3D Gallery due to orientation bug. If you want this, I'll make an optional update.zip. However, it's not vital, and it just adds to my minimal 'Not Working' list.
* News & Weather (Genie Widget)
morelocale2 is included in this app. Set it to your country and it will alter Genie to pull through news specific to your nation. Another tip for this widget is to setup a custom topic such as your 'Kings of Leon'. It will pull through news related to Kings of Leon. Clever huh?
** Battery drain cannot be totally fixed, despite what some people are claiming. The battery issue is due to kernel itself, not the roms. Until we get a decent kernel from HTC, battery life will be an issue.
Bonjour à tous.
Pour eviter le HS, possesseur d'un hero depuis peu , ancien iphone user
Deja je ne regrette en rien mon achat au contraire
ensuite Merci à Wizz pour le tuto concernant le changement de rom
et aussi merci à tous pour ce forum qui regorge de conseils, d'astuces etc etc
Et enfin pour revenir au sujet qui nous interesse,
J'ai fais la maj sur la V3.3 et aucun probléme pour moi non plus, sans aucun wipe venant de la 3.2
Et effectivement le 1er démarrage est long ( avec une préférence pour le bootscreen de la 3.2 )
Mip
Ca bloque sur l'image android depuis plus de 30 minutes, a mon avis c'est pas normale!
J'ai fais un wipe avant de faire la migration depuis la modaco 3.0!
Quelqu'un aurais une idée ou une solution ? Merci
Totor pourquoi ne pas faire un formatage complet de ta sd, un wipe et une install de la 3.3
Cela pourrait, je pense régler ton probléme
Mip
Ca bloque sur l'image android depuis plus de 30 minutes' date=' a mon avis c'est pas normale!
Quelqu'un aurais une idée ou une solution ? Merci[/quote']
Mip
C'est exactement ce que j'ai fais! j'ai formaté ma sd et crée une partition Ext3, j'ai wiper et install la 3.3, ça boot et après ça bloque sur le bootscreen :o
Quand tu dis le premier démarrage est long, c'est combien de minutes?
Est-ce que j'aurais du DOWNGRADER en version en 2.73.405.5 avant l'install comme dans ce tuto https://www.frandroid.com/forum/viewtopic.php?id=9031 ?
Les amis faut pas dire de bêtises !
C'est complètement inutile pour lui
Le downgrade vise les personnes étant en personnalisation opérateur, Orange en particulier et permet d'installer Amon Ra recovery
totor777 peut déjà flasher/wipe, il dispose déja du recovery...
@totor777
Re télécharge l'archive zip de la ROM, fait un wipe complet et retente le flashage.
Invité Shippo
Si jamais comme moi lors du 1er boot vous pouvez rien synchro (gmail, facebook etc...) vous bilez pas, un reboot (un Mars ?:p) et ça repart !!
@totor777
Merci wiz! Je suis quand même revenu à la version usine!
La je wipe/flash ça démarre bien, mais au moment de saisir le pin j'ai plein de FC qui s'ouvre... android.phone , android.process.media , fermeture soudaine de l'application HTC sense... je met le pin, je vois un arrière plan HTC et la ça recommence les FC et ça redemande le PIN... :mad:
J'ai mis a jour le radio, rien n'y fais... j'ai essayé la 3.2 ça fait pareil! Sais plus quoi faire a part tester une autre ROM...
Tu flash directement après le wipe ou redémarre tu entre temps ? (A ne pas faire !)
Réssaie:
Télécharge de nouveau la ROM: Modaco 3.2 copie le à la racine de ta SD.
Boot en recovery
Wipe: Dalvik cache puis ext partition puis Factory reset
Puis toujours dans le recovery, flash le zip.
Y'a aucune raison que ça fonctionne pas.
Modifié par Wiz ^^
Merci à la Villain !! Cette ROM me fait reprendre goût à mon Hero qui commençait à me gonfler, même avec la modaco 3.x
Totor777 : j'ai eu exactement le même problème que toi, je l'ai résolu en faisant tous les Wipes possibles avec l'Amon Ra et en rebootant. Pour info, j'ai fait une partition ext3 ...
J'ai fait la manip du FAQ de Wiz pour récupérer le LockScreen d'android 2.1 sur la Rom villain 3.3.
Le probleme c'est que j'ai plus de background au moment du LockScreen, je vois en transparence HTC sense.
Certains d'entre vous ont ils fait cette manip ?
Merci d'avance
Modifié par Phil-Dar
